Okay to put subwoofer inside ottoman? - AVS Forum
post #1 of 3 Old 06-24-2013, 06:00 PM - Thread Starter
nthydro's Avatar
I have a Logitech LS21 2.1 sound system I use for my PC. It comes with a small down firing sub-woofer (4 inch driver). Right now I have the sub sitting under my computer desk. I'm using it as a footstool but its not very comfortable lol. I plan to get one of those ottoman / footstool but I don't want it to get too cramped down there. I just want to know if it's okay to put the sub inside the ottoman? Will there be any issues with heat or sound quality? Thanks.
Here are pictures of the sub-woofer and ottoman I want to get:
nthydro is offline
post #2 of 3 Old 06-24-2013, 09:10 PM
crn3371's Avatar
Quoted: 21 Post(s)
Liked: 42
Heat could be an issue. You'd have to cut a hole in the side of the ottoman for the port.
crn3371 is offline
post #3 of 3 Old 06-24-2013, 09:10 PM
crn3371's Avatar
Quoted: 21 Post(s)
Liked: 42
crn3371 is offline
User Tag List
