subwoofer in a cabinet with HT electronics above, will it damage? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-25-2013, 04:49 AM - Thread Starter
flyhigh123's Avatar
I am planning on building a cabinet/equipment rack. I was planning on the cabinet to be be built so its a clean and flush install with the current wall. I was thinking of having the electronics on the upper half, and have a sub woofer sitting below inside the cabinet. The bottom of the cabinet will be cut open and have a speaker mesh in front of the sub, but i was wondering if the subs sound will damage the amps, receivers, htpc, or ps3 that is sitting on the shelves/racks above the sub?
thanks
flyhigh123 is offline
post #2 of 5 Old 06-25-2013, 07:18 PM - Thread Starter
flyhigh123's Avatar
Bump
post #3 of 5 Old 06-25-2013, 07:25 PM
gregzoll's Avatar
Liked: 33
How loud do you plan on playing stuff (ie movies, music)? In other words, if you were to measure the sound output in the room that this system is going to be in, what is ambient sound level (quiet noise, nothing turned on in the room), then what is the sound level with stuff at a reasonable level. Now with those two out of the way, if you plan on playing stuff as if Motorhead was in the room with their gear cranked up all the way, yes the vibration from that sub could cause equipment to vibrate too much, along with if you do not have any kind of venting out the back to help disperse heat buildup from the equipment and sub, you can shorten the life of everything.
gregzoll is offline
post #4 of 5 Old 06-26-2013, 03:48 AM - Thread Starter
flyhigh123's Avatar
the cabinet will be vented at the top, but the sub will be a 18" sub for a theater room, so it will be putting out some extended LFE. i'm trying to keep the sub out of sight. maybe if i seperate the 2 a little with a wall between the top and bottom I wonder if that will help.
post #5 of 5 Old 06-26-2013, 05:29 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
It all depends on how loud you play your system, the bass extension of the subwoofer, the structure supporting the sub and the electronics, etc. In general modern electronics resists vibration, but precision mechanical components such as Blu Ray players can mistrack if there is a lot of vibration.
arnyk is offline
