Bass Fading In and Out?? - AVS Forum | Home Theater Discussions And Reviews
Old 06-27-2013, 07:06 PM - Thread Starter
SumoRerun's Avatar
While listening to my music, the bass from my subs will fade and get really weak. Turning up my bass remote for the amp doesn't help. Does this sound like a sub or an amp problem?
SumoRerun is offline
Old 06-27-2013, 07:12 PM
BeeMan458's Avatar
Liked: 813
Do you have another subwoofer you can connect to your system to see if it's an AVR output problem?
If not, do you have another pre-amp you can connect your subwoofer to see if the described subwoofer problem persists when connected to another functioning output device?
Maybe take the subwoofer over to a friend's house and try their AVR pre-out.
BeeMan458 is offline
