xmas /excursion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-29-2013, 05:50 PM - Thread Starter
newc33's Avatar
Quoted: 745 Post(s)
Liked: 920
What is Xmas and what is excursion?
Iknow it has something to do with the travel of the woofer.
Does more or less excursion or Xmas make a sub better if its the same in every other area?
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is online now
post #2 of 8 Old 06-29-2013, 05:57 PM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5255
xmas is short for christmas which falls on december 25th every year. smile.gif
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #3 of 8 Old 06-29-2013, 06:08 PM - Thread Starter
newc33's Avatar
Quoted: 745 Post(s)
Liked: 920
Well ima a Jehovah's whiteness....
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
post #4 of 8 Old 06-29-2013, 06:12 PM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5255
that explains it....however the term is xmax which is how far the driver can extend/travel without bottoming out.
newc33 likes this.
post #5 of 8 Old 06-29-2013, 06:13 PM
Tack's Avatar
Quoted: 2576 Post(s)
Liked: 3480
http://www.subwoofer-builder.com/xmax.htm
newc33 likes this.
Tack is online now
post #6 of 8 Old 06-29-2013, 06:17 PM - Thread Starter
newc33's Avatar
Quoted: 745 Post(s)
Liked: 920
Okay gotcha thanks!. I was joking btw:D
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
post #7 of 8 Old 06-29-2013, 06:20 PM - Thread Starter
newc33's Avatar
Quoted: 745 Post(s)
Liked: 920
Thanks! Bookmarked that one
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
post #8 of 8 Old 06-29-2013, 06:26 PM
oneeyeblind's Avatar
Quoted: 256 Post(s)
Liked: 466
Xmax is the amount of linear excursion a driver has one one way in or out. Normally its measured in mm. Generally Xmax is considered the usable limits of a drivers range. And what is considered clean or linear output.
Its measured two ways. One, is to take the length of the magnet gap and divide by two. This is usually more conservative. The other is to measure when the value BL is at 70% of the of its original strength. Or when the motor (voice coil and magnet ) working together are at 70 percent of the total strength. Xmech on the other hand is how far a driver can move total one way. So when the driver runs out of suspension travel and can't move anymore and the driver is at or will bottom if pushed anymore . Xmech is measured in mm.
Excursion is usually a term meaning total travel of the driver both ways. and is often measured in inches.
You can't tell the loudness or quality of bass from only how far it can move in and out. of how far it will travel its not that simple.
newc33 likes this.
ShaunH
oneeyeblind is offline
