Is this noise normal from a subwoofer? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 67 Old 07-24-2013, 09:37 PM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5253
go with the best sub you can afford...thats the best piece of advice I can offer.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #62 of 67 Old 07-24-2013, 09:51 PM - Thread Starter
guzz46's Avatar
Quoted: 16 Post(s)
Ok, I just brought the PC13-ULTRA, now I just have to wait three weeks for it to arrive.
guzz46 is offline
post #63 of 67 Old 07-24-2013, 09:55 PM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5253
congrats! Im sure it will be a worthy upgrade!
post #64 of 67 Old 07-24-2013, 09:57 PM
oztech's Avatar
Liked: 101
That size room needed a good ported sub or multiple sealed to get the OP 's desired bass.
oztech is offline
post #65 of 67 Old 07-24-2013, 11:30 PM
Oliver Deplace's Avatar
Liked: 33
The OP's room is under 1500CF and it's sealed.
For the ULS to struggle in such a small room isn't something I'd expect from Hsu's best sealed sub.
Oliver Deplace is offline
post #66 of 67 Old 07-25-2013, 11:21 AM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5253
Exactly...I was not even going to say anything since he apparently did not read the thread lol.
post #67 of 67 Old 07-25-2013, 08:48 PM
oztech's Avatar
Liked: 101
Yes I read the thread and then the end of my sentence was desired bass which may or may not of been having levels on the hot side.
I have had both sealed and ported and noticed that I always got more tactical feel out of the ported unit with same driver size your results may vary.
Even the mfg's will often try and sell two sealed units when the customer states he wants tactical feel in rooms of 1500cf even though his is just shy of that.
oztech is offline
