Dual Power Sound Audio XS30s or...? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 34 Old 07-04-2013, 07:48 AM - Thread Starter
rangers's Avatar
Quoted: 65 Post(s)
Liked: 51
I just ordered a LCR set of JTR 228 speakers. My room is 17 x 17 x 8'6" with openings on 3 sides (One opening is
6' x7'). I currently have 2 Polk PSW505s. I'll probably upgrade these subs soon and am looking at my options.
How about dual Power Sound Audio XS30s for $2183 shipped?
What other options do I have for this performance, price, quality, and customer service?
JTR Noesis 212HTR (LR)JTR 228 (Center and Surrounds)Seaton SubMersive HP Plus and Minus (Subs)Denon 3312 (Receiver)Sherbourn PA 7-350 (Amp)Oppo BDP-103 (BluRay Player) and Sharp 80" TV
rangers is offline
post #2 of 34 Old 07-04-2013, 07:52 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
how big are the other rooms that the 3 openings feed into?
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #3 of 34 Old 07-04-2013, 07:57 AM
steve nn's Avatar
Liked: 433
http://www.svsound.com/?gclid=CPS4s-ec87YCFUxxQgod_lYAVQ http://www.hsuresearch.com/ http://www.rythmikaudio.com/F15.html To name a few well respected ID Co.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #4 of 34 Old 07-04-2013, 08:13 AM
jeremymak's Avatar
or dual PSA Triax
jeremymak is offline
post #5 of 34 Old 07-04-2013, 08:37 AM
steve nn's Avatar
Liked: 433
Originally Posted by jeremymak View Post
or dual PSA Triax
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #6 of 34 Old 07-04-2013, 09:46 AM - Thread Starter
rangers's Avatar
Quoted: 65 Post(s)
Liked: 51
2 openings feed into hallways. The large opening feeds into a room approx 14 x 23.
And someone must have missed the cost factor in my post re dual Triax, lol
I wish I had that kind of budget
rangers is offline
post #7 of 34 Old 07-04-2013, 10:05 AM
BeeMan458's Avatar
Liked: 813
You can always fix that by adding a third XS30 at a later time and date.
Maybe a pair of XV30f's with an eye on a third or the addition of a XV15 or XV30 in the near future. That would help plug those openings.
(yup, works for me)
BeeMan458 is offline
post #8 of 34 Old 07-04-2013, 11:07 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
your dealing with 10000^3, I highly doubt any turn key dual sealed sub setup in your budget is going to net deeper extension than a ported sub in that size room.
I would be lookin at dual rythmik fv15hp's or psa xv30's.
post #9 of 34 Old 07-04-2013, 11:59 AM
ZivkoF's Avatar
Quoted: 22 Post(s)
Liked: 27
Hi rangers.
With JTR 228 speakers I would only considered Orbit Shifter LFU or LF smile.gif as the first option and the second option would be Captivator S2.
ZivkoF is offline
post #10 of 34 Old 07-04-2013, 01:11 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Originally Posted by ZivkoF View Post
Hi rangers.
Both of which are totally over his budget.
jbrown15 is offline
post #11 of 34 Old 07-05-2013, 12:52 AM
steve nn's Avatar
Liked: 433
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #12 of 34 Old 07-05-2013, 01:04 AM
jbrown15's Avatar
Liked: 1993
Originally Posted by steve nn View Post
jbrown15 is offline
post #13 of 34 Old 07-05-2013, 01:06 AM
jbrown15's Avatar
Liked: 1993
Two XS30's would probably work well if they were both placed near field to your seating location.
jbrown15 is offline
post #14 of 34 Old 07-05-2013, 07:05 AM - Thread Starter
rangers's Avatar
Quoted: 65 Post(s)
Liked: 51
Looking at all of my options, kicking ideas around....would one JTR Cap S1 be equal to two XS30s? Same cost....
One of my subs sits in a corner, 6' from my primary listening position. I could place it there.
rangers is offline
post #15 of 34 Old 07-05-2013, 10:20 AM
jbrown15's Avatar
Liked: 1993
No two XS30's will have more output then a single Cap S1, that was the very same dilemma I went threw. I was all set to buy a Cap S1 but for a little less money I could get dual XS30's.
jbrown15 is offline
post #16 of 34 Old 07-05-2013, 11:23 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
If you are set on sealed then get the dual xs30's.
post #17 of 34 Old 07-05-2013, 12:09 PM - Thread Starter
rangers's Avatar
Quoted: 65 Post(s)
Liked: 51
I am not set on anything.
rangers is offline
post #18 of 34 Old 07-05-2013, 01:05 PM
BeeMan458's Avatar
Liked: 813
For a similar price one could pick up three XS15's.
One could go asymmetrical with a XS30 and one XS15 with an early eye on a second XS15 at a later date. I'm partial to that combination. Yummmm!
post #19 of 34 Old 12-27-2013, 05:06 PM
JAMES MCHUGHES's Avatar
Quoted: 153 Post(s)
Liked: 52
Dual xs30's ordered hurry up Tom 😃
JAMES MCHUGHES is offline
post #20 of 34 Old 12-27-2013, 07:31 PM
BeeMan458's Avatar
Liked: 813
post #21 of 34 Old 12-27-2013, 08:14 PM
Quoted: 153 Post(s)
Liked: 52
Thx beeman
Subs are in such demand all on back order they can't make them fast enough lol
post #22 of 34 Old 12-28-2013, 01:41 AM
jbrown15's Avatar
Liked: 1993
Originally Posted by JAMES MCHUGHES View Post
Thx beeman
How big is your room James? I've had dual XS30's for over a year now and love them!
I have something a little crazier in the works for my room now, and will be taking them out of my theatre room but they have performed flawlessly since day one!
jbrown15 is offline
post #23 of 34 Old 12-28-2013, 07:05 AM
Quoted: 153 Post(s)
Liked: 52
Room is an open floor plan to kitchen about 25 x 12 with vaulted ceilings
post #24 of 34 Old 12-28-2013, 08:51 AM
ndskurfer's Avatar
Quoted: 39 Post(s)
Liked: 52
I have owned dual XS30's for a while now, you are going to love them! They replaced a single svs pc13, no regrets.
Just moved into a new home, same size room, but much better performance. Crazy how big of a difference it has been.
ndskurfer is offline
post #25 of 34 Old 12-29-2013, 11:31 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
Welcome to the dual xs30 club. It's a club full of grins!!
Brian Fineberg is offline
post #26 of 34 Old 12-29-2013, 12:00 PM
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Welcome to the club. I've had my duals for almost a year now and love them. They really are great subs and a great company too. Congrats!
mmarki is offline
post #27 of 34 Old 12-30-2013, 08:23 AM
Quoted: 153 Post(s)
Liked: 52
I've seen comments of people concerned of the amps behind DSP can anyone comment on this
post #28 of 34 Old 12-30-2013, 08:25 AM
Quoted: 153 Post(s)
Liked: 52
Thx Brian and Mark I'm sure they will be a great addition I can't wait
post #29 of 34 Old 11-29-2014, 06:33 AM
Quoted: 153 Post(s)
Liked: 52
Well my dual xs30's have been traded off I know have dual xv30f's with a single xv30 in rear :smiley:
post #30 of 34 Old 11-29-2014, 09:05 AM
Quoted: 153 Post(s)
Liked: 52
Pics
ID:	391602   Click image for larger version
