Sub enclosure tuing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-09-2013, 01:25 PM - Thread Starter
Chriscake's Avatar
I have a !.4 cuft sealed box with an 8 year old 12" European 4ohm sub. I want to port the box to get some lower notes. I don't expect miracles but would like to know the optimum frequency to tune the box to and what the optimum port width should be for that volume enclosure.
Chris
Chriscake is offline
post #2 of 6 Old 07-09-2013, 01:51 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
You would need the TS parameters of the subwoofer driver, in order to compute the diameter and length of the port. There are free softwares that does the computing for you like REW. Without the TS parameters your shooting blind
qguy is offline
post #3 of 6 Old 07-09-2013, 04:48 PM
Bill Fitzmaurice's Avatar
Liked: 5684
WinISD, not REW, which is room response measurement software.
Bill Fitzmaurice is offline
post #4 of 6 Old 07-10-2013, 03:32 PM - Thread Starter
Chriscake's Avatar
Thanks for the info. Will come in handy when I decide to build a 'real' box. For right now though, I think I am 'shooting blind'.The sub is a 10 year old 4ohm 12 incher that was overpriced when I bought itin Spain some 10 years ago For 40 Euros. There is no longer any info of that manufaturer or make and model on the internet. What I would really appreciate, is an educated guess basd on experience. I think the main challenge is porting a 1.4 cuft box for a 12" sub. So might a 2" port perform any better than a 3" and then what might be a half decent frequency to tune it to. I realy don't expect miracles.
Chris
post #5 of 6 Old 07-10-2013, 07:11 PM
Liked: 5684
Without T/S specs on the driver one can't even make a guess.
post #6 of 6 Old 07-13-2013, 09:27 AM
braveheart123's Avatar
Quoted: 330 Post(s)
Liked: 287
Chris
Without the T/S parameters you are groping in the dark. Alternatively, you can buy DATS (Dayton Audio Testing System) and determine the T/S parameters for the said driver;
http://www.amazon.com/Dayton-Audio-DATS-Test-System/dp/B007Q2NRU0/ref=sr_1_1?ie=UTF8&qid=1373732672&sr=8-1&keywords=dayton+audio+test+system
but knowing that you bought that sub for $40, spending an extra $100 to know its T/S parameters isn't worth it. I reckon you can buy some really nice used driver on eBay for that kind of money and then we can start from there. Otherwise, it's all waste of effort and time.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
