I want prefect reproduction of the whole sound spectrum - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Best sub size
8" 0 0%
10" 0 0%
12" 2 50.00%
15" 1 25.00%
18" 1 25.00%
Voters: 4. You may not vote on this poll
post #1 of 3 Old 07-10-2013, 06:03 PM - Thread Starter
Young123123's Avatar
The title pretty much says it all. I tell that to people at local car audio shops and they just give me a funny look. I already have two 10" ...they are way too quiet and don't seem to be able to reproduce the lower end of the spectrum? Does anyone have any suggestions?
When a sub says it can produce 25hz-1000hz is that even true? sounds like too wide of a range also how well can it reproduce those sounds at each point along that stated segment?
I appreciate your time and feedback.
Young123123 is offline
post #2 of 3 Old 07-10-2013, 06:06 PM
eljaycanuck's Avatar
Quoted: 1247 Post(s)
Liked: 1828
Subs don't play to 1000Hz because they don't need to. Usually, they'll play up to ~120-150Hz, occasionally up to ~200Hz (better for integrating with smaller satellite-type speakers).
SVS' subs have a nice, flat FR within a good range. Example: The PB12-NSD, flat from 18-150Hz +/-3dB.
Ditto PSA's subs, like the XV15 (flat from 21-200Hz +/-3dB).
Question is: At what level of output do you still want to see ruler-flat response? Generally-speaking, the louder you go, the less likely a sub will continue to play flat to the lower limit of its rated range.
Re. the vote: I'd go with 15" or 18". Since I can't pick both, and since I have dual 18" subs, I'll vote for 18". smile.gif
eljaycanuck is offline
post #3 of 3 Old 07-10-2013, 08:39 PM
DonH50's Avatar
Quoted: 1843 Post(s)
Liked: 1375
"perfect" < irony >
Post in the car audio subforum.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
