Small apartment friendly sub? - AVS Forum | Home Theater Discussions And Reviews
Old 07-12-2013, 09:56 AM - Thread Starter
mingus's Avatar
Quoted: 57 Post(s)
I know a sub is really designed as a *sub* woofer. I would like to find just a woofer, that is very tight and musical, maybe 8" sealed? Does not need to do 20hz, not helpful In an apartment. I have an HSU stf1 that is ok, looking for a change.
mingus is offline
Old 07-12-2013, 10:33 AM
kesando's Avatar
Liked: 31
What is your price range. What is wrong with the HSU?
kesando is offline
Old 07-12-2013, 11:16 AM
Quoted: 73 Post(s)
Liked: 112
I will echo kesando as to why you want to change from the STF-1 which is a fine sub for smaller places. If you just have the bug, you could look at the STF-2 or SVS as they have a couple models at $499 shipped.
rnatalli is offline
Old 07-12-2013, 12:08 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Reefdvr27 is offline
Old 07-12-2013, 08:44 PM - Thread Starter
mingus's Avatar
Quoted: 57 Post(s)
little more musical i guess, like a tighter bass. i realize a sub is a sub, but maybe something even smaller? i'll check the other thread.. thx
mingus is offline
Old 07-12-2013, 11:03 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Sealed box for sure, I'd go at least 10", a small 12 is probably better. Front not down-firing if you have downstairs neighbors. The apartment is hard, which is why I'm running full-range towers and no sub at the moment.
lespurgeon is offline
Old 07-13-2013, 06:41 AM
Quoted: 73 Post(s)
Liked: 112
If you can swing it, the SVS SB-1000 at $499 shipped is a good option.
rnatalli is offline
