hooking up sub to 2-channel receiver - AVS Forum | Home Theater Discussions And Reviews
Old 07-13-2013, 11:12 AM - Thread Starter
beatles75's Avatar
Hey guys. so I have a 2-channel receiver model STR-DH130. I have two floor speakers hooked up to it and I want a sub woofer. my friend has one he can give me but it doesn't have the speaker terminals so I can't hookup the sub to receiver and speakers to sub so it'll all work. Is there anyway I can use this sub or do I need one with the speaker terminal?
beatles75 is offline
Old 07-13-2013, 01:43 PM
myoda's Avatar
Liked: 57
You will need a way to get signal to the sub. Find a sub with speaker in and out termnals.
myoda is offline
Old 07-13-2013, 08:53 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
1. If your 2 channel receiver has headphone out, you can buy a headphone to RCA cable.
2. Get a speaker to line level converter, this would convert your speaker level to line level which you can use to hook up your subwoofer.
qguy is offline
Old 07-13-2013, 10:07 PM - Thread Starter
beatles75's Avatar
do you have a diagram or something to show me what you mean?
Old 07-15-2013, 12:31 AM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
1. Headphone to RCA cable
Connect the headphone end to the AVR, connect the other end to the Subwoofer line in.
2. Speaker level to Line level converters
https://www.google.com.ph/search?q=speaker+level+to+line+level+adapter&safe=off&source=lnms&tbm=isch&sa=X&ei=zJbjUbzuBqyTiQf71YCIBA&ved=0CAcQ_AUoAQ&biw=1440&bih=699
Connect another set of speaker wire to Speaker B of AVR, connect the other end to the converter. Connect RCA cable to converter and the other end to the subwoofer.
qguy is offline
Old 07-15-2013, 05:41 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Bear in mind that using the headphone jack might silence your speakers. If not, then this is feasible.
If your receiver has no B outputs, then you can simply connect to the same speaker outputs on the receiver as the speakers, or you can connect at the speakers' inputs. Both of those options would represent a parallel connection.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
Old 07-15-2013, 07:34 PM - Thread Starter
beatles75's Avatar
Well I have the main speakers hooked up as speaker set A...so can't I hook up the sub to speaker set B and wouldn't that work?
