Rythmik Audio FV15HP Direct Servo subwoofer review - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 07-16-2013, 09:40 PM
Cowboys's Avatar
Liked: 107
Should Longhorn try the subs with the room treatment next to the E15 removed?
Cowboys is offline
post #32 of 44 Old 07-17-2013, 03:52 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Originally Posted by bkeeler10 View Post
Right, or more specifically it takes a 10 dB increase in output for the human ear to perceive it as being twice as loud. You actually do get a doubling of pressure amplitude with a 3 dB increase, but our ears are not linear to changes in air pressure, so it takes an increase in SPL of 10 dB (requiring ten times the power) for the average person to say "now it's about twice as loud."
Longhorn I'm glad you're enjoying the new sub.
Right you are bk---more accurately put than I. Was thinking twice as loud (perception), wrote double the output (measured).
BDP24 is offline
post #33 of 44 Old 07-17-2013, 07:44 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 314
That was my first recommendation. But no, due to aesthetical reasons. Those in the photo on the left hand side are to cover windows. So he needs to put some on the right hand side wall to balance out. So his future plan is to get another unit and place on the right hand (in the photo) of the front wall.
Rythmik is offline
post #34 of 44 Old 07-17-2013, 03:35 PM - Thread Starter
Longhorn69's Avatar
If it wouldn't be a pain I would have tried removing the panels. But that really would just be to satiate my curiosity. Because as Brian mentioned, for aesthetic reasons I would have ended up putting them back up.
The lesson for me is that the room has a big affect. As well as that 1 FV15HP positioned well works great for me for now.
Longhorn69 is offline
post #35 of 44 Old 07-19-2013, 07:36 PM
Tom C's Avatar
Quoted: 69 Post(s)
Liked: 69
Originally Posted by Longhorn69 View Post
Here is a picture of my room. The "acoustical panel" on the back left (from this orientation) is a hidden door that opens to expose my gear, so I can't put a sub there. I had it in the back right corner from this vantage point. As you can see putting a sub along the back wall is not an option because of the closet door and the couch. The side walls would be problematic as well.
Congrats on the sub! Reading your review reminded me of when I brought home my Hsu VTF-15H last August. What a difference one of these bad boys makes! G44
Your room looks awesome!
LG OLED55B6P ** Denon AVR-X4200W ** oppo UDP-203 **oppo BDP-103D
HR44 DirecTV ** Panamax 5300 ** Harmony One Universal Remote
Hsu HB-1 MK2 (L, R & S) ** Hsu HC-1 MK2 (C) ** Hsu VTF-15H (sub)
Crowson Technology Level 2 Motion System
Tom C is offline
post #36 of 44 Old 08-13-2013, 12:35 PM
blackangst's Avatar
Quoted: 116 Post(s)
Liked: 102
Hey guys...taking a look at an FV15HP...room is 14'x44'x8'...about half of that is the family room (theater room), then a half wall and steps up to dining and kitchen area. So the question is...one or two? Would one underwhelm me? Ive currently got 2 Hsu 12's.
My system: Yamaha RX-A3060, Emotiva XPA-2, Salk Song3, Salk Songcenter RT, Polk FXiA6, Rythmik FV15HP, Intel i7 HTPC running JRiver Media Center
blackangst is offline
post #37 of 44 Old 08-13-2013, 05:41 PM
Cowboys's Avatar
Liked: 107
^^ For most folks here, I would say two for your room size but try one first to see if that's enough for YOU. If not, you can always add one more later with the same discount from buying two now.
Cowboys is offline
post #38 of 44 Old 08-13-2013, 06:08 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
and I would add the FV15HP with the HSU's...simply replacing them with a single FV15HP would not be enough for that room.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #39 of 44 Old 11-24-2014, 09:50 AM
Liked: 0
Cool
[QUOTE=Wonder if Brian would come to my house in Dallas to help measuring/setup? It is not the first time he came to his customer house and do that though.[/QUOTE]
I'm in Houston and wondering the same thing. Just ordered a full Mirage set up (OMD 28's, OMD C2, and OMD 5's in the rear) powered by a Denon X4000 - I'm considering the FV15HP for my set up.
cinhts is offline
post #40 of 44 Old 11-24-2014, 10:11 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
OP..........what other subs have you owned or heard in the past?
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #41 of 44 Old 01-01-2015, 01:04 PM
Siddhu's Avatar
Happy New Year folks.
I have two 15HP which used to rock my house . I just noticed that one of them is not giving any output . I have flipped the subs (heavy) and the problem persists.
So the issue is not with the cables or connectors etc. It is the sub. I see the green light at the back but no output at all. Has anyone experienced this before? I have contacted the company but wanted to quickly check if there is an easy solution. Any input will be appreciated.
Sid
Siddhu is offline
post #42 of 44 Old 02-13-2016, 09:36 PM
klepp0906's Avatar
Quoted: 49 Post(s)
Liked: 8
Originally Posted by mantaraydesign View Post
Quote:Originally Posted by eljaycanuck
You highlighted it, but you didn't read it carefully:
1. The second sub did not provide the expected gain. (He didn't say it provided no gain.)
2. The OP feels his room may be to blame. (His room, not every room everywhere.)
Your blanket interpretation that "dual subwoofers offer no improvement" is a far cry from what the OP actually wrote.
But you would think by having 2 subwoofers should Double the power of one subwoofer regardless of the room. It should not matter how your room is lay out or what you have in your room. If I am going to spend more money on a Dual Subwoofer setup, it better improve twice the power and sound quality.
Do you also have a Dual Subwoofer setup as well and how does it improve over one sub?
I guess his review did not motivate me enough to go out and get a Dual subwoofer setup.
My head hurts
klepp0906 is offline
post #43 of 44 Old 02-14-2016, 02:35 AM
Quoted: 311 Post(s)
Liked: 273
Sid
Happened the same thing to me once. Opened up the amp and found one of the sub wires had come off. That is understandable coz of the immense pressure inside the cabinet, so any loose connections are bound to come off.
I simply removed the wires from VC terminals and terminated them in the spring loaded ones. Also make sure both servo feedback and the main VC are properly hooked. Also, if the servo coil is disconnected from the amp, FV15HP won't work despite the amp showing green light.
Thin wires are for servo coil (silver spring loaded terminals) thick ones are for main VC (gold terminals).
post #44 of 44 Old 10-03-2016, 09:55 AM
kachua's Avatar
Originally Posted by eljaycanuck View Post
Great review!
I wonder if Brian would be willing to swing by my place if I were to buy a couple of FV15HPs from him...
I just want to know where did you get those CD/DVD rack?
You can choose your kicks, but you don't get to choose your kick-backs.
kachua is offline
Fv15hp Subwoofer
