Turning a wired subwoofer into wireless - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-16-2013, 08:27 AM - Thread Starter
zac851's Avatar
I just bought a sound bar for my living room. Just a little cheap Visio VSB-207BT. It has a subwoofer out connection on it. My TV is hanging on the wall and the Direct TV DVR is mounted under a small end table in the front of the room about 8 foot to the left of the TV. I ran HDMI through the wall over to the DVR a couple years ago and I REALLY dont want to fish another subwoofer cable through the wall again.
I was going to move my Klipsch SW-450 from my dedicated home theater room in the basement so I could get something better, and put the Klipsch in the living room. The living room is 20 x 18 with 14ft ceilings so hopefully the klipsch wont overpower the little bar.
Anyway, my question is does anyone make a wireless device that I would plug into the soundbars subwoofer port and then be able to hook a powered sub up somewhere else in the room to transmit the signal to it so I don't have to run a cable to it?
______________________________________
See my album for finished pictures.
zac851 is offline
post #2 of 4 Old 07-16-2013, 08:34 AM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
There's several wireless options. The cheapest is BestBuys Rocketfish wireless sub device. Runs about $69. A quick Google search will turn up plenty of options. I'd probably try the Rocketfish for the price.
crn3371 is offline
post #3 of 4 Old 07-16-2013, 08:53 AM - Thread Starter
zac851's Avatar
wow, didnt expect them to be that much. Guess I'll pick one up today and see how it works.
zac851 is offline
post #4 of 4 Old 07-16-2013, 08:59 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5212
they work well I have 2 of them
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
