Different sized drivers in a sub? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 07-19-2013, 06:23 AM
steve nn's Avatar
Liked: 433
Originally Posted by Bill Fitzmaurice View Post
I see nothing to be gained from that. It verges on voodoo engineering.
Ok.. Do you see how there might be any “disadvantage” from doing so (mixing differently tuned subs)
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 07-19-2013, 06:25 AM
Bill Fitzmaurice's Avatar
Liked: 4975
Trying to get the different phase and frequency responses to play nice would be a processing nightmare.
Bill Fitzmaurice is online now
Old 07-19-2013, 06:36 AM
oztech's Avatar
Liked: 101
Velodyne tried this some years back and dropped it in favor of their DD18.
oztech is offline
Old 07-19-2013, 06:43 AM
steve nn's Avatar
Liked: 433
Yes that has been my experience. I’m not saying it can’t be done! I still get blasted now and then for stating such though. It would be nice if those who state how wonderful it is, to actually be able to plot it out and see what they’re hearing and at what expense imo.
EDIT> Sorry to the OP for all the questions, but I feel the info contained relates to your original question.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 07-19-2013, 08:47 AM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 441
Originally Posted by braveheart123 View Post
You having gazillion drivers doesn't mean they sound as good as they may look.
No, taking your advice that a 10" is a better driver than an 18" would require a gazillion drivers. I only needed 6. rolleyes.gif
Considering I can play near reference, +- 3db's to almost the single digits; I'd say they sound as good as they look. cool.gif
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
Old 07-19-2013, 09:02 AM
Liked: 4975
Yes that has been my experience. I’m not saying it can’t be done! I still get blasted now and then for stating such though. .
It makes about as much engineering sense as putting a snow tire on one wheel of your car, a rain tire on another, a summer tire on the third and a racing slick on the fourth. The intent would be to have good performance in all road conditions, the result would be bad performance in any.
bass addict likes this.
Old 07-19-2013, 09:23 AM
steve nn's Avatar
Liked: 433
LOL.. Oh that's a perfect analogy that I can sink my head in. No beating around the bush! Thank you! Hope you don’t mind, but I’m going to use it in the future. I can quote if called for?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 07-19-2013, 09:40 AM
Liked: 4975
Quote away.
Old 07-19-2013, 10:42 AM - Thread Starter
tknx's Avatar
Quoted: 34 Post(s)
That is what I figured... Well, back to trying to decide how to maximize WAF, accuracy, and depth.
Denon X4300H | Salk Veracity ST | SVS SB13 Ultra | Neeo Remote (pending)
tknx is offline
Old 07-19-2013, 10:51 AM
steve nn's Avatar
Liked: 433
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 07-19-2013, 01:14 PM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Utterly inappropriate example strictly speaking in the context of two sub boxes both serving different pass bands and used within the same room. I did it a couple of years ago. One box (10" driver) was playing frequencies from 80Hz to 50Hz and another (12" Driver) playing 50Hz and below. I did that coz the right side of my room was offering great depth but very ruffled up upper bass; while the left side offered completely opposite. Hence the need for two separate boxes serving different pass bands.
Somewhat the same thing is very much possible within one enclosure housing two different size drivers in their own completely isolated enclosures within the same box. One can use an iNuke DSP amp for splitting the bands at DSP level and employ two channels of iNuke to serve separate compartments within the same box. One can be assigned to play upper bass while the other can handle the ULF.
Not a big deal.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
Old 07-19-2013, 01:30 PM
oztech's Avatar
Liked: 101
IMO the dips and peaks are room related so having two drivers in the same box does not address either but will add to db output hence the reason some rooms require two subs in different locations as some are finding out XT-32 is not a cure all.
oztech is offline
Old 07-19-2013, 02:55 PM
steve nn's Avatar
Liked: 433
I don’t get it! That’s not what he was addressing.. he was commenting on four differently tuned subs.. say like two 18Hz tuned subs playing along with two 25Hz tuned subs... Not splitting the bands/spectrum between the two.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 07-19-2013, 03:39 PM
Quoted: 311 Post(s)
Liked: 273
I know too little about sound design to answer this, but is there a reason sub designers don't use different sized woofers that roll-off to each other to keep things tight and optimized across the bass spectrum? Is it just too difficult to cross-over without significant artifacts? Seems like you would get tight upper bass with an 8-10" and get the deeper stuff with a 15" or something like that.
I was responding to the starting comments from the OP, so, it is very much doable if he wishes so. I just gave a re-engineered approach to the OP to address his concern.
No more from my side in this thread.
