Different sized drivers in a sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 07-18-2013, 12:48 PM - Thread Starter
tknx's Avatar
Quoted: 36 Post(s)
I know too little about sound design to answer this, but is there a reason sub designers don't use different sized woofers that roll-off to each other to keep things tight and optimized across the bass spectrum? Is it just too difficult to cross-over without significant artifacts? Seems like you would get tight upper bass with an 8-10" and get the deeper stuff with a 15" or something like that.
I suppose the other alternative may be line arrays with different parts of the array assigned to different spectrums. 1 8" for one part, 2 8"s for further down, etc.
Denon X4300H | Salk Veracity ST | Chane AR1X | SVS SB13 Ultra
tknx is offline
post #2 of 44 Old 07-18-2013, 01:09 PM
braveheart123's Avatar
Quoted: 330 Post(s)
Liked: 287
I think it is very much doable. I dIYed something on the same lines but it was with two separate boxes. One housing a 10 inch driver and another a 12 inch both serving different pass bands and the results were amazing.
I would like to hear from some more knowledgeable lads on this forum regarding one box housing two subs using internal passive xo doing handshake between a 10" driver for upper bass and maybe a 15" or an 18" serving the ULF.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #3 of 44 Old 07-18-2013, 01:46 PM
duc135's Avatar
Quoted: 162 Post(s)
Liked: 226
Bass "tightness" has nothing to do with driver size. A properly designed 21" sub driver is no less "tight sounding" than an 8" driver while playing within it's rated frequencies with the proper power behind it. Actually, it can be argued that the opposite would be true since the larger driver would have to move considerably less than the smaller driver to produce the same frequency at the same dB.
Mixing sub drivers in a single enclosure is not done because each driver has different T/S parameters which determine the box size and tuning in the case of ported, bandpass or horn loaded enclosures. You cannot simple throw two different drivers in a box and hope that crossovers give you a good response. The best you can do with multiple drivers sharing a common enclosure is to use the exact same drivers. Even two same sized drivers from different manufacturers or even the same manufacturer, but different models will not work. The only way to use multiple drivers in "one" enclosure is to separate the drivers from each other. Essentially you are building two separate boxes that share a common wall. Think of it like an apartment building. Two separate apartments sharing a common wall. Each does its own thing independent of the other. At that point you might as well build two individual boxes to take advantage of room modes.
Again, best thing to do is get a properly designed driver in the size and specifications you need and build a subwoofer enclosure around it. I can tell you my 18" LMS has a lot "tighter" bass than my cousin's 8" Pioneer. wink.gif
duc135 is offline
post #4 of 44 Old 07-18-2013, 02:00 PM
Quoted: 330 Post(s)
Liked: 287
IMO the moving mass of an 18" cone is heavier than that of a 10" driver. A 10" driver will play the 80hz frequency quicker than an 18" driver keeping the input wattage equal.
post #5 of 44 Old 07-18-2013, 02:16 PM
steve nn's Avatar
Liked: 433
That's not what he said.. Might want to re-read, look for accordingly.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #6 of 44 Old 07-18-2013, 02:40 PM
Quoted: 330 Post(s)
Liked: 287
I think in a way it is the same thing. A 10" driver with lighter moving mass can be snappier at picking up recursive 80hz bass notes half a second apart than an 18" driver with heavier moving mass. The result is tight bass.
post #7 of 44 Old 07-18-2013, 03:01 PM
steve nn's Avatar
Liked: 433
I don’t agree, we have seen this conversation over in DIY more than a few times. In my experience I have not noticed such and find the larger good drivers every bit as tight as a 10”. I equate it to design more than anything. I do hear what your saying though.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #8 of 44 Old 07-18-2013, 03:46 PM
Quoted: 330 Post(s)
Liked: 287
I don’t agree
That's what this forum is all about.....arrive at an agreement after a lot of disagreements.
post #9 of 44 Old 07-18-2013, 04:24 PM
Bill Fitzmaurice's Avatar
Liked: 5625
Nope. It seems logical, but it simply is not the case.
Also logical to assume that might be the case, but it isn't.
In this case agreement or disagreement are moot, this is physics, very well known physics at that, and drivers simply do not behave that way.
steve nn likes this.
Bill Fitzmaurice is online now
post #10 of 44 Old 07-18-2013, 05:35 PM
steve nn's Avatar
Liked: 433
No not to me but if that's why you come here so-be-it!
I’m glad to see Bill step in, he has a way of correcting me from time to time also. wink.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #11 of 44 Old 07-18-2013, 06:50 PM - Thread Starter
tknx's Avatar
Quoted: 36 Post(s)
So, skipping the "faster" discussion - what about using an array of subwoofers with different optimizations and roll-offs? Not that I have space for 4 subs or anything, but really just curious.
tknx is offline
post #12 of 44 Old 07-18-2013, 06:57 PM
bass addict's Avatar
Quoted: 366 Post(s)
Liked: 442
LOL. Agreed.
It's amazing how long certain urban myths can hang around without being dispelled. I should have gone with 20 10" drivers instead of my 6 18's. What was I thinking? cool.gif
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #13 of 44 Old 07-18-2013, 07:04 PM
sivadselim's Avatar
Quoted: 248 Post(s)
Liked: 216
Velodyne 1812
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #14 of 44 Old 07-18-2013, 07:13 PM
duc135's Avatar
Quoted: 162 Post(s)
Liked: 226
As Bill has stated, cone weight has nothing to do with it if the drivers are designed properly. A properly built 18" driver will have a motor capable of moving the cone at the required speed to produce the frequency it is given. Cone speed is a based on two factors, frequency and SPL. SPL is based on the amount of air the driver can move. An 18" driver will need to move considerably less to create the same SPL as a 10" driver at the same frequency. Look at it this way. I (18" driver) have to run 10' and back twenty times in one minute while you (10" driver) have to run 100' twenty times in one minute. Who needs to run faster?
Wattage has nothing to do with how fast a driver moves. Wattage affects how loud a driver will play given the enclosure and sensitivity of the driver. The driver will draw as much wattage as it needs to play the frequency at the SPL you set. If the amp cannot produce sufficient wattage then it will clip and the sub will not get any louder. Distortion not considered. Lets say all things being equal that a 10" driver has the same sensitivity as an 18" driver and their response curves are all the same. Now take the same wattage applied to both speakers you will see that the 10" driver will move much faster than the 18" driver. That's because the 10" driver has to move in and out a much greater distance than the 18" driver to produce the same SPL.
duc135 is offline
post #15 of 44 Old 07-18-2013, 07:27 PM
duc135's Avatar
Quoted: 162 Post(s)
Liked: 226
Originally Posted by sivadselim View Post
Velodyne 1812
Nice. If I had $15K in 2004 dollars with nothing better to use it for I might give it a try. Then again, I might need more than that because my old house might need the floors reinforced to support that beast. For now, my two 18"s and soon to be added four 15"s will suffice for the time being. Hopefully.
duc135 is offline
post #16 of 44 Old 07-18-2013, 07:46 PM
steve nn's Avatar
Liked: 433
LOL. Agreed.
Now now! I notice from your post count that your new around here. We get off track all the time but we always seem to make it back to the subject at hand. I would give you my opinion regarding your question but I don’t want to. It’s going to start a big argument that I don’t feel like getting into. smile.gif There are many on both sides just like sealed v vented.
(imo) Very nice explanation duc!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #17 of 44 Old 07-18-2013, 08:14 PM
Liked: 5625
Subwoofers have too small of a pass band for that to be of any advantage.
post #18 of 44 Old 07-18-2013, 08:42 PM
steve nn's Avatar
Liked: 433
If you make it back.. Do you perceive or know there to be any disadvantage?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #19 of 44 Old 07-18-2013, 09:38 PM
Quoted: 330 Post(s)
Liked: 287
BFM enlighten me with the Physics involved.
post #20 of 44 Old 07-18-2013, 09:41 PM
Quoted: 330 Post(s)
Liked: 287
Stand up for yourself. Why do you need Bill all the time to fill in the blanks for you?
post #21 of 44 Old 07-18-2013, 10:28 PM
Quoted: 330 Post(s)
Liked: 287
If you know something, best explain it than to create another urban myth. You having gazillion drivers doesn't mean they sound as good as they may look.
post #22 of 44 Old 07-18-2013, 10:46 PM
duc135's Avatar
Quoted: 162 Post(s)
Liked: 226
In very simplified terms, frequency is measured in cycles per second. A 20Hz frequency is 20 cycles per second. This means to produce a 20 Hz tone, a speaker must move in and out 20 times per second regardless of driver size. No more, no less. Anything other than 20 cycles per second then it is no longer producing a 20Hz tone. This means at 20Hz, a 21" driver is moves in and out 20 times per second. Same thing for the 8" driver. That is why driver size in itself has no bearing on the "tightness" or "speed" of the bass.
What determines the tightness of the perceived "tightness" is a combination of things like decay and secondary reflections of the sound waves. Decay is a function of how well the motor can control the movement of the cone as well as other things like enclosure design. Motor control of the cone is not dependent on the size of the cone, but the strength of the motor relative to the mass of the cone. Note I say mass and not size and I said the motor strength relative to that mass. As an analogy, consider me, a fairly fit person who can easily move around a 20lbs. weight with ease. I can move the weight around with control and stop and start it's motion with ease on command. Now take a five year old and ask him/her to move around a 10lbs. weight. Even though it is obviously lighter weight, the five year old will have trouble moving that 10lbs. weight around than I would with the 20lbs. weight. Speaker drivers operate in a very similar fashion in this respect.
I'm not Bill and I don't know the equations off the top of my head, but I'm sure they can be found online if you do a search for them.
duc135 is offline
post #23 of 44 Old 07-18-2013, 11:09 PM
steve nn's Avatar
Liked: 433
Mmm!.. I never have heard that said of me?.. all the time huh? Are you sure you’re not on the defensive for some reason? Anyway like said there has been a few times he has corrected me but never has backed me up. No I asked him the question (Do you perceive or know there to be any disadvantage?) regarding mixing SW's because I know he designs speakers and subwoofers and sometimes it’s best to listen rather than spout. Opinions, to a degree, are not what I’m looking for as I come to my final conclusion regarding the question asked. If my experience coupled with my opinion doesn't correlate with the physics involved, then I want to know.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #24 of 44 Old 07-18-2013, 11:30 PM
Quoted: 330 Post(s)
Liked: 287
So do I. Um not being defensive or offensive; just being logical. Whatever I'm saying is logical and does make sense; but according to more knowledgeable ppl on this forum I am wrong. That is perfectly fine, but leaving it open-ended and coming up things with things like "Urban Myth" or "It's Physics" and other crap and not explaining creates other so-called "Urban Myths".
post #25 of 44 Old 07-18-2013, 11:46 PM
steve nn's Avatar
Liked: 433
If I could explain the physics in my posts I certainly would if called for, in all truth it’s beyond me. So I like to have them backed up and then explain to others in a manner like duc when it comes up. This mixing differently tuned subs thing has been coming up a long time, so I too wanted to rest the case in my mind regarding. I know what I think I know, but is it really so?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #26 of 44 Old 07-19-2013, 12:35 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
I think a case might be able to be made for a two way subwoofer system, but not two different subs in one enclosure. For instance, the massive drivers that have great deep bass output like the RE XXX and the LMS Ultra are real energy hogs, and are relatively inefficient at upper bass frequencies. Other lighter drivers are very efficient at upper bass but you would not want them to go for lower bass. Also, as Hsu argues for its MBM-12, the subwoofer locations in a room that work that work great for deep bass can sometimes leave massive gaps in mid and upper bass frequencies, and vice versa, so two subs tackling different frequency ranges can work with the room and not against it. Furthermore, the narrower of a frequency band an amplifier has to deal with, the more headroom it has overall, since the amplified signal isn't being inflated by a other frequencies.
shadyJ is offline
post #27 of 44 Old 07-19-2013, 12:58 AM
steve nn's Avatar
Liked: 433
Thats not what I was alluding to though. You're referring to a mid bass mod. That’s a whole different subject/can of worms. wink.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #28 of 44 Old 07-19-2013, 05:06 AM
Liked: 5625
The reason for using different size drivers in a system is dispersion, as that's the only factor that is determined by driver size alone. Dispersion is inversely proportional to the size of the radiating surface. In order to keep the angle of dispersion sufficiently wide as frequency goes higher and wavelengths grow shorter the radiating surface must be made smaller. That's the main reason why midranges are smaller than woofers, and tweeters are smaller than midranges. You can make a twelve inch driver that has useful axial response to 5kHz, but off-axis it's only going to be good to perhaps 1.5kHz at best.
Within the subwoofer pass band the wavelengths are far too long for the driver size to influence dispersion; even a 21 inch driver will have a 360 degree pattern to well above 100Hz. That means there's nothing to be gained by using different size drivers within the sub woofer pass band that justifies the added complexity involved.
post #29 of 44 Old 07-19-2013, 06:00 AM
steve nn's Avatar
Liked: 433
Thanks Bill... Might you comment on using differently tuned subs in the same room at the same time and a sealed SW mixed with a vented SW in the same room, same time. This is what I was asking about.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #30 of 44 Old 07-19-2013, 06:11 AM
Liked: 5625
I see nothing to be gained from that. It verges on voodoo engineering.
