Help me decide: SVS PC-13 Ultra or SVS PB-13 Ultra - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 40 Old 07-18-2013, 07:17 PM - Thread Starter
Manzola's Avatar
I know this has been brought up several times in a few threads but I specifically want to know if the space I am working with will lend better to one or the other design ( in regards to sound properties vs. sub footprint).
A few things I am hoping to do:
1. Minimize reflection ( inherent due to concrete floor/ceiling + floor to ceiling windows). I can't apply room treatment and I know it's literally the worst acoustically speaking, but I would like opinion on whether the down-firing cylinder perhaps is better than the front firing for this type of space
2. Optimize for the space but have room for the future- basically which one is the most flexible for future spaces?
3. Which one will play best with my CM9s and Pioneer Elite SC-67
4. Are there truly any strange wind noises (waffling?) from the ports more likely with the cylinder vs. box?
Aesthetically speaking I like them both, so really this is more about maximizing value in regards to performance.
In the pictures below you can all see where they would likely go- probably behind the couch or in that corner near the column...or perhaps by the window on the center between couch and speakers ( I'm really not sure what would be acoustically best) . Thanks in advance!!
Manzola is offline
post #2 of 40 Old 07-18-2013, 07:26 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Without going into a diatribe.
Either will work fine
Don't know what your future space will be. Either is a small footprint and work fine almost anywhere. Some like cylinders and some like boxes. Personal preference.
Either
No
Thanks in advance!!
Manzola, Valtyr and knappkd like this.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 40 Old 07-18-2013, 07:47 PM
Kini62's Avatar
Quoted: 1410 Post(s)
Liked: 1293
The PC would be much more placement friendly IMO. The PB 13 Ultra is a pretty big box. Another benefit to the cylinder is that you can lay it on its side too. Maybe lay right behind the sofa?
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #4 of 40 Old 07-18-2013, 07:50 PM
Quoted: 360 Post(s)
Liked: 437
I miss my pair of 16-46's I had back in the day. Those bad boys dug deep.
post #5 of 40 Old 07-18-2013, 07:59 PM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
I agree addict! They did dig deep and was my first wow ever with true bass.
Marantz 7702 Atmos
MKtheater is offline
post #6 of 40 Old 07-18-2013, 08:21 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5201
ya I really like the pc13 and its priced better than the pb. I believe svs has a b-stock for 1599.00
ttn333 likes this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #7 of 40 Old 07-18-2013, 09:53 PM - Thread Starter
Manzola's Avatar
I have been mainly afraid that the cylinder would suffer on the concrete ( this may be baseless )- And potentially that the fabric finish might be more fragile and prone to wear?
Otherwise I have been leaning towards the PC13 since it's just so odd looking....but the conservative in me says go for something tried and true?
Manzola is offline
post #8 of 40 Old 07-18-2013, 10:28 PM
Quoted: 360 Post(s)
Liked: 437
Trust me when I say the cylinder design has been around as long, if not longer, than the cube. As MK mentioned, the 16-46's (cylinder subs) were also my first introduction to true clean bass. That was over 10 years ago.
The fabric finish is actually more resilient than the other finishes can be. I've had fabric, black wrinkle, and real wood; and the fabric actually held up the best. It's not like you should be putting any of them through the torture test, but accidents do happen.
post #9 of 40 Old 07-19-2013, 02:31 AM
maxht's Avatar
The PB13-Ultra will be quite an eyesore in your space as it is really big. I would place the PC13-Ultra at the back corner (right LP) to take advantage of room gain since there isn't any space in front.
Bass, please. Shaken, not stirred.
maxht is offline
post #10 of 40 Old 07-19-2013, 07:35 AM - Thread Starter
Manzola's Avatar
Well after some serious personal deliberation, at least 5+ hours of research and two calls with SVS I decided to place the order for the PC13-Ultra. I'm super excited and agree this will likely be more practical. I just hope it works as advertised and can be felt 5-10 floors down.
Thanks to everyone for helping me make up my mind!
Manzola is offline
post #11 of 40 Old 07-19-2013, 08:14 AM
steve nn's Avatar
Liked: 433
No need to worry about the fabric at all. It’s very durable, more so than the other options imo. It’s also a very easy unit to move around compared to the box style.
LOL.. You have a great sub on the way, enjoy and Congrats!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #12 of 40 Old 07-19-2013, 09:35 AM
spyboy's Avatar
Liked: 47
Just don't get a cat. I wonder if SVS can provide a replacement sock if yours ended up mutilated by a cat?
I am using an SVS 20-39 PCi and the sock has not been a problem.
spyboy is offline
post #13 of 40 Old 07-19-2013, 10:58 AM
Lecter83's Avatar
Liked: 41
I tested both models.
The PB13-Ultra has a larger cabinet, which gives you an advantage in the 20Hz 15Hz range of about 1.5 dB more.
In the rest, in terms of output are identical and more than audible, measurable serious.
The PC13 has the driver closer to the ground and this may enhance the modal response in the room, causing the subwoofer in certain frequencies sound more violent.
In absolute terms the two are similar in the PB13 music has a cleaner trace (subjectively speaking). The picture is much nicer and in turn imposing.
In your case, if I tubiera space, would go no doubt by the PB13.
Lecter83 is offline
post #14 of 40 Old 07-20-2013, 01:39 PM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
I have a pb-13 ultra behind my couch and it works amazing. (also have two pb12+ behind the screen) svs behind couch.jpg 172k .jpg file
Name:	svs behind couch.jpg
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #15 of 40 Old 07-20-2013, 01:58 PM - Thread Starter
Manzola's Avatar
That's what I was likely going to do but opted to buy the pc-13 after I took some measuring tape and realized I would have to jump over it every time I wanted to shut my blinds.
I know this is totally off-topic but I'm curious....you mention you have the smaller subs behind the screen and one pb13 ultra in the back, does this not cause some kind of strange bass delay phenomenon since the pb12 are presumably faster than the larger pb13?
I always thought you had to match size/brand subs when doing a multi-sub setup.
Manzola is offline
post #16 of 40 Old 07-20-2013, 03:26 PM
Quoted: 142 Post(s)
Liked: 730
All three are tuned to 20hz and i did adjust the phase a bit on the back sub. I use a sms-1 eq so can see on screen what the room response is (to lower small peaks and to adjust phase for dips). The two subs are really close in terms of brand,amp type and of course the sub design is the same. The 13 has way more output but both models are pretty much the same sub. So imo they work great together. I could probably sell the two pb12+s and be very happy with just the 13 (wish i would have bought the 13 first lol). Congrats on your new sub im sure you will love it biggrin.gif
post #17 of 40 Old 07-31-2013, 11:33 PM - Thread Starter
Manzola's Avatar
Update: Got the PC-13 Ultra two weeks ago and it bojangled my mind with power only known to the gods of Mt. Olympus.
However, it arrived damaged from shipping. The baseplate was cracked and the amp would shut off after a few seconds. This continued for a couple hours then I gave up. A couple days I tried it out again and it worked, so I got to play around with it for a day before the replacement arrived. Let me just say the SVS guys have been just amazing with the whole ordeal, and really it's FedEx's fault because it arrived with a massive hole on the side of the box.
The second one was a charm and seriously scared me with the amount of power it drives....however I found a wee bit problem as a result of that...which is that my concrete (slightly uneven in places) floor is incompatible with the sub platform. At high volume the sub actually walks about a foot to the left, as a consequence I can hear the rattling as it lifts off the ground and starts to walk.
Disclaimer: I have polished concrete floor and I tend to have a bass bias on my setup ( read: I'm only satisfied if you can feel it 5 floors down).
As a result, I'm likely going to exchange it for the pb-13 ultra since that weighs about 155lbs...which should resolve the walking issue.
Other than that, this is an awesome sub and I really wanted to keep it since everyone now asks WTF is that large round thing in your living room, watching their jaws drop as they discover it's a sub is my ultimate satisfaction.
Manzola is offline
post #18 of 40 Old 08-01-2013, 12:33 PM
Ed Mullen's Avatar
Quoted: 80 Post(s)
Liked: 268
A small piece of carpeting under the subwoofer or an Auralex SubDude will help with the walking issue.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #19 of 40 Old 08-01-2013, 05:44 PM
Bill Fitzmaurice's Avatar
Liked: 4628
Or a piece of this, cut to size:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=202015909&R=202015909#.UP66YGeYUYc
But I can't imagine a polished concrete floor sounds good in the mids and highs, unless there's a lot of rug covering it.
Bill Fitzmaurice is online now
post #20 of 40 Old 08-02-2013, 01:11 AM - Thread Starter
Manzola's Avatar
Going to head to home depot and give it a try, as far as the sound....you are correct there is tons of reflection + room gain from the concrete. It's less than ideal but I will be moving next year hopefully can get a better room setup.
I really had to experiment with dozens of settings to make it sound decent.
Manzola is offline
post #21 of 40 Old 08-02-2013, 01:26 AM
cjvnyc's Avatar
Liked: 31
Dude, do you have downstairs neighbors? Beautiful apartment, by the way.
cjvnyc is offline
post #22 of 40 Old 08-03-2013, 11:38 AM - Thread Starter
Manzola's Avatar
I live on the 10th floor of a high rise but there is 9 inches of concrete that separates our floors. I'm sure they can still hear some of it, but I have not once in 4 years of living here heard anything from a neighbor with the exception of...high heels, imagine that.
And thanks! Chicago is a beautiful...but cold city.
Manzola is offline
post #23 of 40 Old 08-14-2013, 03:33 AM
maxht's Avatar
Manzola, how's the progress of your settings?
maxht is offline
post #24 of 40 Old 08-14-2013, 08:54 AM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
eek.gif Don't say that. I'm getting ready to replace my 16-46PC+ that I've enjoyed for over 10 years. Hope I'm not making a mistake.
Fortunately none of my 3 cats ever paid any attention to my cylinder sub.
Saturn94 is offline
post #25 of 40 Old 08-14-2013, 01:50 PM - Thread Starter
Manzola's Avatar
I have been trying out the sub with a carpet underneath it for the last week. I watched War of the Worlds (in the name of bass, because really this movie is so bad it was misery) and unfortunately it still hops a tiny bit- which manifests itself in a rattling noise that's just not going to do it for me.
Ultimately I keep changing my mind daily whether to try something else or just exchange it for the PB-13 Ultra while I'm under the trial period... I will probably end up exchanging since the 155 lbs of the PB-13 Ultra is basically guarantee to make it sit still under any load without modification.
Manzola is offline
post #26 of 40 Old 08-14-2013, 06:50 PM
GLBright's Avatar
Quoted: 64 Post(s)
Liked: 84
Are you referring to the temperature or the populace?
HT: Onkyo TX-SR702,Infinity IL60s/IL36c,LG PF1500,Draper92"screen,SonyBDP-S570,Dish622
Stereo1 Denon PMA-630 amp,TechnicsSL-1300TT,ToshibaSD-4960 uni-player,Infinity Overture 3s
Stereo 2 OnkyoTX-8222,HitachiHT-61S TT,YamahaDV-S586 uni-player,Large Advents (1972)
GLBright is offline
post #27 of 40 Old 08-15-2013, 03:21 AM
maxht's Avatar
I wonder whether the Auralex Subdude will be able to solve your problem.
The PB13-Ultra will surely stay at its spot. Mine never move an inch. If it does, I am surprise eek.gif
maxht is offline
post #28 of 40 Old 08-15-2013, 04:06 AM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
Make some subwoofer risers for less than the cost of the subdue and then you can make them fit you décor. It may improve the sound of the bass in the room and can act as a bass trap. If nothing else, it will sure make life easier moving the subs around.
derrickdj1 is offline
post #29 of 40 Old 08-15-2013, 08:03 AM
steve nn's Avatar
Liked: 433
I'm very surprised the old rug trick didn't work. It seems like you ought to be able to come up with something that's a easy fix. How thick was the carpet?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #30 of 40 Old 08-15-2013, 03:51 PM
Kini62's Avatar
Liked: 1293
Something like a tile of foam "gym" floor would work, i think.
Def Tech SC8000
Kini62 is offline
Svs Pb13 Ultra
