Dayton sub 1200 vs 2 Yamaha YST-SW216 subs for music? - AVS Forum | Home Theater Discussions And Reviews
Old 07-20-2013, 06:26 PM - Thread Starter
tf3090's Avatar
I currently have two tower speakers (I think they have either 8" or 10" woofers included) and they sound nice, but they can't quite play as low as I want. I will be putting this system in a small space (college dorm room) and it will be used exclusively for music; I listen primarily to EDM and hip hop, so lots of bass heavy music. I'm not very picky about quality, the music I listen doesn't really require much accuracy; I'm more interested in loud, floor shaking bass.
I made a thread a few days ago and think I have pretty much decided on the Dayton Sub 1200 for $129 shipped (here http://www.amazon.com/Dayton-Audio-SUB-1200-Powered-Subwoofer/dp/B00669L3HS/ref=sr_1_1?ie=UTF8&qid=1374366124&sr=8-1&keywords=dayton+sub+1200)
However, I came across this on craigslist and was wondering if it was any better of a deal. http://siouxcity.craigslist.org/ele/3924582447.html
It's two yamaha yst-sw216 subs, as seen on amazon here: http://www.amazon.com/Yamaha-YST-SW216BL-Subwoofer/dp/B000FJ89UO
I could probably get the pair for like $70. I was just wondering how these would compare to the single dayton sub 1200 in terms of output? The dayton has 20% more power than the pair of yamaha's, but the pair of yamaha's would have more cone area. Not sure which would be the better deal for someone looking for a lot of bass for a small area like a college dorm.
Also, I won't be using it for watching movies or anything, so home theater use is irrelevant in this scenario.
tf3090 is offline
Old 07-21-2013, 12:00 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Those Yamahas are a complete joke. The Dayton will easily smoke the pair.
Jay1 is offline
Old 07-21-2013, 08:42 AM - Thread Starter
tf3090's Avatar
Fair enough, i think after all ive read, I've decided on the dayton 1200
I feel like it will have some pretty solid output in my small room
tf3090 is offline
Old 07-21-2013, 08:49 AM
Kevin Taylor's Avatar
I have the dayton sub 1200, and it shook half my house until i put plywood under it.
Kevin Taylor is offline
Old 07-21-2013, 09:36 AM - Thread Starter
tf3090's Avatar
I like the sound of that lol
What does the plywood do? Help less of the bass get absorbed by the floor it's sitting on?
tf3090 is offline
Old 07-21-2013, 09:53 AM
Yeah, when i had it on just carpet, the bass hit the floor and everything rattled, now with the plywood i can get everything to rattle, but the walls in the room adjacent to me no longer rattle (which is what i needed), and the bass sounds punchier/better
Old 07-21-2013, 11:24 AM
Bill Fitzmaurice's Avatar
Liked: 4628
Putting plywood under the cab will have absolutely no effect on the low bass frequencies. It will serve as a reflective surface for midbass frequencies, and by having those reflect into the room rather than being absorbed by the carpet the subjective result can be that the sub sounds louder in the room, especially where 'punch' is concerned, as that is sourced in the midbass, not the low bass. That might allow you to turn it down without having it seem to be at a lower volume, which could reduce pass through to other rooms. I know what it is that you think you're hearing, but only by taking in-room response measurements both ways can you actually know what you're hearing.
Bill Fitzmaurice is online now
Old 07-21-2013, 12:16 PM
hmm i didn't know about this, does the way i have it setup in any way lower the bass quality?
Old 07-21-2013, 01:19 PM
Liked: 4628
It doesn't affect the low bass at all, so if you like the way it sounds better with the plywood than without leave it there. However, I mistakenly assumed that you had a downfiring sub, which would explain why it sounds different with plywood beneath it. But the 1200 isn't downfiring, so it shouldn't have any effect, other than placebo effect. Again, the only way to really know what's going on, if anything, is by measuring the response both ways.
Old 07-21-2013, 07:18 PM
"This powered sub features a bottom-firing, flared port, bass reflex design for reduced port noise and increased bass response. It also utilizes a long-throw 12" woofer and up to 120 watts of house-shaking power."
description from dayton. i believe its downfiring.
Old 07-21-2013, 07:58 PM
Liked: 4628
I'm just going by the picture, which shows a forward firing driver.
Old 07-21-2013, 09:18 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Port is downfiring, driver is forward firing.
kiwi2 is offline
Old 07-22-2013, 06:26 AM
Liked: 4628
That being the case the plywood shouldn't do much, if anything, as the only frequencies radiated by the port are very low frequencies with wavelengths too long to be affected by the density of what lies beneath. However, one added factor is the distance between the port exit and the floor, which will have an effect on the tuning of the sub. Resting on plywood the feet won't sink in as they will on carpet. You actually can fine tune the response of down firing subs, be it the driver or port that down fires, by adjusting the height of the cab off the floor. But doing so requires measuring the response to see the effect, otherwise it's pure trial and error.
Yamaha Yst Sw216bl Subwoofer
