Sub to Compliment my HT - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 80 Old 08-24-2013, 05:48 AM
steve nn's Avatar
Liked: 433
Originally Posted by mijotter View Post
Any idea on where to purchase the Rythmik LV12 and how much it is?
Rythmik> http://www.rythmikaudio.com/LV12R.html
I also know of a good second hand one bought by a respected member here on the forum that he did a review on that is up for sale if interested? It’s practically new.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #62 of 80 Old 08-24-2013, 01:25 PM - Thread Starter
mijotter's Avatar
Liked: 59
What do you mean second hand?
And yes I'd be itnerested.
mijotter is offline
post #63 of 80 Old 08-24-2013, 02:49 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5266
It means the sub was unboxed, setup, reviewed, put back into the box, and is now for sale. smile.gif
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #64 of 80 Old 08-24-2013, 10:07 PM - Thread Starter
mijotter's Avatar
Liked: 59
Oh ok excellent and thank you.
Steve nn i'm definately interested.
Also, where is a good place to set the crossover frequency for the sub? Anything below 80 is handled by the sub or lower like 65?
mijotter is offline
post #65 of 80 Old 08-25-2013, 05:06 AM
steve nn's Avatar
Liked: 433
I will ask him to PM you, you should hear from him today.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #66 of 80 Old 09-10-2013, 03:41 PM - Thread Starter
mijotter's Avatar
Liked: 59
How is the Rhythmik LV12R compared to the Klipsch 12D. Did I upgrade significantly? By upgrade I mean I was going to purchase a 12D but can't find them for what I want to pay for it so I got the LV12R and boy is it a beast. Haven't listened to it yet.
mijotter is offline
post #67 of 80 Old 09-10-2013, 03:57 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5266
It should be a significant upgrade from the 12d.
post #68 of 80 Old 09-28-2013, 10:57 AM - Thread Starter
mijotter's Avatar
Liked: 59
Is there a general rule when it comes to sub placement as far as distance from the walls and other items?
Also, my Right speaker as of right now is about 6 inches to the right of the subwoofer, is this acceptable?
mijotter is offline
post #69 of 80 Old 09-29-2013, 01:36 AM - Thread Starter
mijotter's Avatar
Liked: 59
Anyone?
mijotter is offline
post #70 of 80 Old 09-29-2013, 02:22 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
There is no rule, but corner loading (1/8 space) yields extra spl (3-6dB) depending on room. But there is no free lunch. It also yields boomy response centred around the passband where it is peaky. Place your sub where ever it sounds best and blends well with mains.
Every room has some sort of pressure zone that you can exploit to your best. If you can find that spot the sub would be best suited there to excite room modes. Such spots are along the longest walls, corners, near-field (behind listening position or left/right of listening position). Near field must not be in null. Same goes for your listening position.
Experiment and try different spots.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #71 of 80 Old 09-29-2013, 05:30 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
Jotter, also note that the graphs posted earlier may not have any meaning at all. Subwoofers are affected a lot by the room in which they are placed and even where in the room they are placed. Room gain is the term that is used to describe the phenomenon. All subwoofers will go lower and louder in a room than they will in an anechoic chamber. The only meaningful way to compare subs with graphs is to use either the predicted performance parameters or those measured in an anechoic chamber. As soon as you put a sub in a room and fire it up, all bets are off.
FMW is offline
post #72 of 80 Old 09-29-2013, 04:09 PM
LastButNotLeast's Avatar
Quoted: 1488 Post(s)
Liked: 1088
LastButNotLeast is offline
post #73 of 80 Old 11-01-2013, 01:31 PM - Thread Starter
mijotter's Avatar
Liked: 59
What do you guys use to measure the bass output? Looking to get an accurate measurement from my sub but don't want to spend a ton of money on a meter. Thanks.
mijotter is offline
post #74 of 80 Old 11-01-2013, 04:51 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5266
Go to Cross Spectrum Labs and pick up a UMIK-1 or UMM-6 mic for 80.00.
post #75 of 80 Old 11-02-2013, 10:23 AM
SaviorMachine's Avatar
Liked: 90
Is one better than the other? Is there a reason to choose either one?
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #76 of 80 Old 11-02-2013, 10:35 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
I'm not expert on this, but the UMM-6 also requires a sound interface to plug into. If I'm not mistaken, as a USB mic, the UMIK should be all one would need.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #77 of 80 Old 11-02-2013, 10:46 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5266
The UMM-6 requires nothing but a usb cable. The only difference is the UMIK-1 does not need a seperate spl meter to calibrate REW to the mic. Both are great mics and some prefer the UMM-6 and vice versa.
post #78 of 80 Old 11-02-2013, 11:04 PM
cel4145's Avatar
Liked: 2991
cel4145 is offline
post #79 of 80 Old 11-03-2013, 12:54 AM - Thread Starter
mijotter's Avatar
Liked: 59
If I order one will it come with an instruction manual? Never dabbled in this before.
mijotter is offline
post #80 of 80 Old 11-05-2013, 08:02 AM
Liked: 1088
The only manual you need is here:
post #275
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Onkyo Tx Nr809 , Panasonic Ptae8000u Hd Projector , Klipsch Rw 12d 12 Subwoofer Each
