NOT trying to troll: Anyone else have big issues with ear pain? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-25-2013, 07:50 AM - Thread Starter
cjvnyc's Avatar
Liked: 31
I have a decent sized listening room (12 x 24 x 8), hardwood floors, plaster walls, listening couches in center of room. I bought 2 12" subs, decent manufacturer (PA), listening volumes not extreme. But my eardrums would start to throb, seemingly more from the amount of air the subs were pushing than the frequencies themselves. Moving them around the room did not help. I'm wondering if any others have had this problem and if there were any workarounds that worked. I tried changing the cutoff frequencies but perhaps I didn't try the right approach. Again, please don't interpret this as trolling. There is an entire octave or more that a string bass can play and I can enjoy that my front speakers cannot render- I'd like to find the solution.
cjvnyc is offline
post #2 of 9 Old 07-25-2013, 11:14 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
Have you "EQ'd" the system?
Do you have an AVR doing any processing to the sound?
It sounds like you may have some room nodes at play, creating boomy peaks where standing waves occur.
If you walk round the room when it's playing a consistent bass note or beat, does the bass get louder and quieter as you walk round?
MemX is offline
post #3 of 9 Old 07-26-2013, 11:37 AM
stangdriverdoug's Avatar
My suggestion would be to move the subs around to different locations to see if the problem goes away. Maybe moving them one a week. you'll be surprised at how different it will sound once you start moving them.
stangdriverdoug is offline
post #4 of 9 Old 07-26-2013, 01:14 PM
JWL-Realtraps's Avatar
Agreed, problems like that can definitely be rooted in acoustics. Do you have any bass traps in the room? Those will level out any peaks that might be causing the weird resonance in your ears.
These articles might help:
http://realtraps.com/art_basics.htm
http://realtraps.com/art_room-setup.htm
http://www.realtraps.com/art_sub-placement.htm
JWL-Realtraps is offline
post #5 of 9 Old 07-26-2013, 09:48 PM
ryanb650's Avatar
He mentioned that he has tried moving them around already and it didn't help...
ryanb650 is offline
post #6 of 9 Old 07-27-2013, 02:41 AM
NWCgrad's Avatar
Quoted: 1229 Post(s)
Liked: 1221
JapanDave reported a similar sensation, its documented somewhere in the diy speaker section under his sub build thread. I believe his was due to the amplifiers and not the actual subs. Perhaps the class D amp (?) in the subs is causing a similar issue.
NWCgrad is offline
post #7 of 9 Old 07-27-2013, 04:32 AM - Thread Starter
cjvnyc's Avatar
Liked: 31
Let me thank all of you for taking the time to help here. My listening room is my living room, and due to a fireplace and openings there are only two choices for the subs, front or rear corners along the short-sided walls (listening chairs face the long direction). I just read the thread by JapanDave and my situation is on low frequencies and is a throbbing, not a "ringing". I believe the amps/electronics is worth exploring, although I've never experienced the pain with the subs powered on but no music playing. And I can listen to music at high volumes without the subs playing (my mains are passive, of course). So its somehow the low frequency sounds/hums. The "standing wave" thought seems credible. Alas- can't buy a new house over this. Again, thanks to all of you for taking the time here.
cjvnyc is offline
post #8 of 9 Old 07-27-2013, 12:29 PM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
It is the reverb characteristics of the system/room. I cut my sub around 6 dbs for some music which control it very well. That bass hit can be annoying and may lead to hearing loss. I know we read so much about trying to get all the bass from the subs on this and other forums but more is not better all the time. Cut the dbs in the avr's since It can be moved back up with the remote easily. I don't rum my bass hot for music and only sometimes with movies..
derrickdj1 is offline
post #9 of 9 Old 07-29-2013, 06:40 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
I would run REW and do some room analysis - you might have a massive peak in your room response which could be easily EQd out using a Behrindger Feedback Destroyer smile.gif
MemX is offline
