Anti-Mode 8033 Balanced XLR Output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-25-2013, 10:01 AM - Thread Starter
JoeMG's Avatar
I just learned today that you can use the 0 & 180 outputs together with a "special" cable to output a balanced XLR connection to your sub (assuming your sub has XLR input).
However, the "special" cable is like $90. So I googled around and found this:
http://www.seismicaudiospeakers.com/XLR-Y-Splitter-Cables-6-inches-p/sa-y6.htm
After speaking with the technician at seismic audio, and telling him what i was trying to achieve, he gave me this information and told me he thinks it should be the same cable as the original:
http://verkkokauppa.planeetta.net/epages/Planeetta.sf/en_GB/?ObjectPath=/Shops/vlsi/Products/80336
Here is the information the siesmic tech gave me on the pin configuration:
Pin 1 is the ground, Pin 2 is connected to the Red/Right RCA and Pin 3 is connected to the White/Left RCA
I have an email out to DSPeaker to see if they will tell me the pin configuration of their cable.
Any bets on whether this works or not?
JoeMG is offline
post #2 of 3 Old 07-25-2013, 06:55 PM
xMEATx's Avatar
You might check out Blue Jeans Cable, I think they have a similar cable that does the same as the DSPeaker. It also is a little cheaper.
xMEATx is offline
post #3 of 3 Old 07-26-2013, 03:50 AM - Thread Starter
JoeMG's Avatar
Just heard back from DSPeaker:
RCA 0-out (red) to XLR pin 2
RCA 180-out (white) to XLR pin 3
RCA ground to XLR pin 1
So they are, infact, the same cable.
JoeMG is offline
