Polk PSW505 vs ?? for $199 - AVS Forum | Home Theater Discussions And Reviews
Old 07-25-2013, 11:29 PM - Thread Starter
cpmiller22's Avatar
I'm setting up a new home theater system and was looking at the Polk psw505 12" for $199. It seems like a pretty good value for the price, but I thought I'd check to see if there is any other subs in that price range that you might recommend over the Polk. I also like the Polk because its a little more compact and will definitely fit in my sub cabinet.
cpmiller22 is offline
Old 07-26-2013, 05:43 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1320
You could also look at the BIC F-12 and JBL ES250P
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 07-26-2013, 07:12 AM
basshead81's Avatar
Quoted: 201 Post(s)
Liked: 5630
I have had both the polk and jbl. the polk has cleaner output at max levels but the jbl digs deeper.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
