SVS - PB13 Ultra (Resolved with Top Notch Customer Support) - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 68 Old 07-31-2013, 06:09 AM
3db
3db's Avatar
Quoted: 157 Post(s)
Liked: 40
Ed, thanks for stepping up on the side of the customer. Although you weren't obligated to replace the amp, I'm happy to see that you recognize a faulty part and and have the customers' back on this. Good job. smile.gif
Receiver: Yamaha RX-V1800/Yamaha RX-V1500
Display Samsung UN65KU6491 65"/Vizio SV-470M 47"
BluRay/CD: Yamaha BD-S681/Sony BDP-S360; Turntable ProJect Xpression III
Speakers PSB: Mains Image T-45/Alphas; Center Image 8C/100C; Srnd Image 1B/Alpha Mites
Subwoofer: Rythmic LV12-R/PSB Subsonic 5
Media Player WD + 3TB USB drive/Iomega + 1TB internal drive
3db is offline
post #62 of 68 Old 08-01-2013, 11:25 PM
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
SVS is the industry standard in quality performance and customer service, glad OP was taken care.
deepat04 is offline
post #63 of 68 Old 08-02-2013, 08:07 AM
jchong's Avatar
Liked: 32
Kudos to SVS. Their outstanding customer support is one reason why I have 3 of their subs.
jchong is offline
post #64 of 68 Old 12-02-2013, 08:41 PM
Sfniner's Avatar
I'm wondering we're should I set my svs pb13 ultra at 80hz or what ?
Sfniner is offline
post #65 of 68 Old 12-03-2013, 02:32 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Crossover depends on -3dB point of your speakers. For an HT application; setting it half an octave above the -3dB point of your speakers is a good start. If you feel you're having weak bass; raise the crossover.
80Hz is not a de facto; you can choose any value based on your speakers and room acoustics. Also, it's better to use bass management in the AVR and bypass LPF on the sub.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #66 of 68 Old 12-03-2013, 02:49 AM
bigvix's Avatar
I'm quite late to this thread but would like to add that...
I've been completely impressed with SVS customer service and their product after purchasing a full 5.1 system from them
Full tower mains, center, and 2 satellite speakers as well as a pb-12nsd
I fully will be upgrading the pb-12 for an ultra before my 1 year is up in the next few months, right after I get enough money saved again after the holidays.
This system will be used in my dedicated home theater. I cant wait to feel the power of the big boy.
I will continue to support and buy svs products in the future!
bigvix is offline
post #67 of 68 Old 12-03-2013, 06:27 AM
Sfniner's Avatar
thanks
Sfniner is offline
post #68 of 68 Old 08-01-2014, 08:33 PM
Liked: 4
<div class="quote-container" data-huddler-embed="/t/1483818/svs-pb13-ultra-resolved-with-top-notch-customer-support/60#post_24024953" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>braveheart123</strong> <a href="/t/1483818/svs-pb13-ultra-resolved-with-top-notch-customer-support/60#post_24024953"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Crossover depends on -3dB point of your speakers. For an HT application; setting it half an octave above the -3dB point of your speakers is a good start. If you feel you're having weak bass; raise the crossover.<br><br>
80Hz is not a de facto; you can choose any value based on your speakers and room acoustics. Also, it's better to use bass management in the AVR and bypass LPF on the sub.</div>
</div>
thanks
It's an old topic, but worthwhile reading.
I am purchasing two PC12-Plus in the next couple of weeks and it is this type of service that made the decision to go with "two" straight away.
Also looking at purchasing their Towers at the end of the year.
I am in Australia, so customer support and service, both via their local distributor and the company itself is of utmost importance.
Having said all that, it is still puzzling why the 2nd amp failed just after 10 months. I thought the amps were specifically matched to the woofers to prevent overdriving/clipping?
Alfred02 is offline
Svs Pb13 Ultra , Svs Pc12 Ultra
