should i take my eq2 out of the mix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-30-2013, 11:45 PM - Thread Starter
SULLY12's Avatar
Has anyone had one and the not used it. Would I be better off without it. I got it mostly for the sub sonic filter but now have three subs and can. Run without the sub sonic filter. Plus I have no sub eq in my reciever. But when I tweek the eq2 and then run sweeps nothing seems to change for thw better. What do you guys think.thanks
SULLY12 is offline
post #2 of 4 Old 07-30-2013, 11:50 PM
braveheart123's Avatar
Quoted: 330 Post(s)
Liked: 287
which eq do you have? What kind of gains are you applying i.e. +/- how many dBs?
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #3 of 4 Old 07-31-2013, 12:09 AM - Thread Starter
SULLY12's Avatar
It is aelemental designs eq2 just a 2 band eq I boost it at 25 Hz by about 3 db and at about. 60 Hz about 2 db but I have tried many variations and even just when testing gone as far as 6-8 + db. It could be my room but it just doesn't seem to change much.
SULLY12 is offline
post #4 of 4 Old 07-31-2013, 12:33 AM
Quoted: 330 Post(s)
Liked: 287
Try changing the sub location. You may be experiencing nulls or dips at those frequencies wrt your MLP
