What type of Subwoofer do you recommend? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 07-31-2013, 10:01 AM - Thread Starter
jeffpell's Avatar
I have a 10x20 room with hardwood floors. I have a subdued ii. My current room setup is in the attached jpg.
Thanks in advanced for any help.
Front Left and Right - Monitor Audio GX300s
Center Channel - Monitor Audio GXC150
Surround Left and Right - Monitor Audio GX100s
Subwoofer - Monitor Audio GXW15
Pre-Amp - Yamaha Aventage CX-A5000
Amp - Yamaha Aventage MX-A5000
jeffpell is offline
post #2 of 16 Old 07-31-2013, 10:04 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
What is your budget?
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 16 Old 07-31-2013, 11:00 AM - Thread Starter
jeffpell's Avatar
I'd like to stay under $1200 if possible.
jeffpell is offline
post #4 of 16 Old 07-31-2013, 11:08 AM
Liked: 1319
I would probably go with a pair of Rythmik LV12R subs.
post #5 of 16 Old 07-31-2013, 11:16 AM - Thread Starter
jeffpell's Avatar
A pair? Even though the bp-8060st have built in subs? Just curious. thanks for your input.
jeffpell is offline
post #6 of 16 Old 07-31-2013, 11:37 AM
Liked: 1319
A dedicated sub will have much better output and extension than the ones in the DefTechs. A pair will provide more even bass response in the room, and increase output some as well.
post #7 of 16 Old 07-31-2013, 11:39 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
They don't have true subs. That is marketing. What they have is a 10" woofer and a couple of passive radiators. If they produce enough bass for you then leave it alone. If you don't get the room pounding LFE you expect, then get yourself a true 15" powered subwoofer from Rhythmik, Hsu, SVS etc. The bigger the size of the sub or the number of subs, the smoother the bass and the less work the sub {s} have to do. You can't have too much subwoofer. You can have too little.
FMW is offline
post #8 of 16 Old 07-31-2013, 11:54 AM - Thread Starter
jeffpell's Avatar
I just ordered the pair bp-8060st. I'm wondering now if I should cancel the order and get something better for the money...
jeffpell is offline
post #9 of 16 Old 07-31-2013, 12:00 PM
tenderchkn's Avatar
If you're planning on running a subwoofer, full range towers will be a waste of money because they will be crossed over well before the big woofers are needed. A pair of good bookshelves should be better value for your money.
tenderchkn is offline
post #10 of 16 Old 07-31-2013, 12:08 PM
simp1yamazn's Avatar
Quoted: 109 Post(s)
Liked: 77
If you like def tech but are planning to get a good subwoofer to go along with it, I would suggest looking at their SM65 bookshelf speakers. IIRC they use the same tweeter as the 8060 and actually have larger midrange woofers. they easily play low enough to properly integrate with a sub for less than half the cost of 8060's
simp1yamazn is offline
post #11 of 16 Old 07-31-2013, 12:12 PM - Thread Starter
jeffpell's Avatar
Could you recommend some shelf speakers in the $800 each range?
jeffpell is offline
post #12 of 16 Old 07-31-2013, 12:27 PM
Liked: 1319
You would also need a matching center if you were to get different fronts. I would take a look at the Ascend Sierra-1 bookshelves with the upgraded NRT tweeter. Pair those with the Sierra-1 Center (w/ NRT) and you would have a nice setup. You also get a discount for buying Ascend speakers and Rythmik subs together.
post #13 of 16 Old 07-31-2013, 01:12 PM
padgman1's Avatar
+1
Another option would be to go with Arx A2c for L/C/R ................. http://www.theaudioinsider.com/product_info.php?loudspeakers=arx&p=arx-a2c-center-lcr-loudspeaker&cPath=21_32&products_id=66&osCsid=cbd7f0d9eb5bdb6cc93b9f088bf0f06f
padgman1 is offline
post #14 of 16 Old 07-31-2013, 01:37 PM - Thread Starter
jeffpell's Avatar
I guess the next question is... If I plan on placing a single sub in the corner based on the my floor plan. What is the best type of sub? Downward firing etc?
Thanks a lot for the advice
jeffpell is offline
post #15 of 16 Old 07-31-2013, 02:00 PM
tenderchkn's Avatar
Bass waves are omnidirectional, so front/side/down firing makes little difference. I have heard mentioned by several people on this forum that firing down or into a wall gives a tiny edge over front firing, but I don't think that it is significant enough to make your decision purely based on this.
post #16 of 16 Old 07-31-2013, 03:14 PM
Quoted: 73 Post(s)
Liked: 112
The Ascend/Rythmik option would be great and you would get the discount to boot.
rnatalli is offline
