Sub advice: my trusty Velodyne HGS-18 died - AVS Forum | Home Theater Discussions And Reviews
post #1 of 88 Old 08-12-2013, 04:09 PM - Thread Starter
Gussboy's Avatar
Well my trusty 12 yr old Velodyne HGS-18 has recently died on me and I am looking for a replacement. My newer dedicated media room is only a 1400 CU FT (14'x11'x9') room so I am thinking that I just do not need a new sub as large as the HGS-18 I had prior. My primary listening is for movies and I do not listen to music at all in this room. I love heavy bass soundtracks and watch alot of action movies.
Budget is $2,000 max but I would like to stay well under this if possible. So far the SVS SB13-Ultra has caught my attention and am wondering what else I should consider given my budget and room specs. Would the SB13-Ultra feel like a downgrade from my older 18" Velodyne?
For reference the rest of my HT gear is as follows:
Velodyne HGS-18 (dead subwoofer)
Frequency Response: 15Hz - 120Hz
Woofer: 18"
Amp: Class D, 1250 watts RMS, 3000 watts peak
AV RECEIVER: Denon 3808 CI
Power output: 130 WPC / 7-channel
SPEAKERS:
Martin Logan Scripts (fronts)
Martin Logan Theater (center)
Polk Audio (surround rears)
Gussboy is offline
post #2 of 88 Old 08-12-2013, 04:20 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
basshead81 is offline
post #3 of 88 Old 08-12-2013, 04:27 PM - Thread Starter
Gussboy's Avatar
Basshead81, thanks I will look into the XS30. However I just don't think I have the floor real estate in my small room for dual subs.
Can anyone give me a frame of reference of what I might experience going from the older 18" Velodyne to something like an XS30 or SVS SB13-Ultra?
I feel confident making a decision solely on reviews and user opinions, however I just don't want to feel like I have lost any low end (umph) in this transition to a new sub....
Gussboy is offline
post #4 of 88 Old 08-12-2013, 04:33 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
You wont lose anything. a single XS30 will dig down in the 7-10hz range in your room.
post #5 of 88 Old 08-12-2013, 04:37 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
Is it a sealed room, Rythmik F15HP would be more than enough in that room. You might be better off aesthetically with 2 smaller 12 inch sealed subwoofers.
Check out this site for some comparison, there is a couple of Velos in there for reference
http://www.data-bass.com/systems
qguy is offline
post #6 of 88 Old 08-12-2013, 04:40 PM - Thread Starter
Gussboy's Avatar
Originally Posted by qguy View Post
Is it a sealed room, Rythmik F15HP would be enough in that room
The room is mostly sealed but there are double doors in the rear, which are closed during critical viewing. I do not have any acoustic dampening in the room if that is what you meant.
Gussboy is offline
post #7 of 88 Old 08-12-2013, 04:49 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
The XS30 is a better buy than the F15HP Imo. A better comparison would be the F25.
post #8 of 88 Old 08-12-2013, 05:00 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
but thats too big. maybe FV15HP ? .
qguy is offline
post #9 of 88 Old 08-12-2013, 05:36 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
If you think a XS30 is too big the FV15HP is even bigger.
jbrown15 is offline
post #10 of 88 Old 08-12-2013, 06:12 PM - Thread Starter
Gussboy's Avatar
I might be able to squeeze two 12" sub's in my room. I have never experienced a multiple sub configuration so I am not sure what to expect or how it will sound better...
Gussboy is offline
post #11 of 88 Old 08-12-2013, 06:20 PM
henrich3's Avatar
Quoted: 585 Post(s)
Liked: 502
The HGS-18 is a fine sub. Have you considered repairing it? A replacement amp should be less than $400. I believe that's the usual fix for these.
henrich3 is offline
post #12 of 88 Old 08-12-2013, 06:41 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
The XS30 is smaller than the FV15. I would not go ported in that small of a room. I know you like Rythmik, I do to, but imo the PSA XS30 is a killer sub.
post #13 of 88 Old 08-12-2013, 07:27 PM - Thread Starter
Gussboy's Avatar
How would you compare the XS30 versus the SVS SB13-Ultra in my room?
Gussboy is offline
post #14 of 88 Old 08-12-2013, 07:29 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
Two F15HPs would be a great system, but it would go over budget. Boost your budget by $500, and you can get a Funk 18.0. Like your HGS-18 it is a sealed 18", but the Funk has a much more powerful driver and amplifier. It has recently received a terrific review from audioholics with some great measurements. You might think of it as a 'super' HGS 18.
shadyJ is offline
post #15 of 88 Old 08-12-2013, 07:46 PM - Thread Starter
Gussboy's Avatar
Shady - but do I really "need" that large of a sub in my small media room that is only 1,400 cu feet? I just wanted something ideally suited to my room but that will also rock the house in movies.
Gussboy is offline
post #16 of 88 Old 08-12-2013, 07:52 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
Anything but PSA huh Shady....the XS30 would match the performance of the 18.0 for alot less coin. Let me guess you are going to claim no way because of the cheap drivers?
post #17 of 88 Old 08-12-2013, 07:57 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
A ported 12, 2 sealed 12 or a single 15 should provide you with all the LFE happiness that you need......
You may not need a big sub, a single ported 12 may work for you, but your coming from an 18 incher. So a smaller sub may not cut it.... psychologically smile.gif
qguy is offline
post #18 of 88 Old 08-12-2013, 08:04 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
It would take almost 2 sb13 to equal 1 xs30.
post #19 of 88 Old 08-12-2013, 08:05 PM
jbrown15's Avatar
Liked: 1995
It's hard to directly compare the XS30 to a Funk 18.0, I mean lets not kid ourselves I would have to say it defiantly has a better driver. But at the same time I would think that a XS30 would compare fairly well and two for the price of one 18.0 would defiantly have more output. Hell you could buy two XS30's with a nice veneer finish and still save over $600.
jbrown15 is offline
post #20 of 88 Old 08-12-2013, 08:06 PM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
FYI we do have our smaller 18.0C, also on databass. If you compare it to the sealed mode pb13(the pb13sealed has a little more low end than the sb13) it has similar low end but much more mid/top end. That gives it great dynamics and very low distortion in the upper bass for great sound quality and punch. It has very similar sound characteristics as its bigger brother the 18.0(btw the 18.0 is on sale right now)
Nathan Funk
Funk Audio
Funk Audio is offline
post #21 of 88 Old 08-12-2013, 08:10 PM
jbrown15's Avatar
Liked: 1995
Even a passive 18.0 would still cost more then dual XS30's once you factor in the amp the OP would need to buy and would still have less output.
jbrown15 is offline
post #22 of 88 Old 08-12-2013, 08:13 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
Lookin at 18.0 numbers on data bass the xs30 numbers look very similar...107db ultra low bass and 122db low bass.
post #23 of 88 Old 08-12-2013, 08:16 PM
shadyJ's Avatar
Liked: 1352
It's about the same size as your HGS, it's not that large. It's probably lighter too, thanks to the neodymium magnet. Still, it will be a far higher performer. As for needing it, no one needs a subwoofer at all, but if you are going to spend the coin, might as well make it a great sub.
Outside of raw upper bass SPL, I would guess the XS30 is no way match for the 18.0, and I think even Tom V would admit to that. However, if your only criteria for evaluating a sub is lots of boom without control, the PSA subs will fit the bill nicely.
shadyJ is offline
post #24 of 88 Old 08-12-2013, 08:20 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
Lol now thats some funny **** there.
post #25 of 88 Old 08-12-2013, 08:25 PM
jbrown15's Avatar
Liked: 1995
While I totally agree that the 18.0 will have more output then a XS30's I don't think it's going to have a lot more. But so it should considering the driver Nathan is using, that thing is a work of art.
But your last statement about lots of boom with no control is about as dumb as it gets, have you even heard a XS30 yet shady?
jbrown15 is offline
post #26 of 88 Old 08-12-2013, 09:05 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
While they argue on which is better, one 18 or two 15, Go get the Rythmik sealed F12 if you like music too, its 874 each or the ported Rythmik LV12R, its 589 each. you'll thank me later smile.gif
qguy is offline
post #27 of 88 Old 08-12-2013, 09:11 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
Whats he going to thank you for suggesting to downgrade? Fyi the F12 is 935.00 shipped.
post #28 of 88 Old 08-12-2013, 09:15 PM
shadyJ's Avatar
Liked: 1352
I would guess the 18.0 doesn't have a whole lot more output than the XS30, and that isn't really the point of comparison I am making. So if the 18.0 isn't absolutely stomping the XS30 in raw output, what then is the point of such a expensive and massive driver and amplifier? Why wouldn't all subwoofers use cheaper drivers to get big SPLs? Are Funk, JL Audio, SVS Ultras, TC sounds, et al. simply over priced?
shadyJ is offline
post #29 of 88 Old 08-12-2013, 09:16 PM
shadyJ's Avatar
Liked: 1352
OP has stated he does not intend to listen to music, just movies only.
shadyJ is offline
post #30 of 88 Old 08-12-2013, 09:32 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6572
The Funk is a awsome sub and I would expect it to be another level above the XS30. However i was simply suggesting a sub that will maximize performance and still fall within the op's budget. The Funk is not in his budget so I am not sure why its even being mentioned.
The op also does not want to lose any performance, so I am not sure why the rythmik f12 or fv12 is being mentioned.
There are 2 sealed subs that fall within the op's budget that will out perform the velodyne 18 and that is the PSA XS30 and Rythmik F25...the F25 is huge, so I thought the XS30 was the best option.
Now instead of further cluttering the op's thread, why not offer suggestions that meet his criteria or stay out of his thread to avoid further confusion?
Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Xs30 , Rythmik Audio F15 Subwoofer
