Sound&Vision Magazine Tests Five ~$800 Subs Including PSA XV15 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 72 Old 08-26-2013, 01:56 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5319
So you are saying you can tell a difference between 10% and 20% 2nd order THD? When I played a 15hz test tone at 110db, I herd nothing but the walls and cabinets in the house pulsating, the subs were quiet...I turned it up to 115db still no audible change in the subs, but when I turned it up from there the subs did not raise the spl levels and they started to make audible noises that sounded like distortion. I am not arguing with you, but I am just trying to figure out why you specify 10% thd in lower order harmonics is clean bass? Why does cea-2010 allow such higher low order thd levels?
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #62 of 72 Old 08-26-2013, 02:54 PM
MKtheater's Avatar
Quoted: 1596 Post(s)
Liked: 1123
Sorry, but I measured at much higher levels so at the point of when I reach 10% THD everything sound great and depending on the drivers, 12% THD sound great on some and bad on others. From all the subjective comments and then verified by Ricci the PSA sub has good sounding THD so you can not tell it is THD to begin with. Whether one can live with knowing it is THD or not is up to them. The key is to have enough subs not to reach their THD limits so it won't matter. This is why I said pick which ever looks better or cheaper.
Marantz 7702 Atmos
MKtheater is online now
post #63 of 72 Old 08-26-2013, 03:12 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5319
Ok...I was just curious because with my Polk 505's If I played a 15hz test tone they would have sound like a 30hz test tone, which obviously was distortion. The XV15's do not do that so I was just curious. I know you have taken lots of measurements with various setups so that's why I asked. I appreciate the feedback!! smile.gif
post #64 of 72 Old 08-26-2013, 04:06 PM
MKtheater's Avatar
Liked: 1123
I use 10% because that is where some subs start to sound bad. Just being safe. I played my eD's with 12%THD at 10hz and it was awesome! I could not do that with other subs which start to sound bad at 10%. My F-20's also sound very good at 15% THD. I have a hard time believing people say that their sub sound much tighter than another unless they were over driving the other sub.
I just noticed something, I see that the sweeps were at different levels. What people are noticing is that the PSA sub is clean from 25-80hz with a 110 dBs sweep. The SVS stays clean with a 105 dBs sweep and if you notice the 105 dB sweep of the PSA it is just as clean as the SVS within a range where music would be played. The THD stuff is for the low end and in a room is where the THD gets knocked down, the low stuff. I take it the SVS will not play louder and just limit so this is where the PSA has the advantage.
Marantz 7702 Atmos
post #65 of 72 Old 09-05-2013, 11:21 AM - Thread Starter
spyboy's Avatar
Liked: 47
The review of the five $800 subs is up at Sound&Vision, here:
http://www.soundandvisionmag.com/article/review-800-subwoofers
spyboy is offline
post #66 of 72 Old 09-20-2013, 11:18 PM
mdanderson's Avatar
Quoted: 37 Post(s)
Liked: 52
This link did not work for me. I even tried going to their site and could not find it. Thanks.
Paradigm Studio 20v5-fronts
Paradigm Studio CC-490v5-center
Paradigm Studio 10v5- side surrounds,Monitor surround 3v7-bck surr
Oppo BDP-105/LG 65C6
Marantz SR-5010(as preamp) Emotiva BasX A-700amp
SVS SB-1000
mdanderson is offline
post #67 of 72 Old 09-21-2013, 04:34 AM
KidHorn's Avatar
Quoted: 1380 Post(s)
Liked: 889
http://www.soundandvision.com/content/review-800-subwoofers
KidHorn is offline
post #68 of 72 Old 09-21-2013, 05:43 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
If you get it to work, it turns out to have close to zero content.
SaviorMachine likes this.
arnyk is offline
post #69 of 72 Old 09-21-2013, 05:51 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
It is all about the audibility of distortion.
One factoid - most bass musical instruments produce more low order harmonics than fundamentals. Since the harmonics are also quite a bit more audible than the fundamentals, that is most of what you hear.
So adding even more low order harmonics doesn't make that much change to what you hear, since there is already so much of them present in the recording. The same is generally true of SFX in movies.
In contrast high order harmonics stick out like sore thumbs.
Most distortion in a well made subwoofer driver is due to the active region of the voice coil moving out of the magnet's active gap. Whether the magnetism in the gap falls off slowly or rapidly is up to the designer. The more rapidly the magnetism in the gap falls off, the more higher order distortion is generated. If the cone hits a mechanical limit, then you obtain a similar effect.
arnyk is offline
post #70 of 72 Old 09-21-2013, 01:01 PM
mdanderson's Avatar
Quoted: 37 Post(s)
Liked: 52
Thanks for the link. Like arnyk said, there should be more pages.
SVS SB-1000
post #71 of 72 Old 09-21-2013, 01:14 PM
cvinfig's Avatar
Quoted: 148 Post(s)
Liked: 102
Links to each sub review can be found here: http://www.soundandvision.com/category/subwoofer-reviews.
cvinfig is online now
post #72 of 72 Old 09-21-2013, 06:03 PM
mdanderson's Avatar
Quoted: 37 Post(s)
Liked: 52
Thanks so much. That did the trick.
SVS SB-1000
Nht B 12d 500 Watt Powered Subwoofer With Dsp Piano Gloss Black Single , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer
