Mono Price RCA Connectors - AVS Forum | Home Theater Discussions And Reviews
Old 08-21-2013, 07:28 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Anyone else think they lack a bit of quality? I ordered several in several different lengths and the connectors keep coming loose. I had to clamp down the outer ring on a couple so they would stay on the female jack, and now one seems to have a short in it at the tip.
Anyone else experience any issues?
pdxrealtor is offline
Old 08-21-2013, 08:41 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
I did have issues with mediabridge cables, got some and 2 didnt work right, but i did get some monoprice ones, but they were vary stiff, now i have BJC and they are nice.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
Old 08-21-2013, 08:58 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Hmmm now that you mention it they are stiff huh? I never noticed.
Are the BJC ones online?
Old 08-21-2013, 09:04 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
Yeah, I was thinking the same thing. I just got 7 and all the ends were loose and just overall, the quality seems very poor. I have monoprice wire through my whole theater and home. This is the first time I've been disappointed in one of their products.
BllDo is offline
Old 08-22-2013, 06:13 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
Have you emailed them to mention it?
They may have had a bad batch and might offer to replace them.
MemX is offline
Old 08-22-2013, 07:35 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
I always take a pair of pliers and crimp down the outer ring on the rca connectors so it is a snug fit. That being said my mono price coaxial cables are working great. As mentioned above email them, they might send you replacements.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 08-23-2013, 11:19 AM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
+1 the only other issue I had were with their 1/4" to RCAx2 adaptors. Cheap plastic.
I too crimped the ends like you. One of the tabs actually broke on a cable and I RMAd it as damaged. Crimping for a tight fit seemed odd to me....
Old 08-23-2013, 07:01 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
I have had to do it on all rca or coaxial cable I have bought over the last couple years...I believe I have tried several brands as well.
Old 08-23-2013, 10:37 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
http://www.bluejeanscable.com/
HT~
2.1CH~
Joshjp is offline
