Where did all my mid bass go? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-21-2013, 11:49 PM - Thread Starter
Oledurt's Avatar
Quoted: 201 Post(s)
Liked: 288
My first measurement of my subwoofer is indicated by the green line. You can see a nice little null there right at 60hz (I wonder where all my mid bass went tongue.gif) By moving my seating area 6 inches I eliminated the null and had a fairly flat response. After running Audyssey XT32 to smooth it out more I am in bass heaven once again. Oh what a difference 6 inches makes.
Just thought I would share.
update: I took at second look at how far I moved the mic position and it was closer to 10-12 inches. wink.gif
Oledurt is offline
post #2 of 8 Old 08-21-2013, 11:56 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
steve nn likes this.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #3 of 8 Old 08-22-2013, 07:09 AM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5286
fairly flat? thats a +/-20db swing.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #4 of 8 Old 08-22-2013, 07:34 AM
BeeMan458's Avatar
Liked: 813
BeeMan458 is offline
post #5 of 8 Old 08-22-2013, 09:31 AM
Bill Fitzmaurice's Avatar
Liked: 4692
+/-9dB, actually.
Bill Fitzmaurice is offline
post #6 of 8 Old 08-22-2013, 10:10 AM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5286
Originally Posted by Bill Fitzmaurice View Post
+/-9dB, actually.
correct...I meant there is almost a 20db difference from the lowest point to highest which would be +/-10db. But yes the exact difference is +/-9db...thanks for the correction.
post #7 of 8 Old 08-22-2013, 10:32 AM
Ivan Beaver's Avatar
Liked: 57
So where is the mic position? Your left ear? right ear? middle of the head?
Just something to consider that there is spacing (more than 6") between your ears
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #8 of 8 Old 08-22-2013, 11:24 AM - Thread Starter
Oledurt's Avatar
Quoted: 201 Post(s)
Liked: 288
My mic position was the middle of my head at my seating position. I pulled the mic back toward my rear wall about 10-12 inches straight back and the null disappeared.
These readings are taken before audyssey was run so I realize that the second sweep is not flat. what I meant to say is it is fairly flat relative to the first reading.
I moved the sofa more than 6 inches after taking a second look.
Oledurt is offline
