How to use SPL Meter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 08-26-2013, 05:27 PM - Thread Starter
mantaraydesign's Avatar
Quoted: 133 Post(s)
Liked: 33
Anyone know how to use the SPL meter for measuring subwoofer?
I am using the SPL meter with a needle (analog) and not a digital. I have the Range set to "70 dB". I have the Weighting set to "C" and I have the Response set to "Slow".
I was able to measure at 75 dB for all my speakers. But when it come to measure the subwoofer, the needle keeps on bouncing at 75 dB and even higher. Measuring the subwoofer is a little more difficult than I thought.
I guess I don't know where the needle should hit to get 75 dB? When the white noise or the rumbling noise (MCACC Calibration) is coming out of the subwoofer, I tried to get it at 75 dB but the needle keeps on bouncing over 6+ dB on the SPL meter.
It's kind of hard to explain. The needle seems to stay at 75 dB but if you wait a little longer, the needle will bounce pass the 6+ dB on the SPL meter. It's difficult to read because the needle will not stay at 75 dB. It just stay at 75 dB for a short seconds and the needle will bounce way pass the 6+ dB.
It's pretty hard to get an accurate reading using the SPL meter for subwoofer.
mantaraydesign is offline
post #2 of 31 Old 08-26-2013, 05:32 PM
BeeMan458's Avatar
Liked: 813
A recommendation, lose the needle and go digital.
This is the sound meter I'm partial too and yes, of the several sound meters I have and have used, one is a well used RS, digital sound meter.
BeeMan458 is offline
post #3 of 31 Old 08-26-2013, 05:49 PM
steve nn's Avatar
Liked: 433
I have somewhat the same problem to a degree with the digital meter I use also. I get a 1-2 dB flexuation. My suggestion is to just do the best you can for a reality check and adjust from there.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #4 of 31 Old 08-26-2013, 05:54 PM
BeeMan458's Avatar
Liked: 813
^...+1
post #5 of 31 Old 08-26-2013, 05:59 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 33
Can the Digital meter lock the dB reading? Or can the Digital meter do an estimate on the dB and show you the average dB or the next highest dB?
If it can do that, I would buy the Digital SPL meter.
post #6 of 31 Old 08-26-2013, 06:14 PM
steve nn's Avatar
Liked: 433
Your meter is fine. I would suggest go with the first reading before the bounce, the digital does the same to a degree although I can’t speak for the digital option Bee brought up.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #7 of 31 Old 08-26-2013, 06:28 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 33
Thanks guys for your advice!!
post #8 of 31 Old 10-17-2013, 02:32 AM
joamonte's Avatar
A or C weighted SPL meter is meant for measure noise at at mid range, it is wrong to use it for subwoofer calibration.
Check wiki for C weighting , C weighted mean the lower and higher the frequency , the less sensitive the SPL meter.....if you use a C weight SPL to calibrate the subwoofer, you will set it too loud.
I don't understand why every where in internet , I see expert recommend using SPL meter to calibrate subwoofer....
Room acoustic treatment is importance.....
joamonte is offline
post #9 of 31 Old 10-17-2013, 06:22 AM
Bill Fitzmaurice's Avatar
Liked: 4628
That's because the level with a pink or white noise source isn't constant. If you were to watch it on an RTA you'd see each individual frequency level is constantly shifting. You can only get a constant level with a sine wave source.
You don't use 'A' weighting, because that filters out all the lows and highs. 'C' weighting also filters lows and highs, but only below 50Hz and above 5kHz, and that filtering can be compensated for. Unweighted is best, but meters with an unweighted or 'Z' weighting are rare, and expensive.
Bill Fitzmaurice is online now
post #10 of 31 Old 10-17-2013, 09:37 AM
joamonte's Avatar
Wrong measurement tools give wrong result, that is a facts....
C weighted filter not only affect below 50 Hz, all the bass below 100 Hz is affected if you look at the curve line.....worse if the calibration is using pink noise , because the C weighted SPL is just picking up the AVERAGE noise below the low pass crossover frequency from the subwoofer, and as we can see since the SPL meter lowest octave is much less sensitive, the end result will be we need to turn the sub woofer MUCH louder to reach the ref SPL.
Solution? Simple , get a USB measurement mic with a notebook....
joamonte is offline
post #11 of 31 Old 10-17-2013, 01:09 PM
BeeMan458's Avatar
Liked: 813
Not sure where you're coming from.
With the AVR's subwoofer levels set to zero, using AVR provided pink noise, the calibrated, type 2 sound meter is used to individually gain match each subwoofer's output. From there, using each EQ's provided microphone, Anti-Mode and Audyssey MultEQ XT (will upgrade to a XT32 AVR as soon as possible) are run so they can do their magic. After the two EQ programs have done their stuff, a measuring microphone is used in concert with REW to measure and season the output to taste.
Don't know how things can get any better.
post #12 of 31 Old 10-17-2013, 07:31 PM
joamonte's Avatar
Friend , if you really depending on the auto calibration thing on AVR to do calibration, I hope good luck on you, I never able to get the setting right with any AVR auto calibration so far.....
joamonte is offline
post #13 of 31 Old 10-17-2013, 07:39 PM
joamonte's Avatar
BTW the USB measurement mic thing is refer to the question of last poster mention that "Z weighted SPL meter is rare and expensive", a calibrated USB measurement mic with some cable and free software like REW should cost less than a branded low end A/C SPL meter....
My point is , A/C SPL meter are not design for sub woofer calibration in the first place, I don't understand why so many internet HT expert still recommend it ......smile.gif
joamonte is offline
post #14 of 31 Old 10-18-2013, 08:16 AM
BeeMan458's Avatar
Liked: 813
Thanks! I use a separate calibrator tool for calibrating our sound meters. We have three of them. biggrin.gif
post #15 of 31 Old 10-18-2013, 08:19 AM
BeeMan458's Avatar
Liked: 813
..... I don't understand why so many internet HT expert still recommend it ......smile.gif
I only qualify as an incompetent old fool. I use the sound meter to gain match subwoofer output before running the EQ programs and use it to measure the room's acoustics in various locations. Sometimes I like to relax, go outside and use the sound meter to measure the sound of the wind.
post #16 of 31 Old 10-18-2013, 12:51 PM
DonH50's Avatar
Quoted: 1790 Post(s)
Liked: 1323
You might want to pick up calibrators for LF and HF as well as the single-point (1 kHz) measurement. Or just spend the $100 and get the calibrated USB mic as previously suggested. These days I suspect few have or need a $1200 earthworks measurement mic with a nice personalized calibration curve, but I have had mine for years so can blame it on my youth. smile.gif
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #17 of 31 Old 10-18-2013, 07:26 PM
joamonte's Avatar
For example
http://www.daytonaudio.com/index.php/emm-6-electret-measurement-microphone.html
This one do not even need $100....and it is calibated individually.
This one slightly higher than $100 but it can directly plug into notebook without need of phantom power.
http://www.daytonaudio.com/index.php/test-measurement/umm-6-usb-measurement-microphone.html
joamonte is offline
post #18 of 31 Old 10-18-2013, 07:33 PM
joamonte's Avatar
Than the measurement you taken is not the true dB SPL of the wind, it is just dB C weighted......because you SPL meter is bandwidth limited but the sound of the wind is full bandwidth.
You need to find a way to limit the bandwidth of the wind , band pass it between 100 Hz to 3 kHz in order to get the slightly more correct true dB SPL of sound of the wind....biggrin.gifbiggrin.gif
joamonte is offline
post #19 of 31 Old 10-18-2013, 07:45 PM
BeeMan458's Avatar
Liked: 813
When listening to the wind, I use "A" weighting. confused.gif I'm clueless what the frequency response range of the wind is. All I know, the wind is outside and where we live, one can hear the wind coming, long before seeing the tree tops move.
post #20 of 31 Old 10-18-2013, 09:04 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
If you had your laptop/usb mic you could see the frequency response of the wind as well as the spl !
lovinthehd is offline
post #21 of 31 Old 10-19-2013, 08:25 AM
BeeMan458's Avatar
Liked: 813
post #22 of 31 Old 10-19-2013, 02:26 PM
lovinthehd's Avatar
Liked: 4775
That would make it more difficult....haven't had a desktop at home in years.
post #23 of 31 Old 10-19-2013, 02:51 PM
BeeMan458's Avatar
Liked: 813
It's outdated/antiquated and I know that I'm probably the only person within a hundred miles that still has a desktop but I love my desktop PC because I can easily add and change boards, drives and memory. Both the wife and son have and use laptops.
When our current desktop fails, I may break with my old habits and go with a laptop......this as everybody is going with tablets. tongue.gif
(behind the curve? Hell, the curve ran me over years ago)
post #24 of 31 Old 10-19-2013, 04:39 PM
steve nn's Avatar
Liked: 433
If I ever break down and buy a lap it’ll be for wind/calibration basically, except for when I travel or something. I really like the old style PC, my own little space. smile.gif
I tried a friends tablet on a trip, it worked, but I found it quite odd being a old dog.. no mouse! how can we resist change? By the time we get a tablet it'll be antiquated and we'll need to move on again. eek.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #25 of 31 Old 10-19-2013, 06:02 PM
lovinthehd's Avatar
Liked: 4775
LOL no, am not even a smart phone kinda guy let alone tablet. I have used laptops for many many years and I like being wherever I want to be and be able to use it, whether that's in the living room, kitchen, bedroom, etc or on the road (which I've done quite a bit of since laptops became reasonably powerful/fast). I did get used to a touch pad, and prefer it to a mouse too. If I didn't have a work pc for the last few years at the office I probably wouldn't even be able to use a mouse again. Let alone a touch screen; I don't have any devices that have one. Old dog definitely is me.
post #26 of 31 Old 10-19-2013, 06:29 PM
BeeMan458's Avatar
Liked: 813
My guess, soon we'll be using heads-up technology and we'll put little gizmos on our fingers and look like idiots tapping away in the air, much like we all looked when we first started using bluetooth ear pieces with our cellphones.
post #27 of 31 Old 10-19-2013, 07:49 PM
steve nn's Avatar
Liked: 433
biggrin.gif I never did like that look. At first I thought they were talking to themselves until they turned their head. redface.gif now I know.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #28 of 31 Old 10-20-2013, 06:18 AM
BeeMan458's Avatar
Liked: 813
Ya gotta love technology. If anything, it's makes for some excellent entertainment. It just so darn expensive trying to keep up with the fast moving upgrade curve and trying to stay on top of the next, newest and greatest operating system interface kills you as your brain gets older.
steve nn likes this.
post #29 of 31 Old 12-22-2014, 04:27 AM
Sam Ash's Avatar
Quoted: 216 Post(s)
Question Z Weighting & Sub Levels ?
Hi Bill, you seem to be quite knowledgeable about acoustics. I know this is an old post but I thought I'd ask you this question. You mentioned in one of your posts quoted above that it is best to use 'Z' weighting to set speaker levels. Can you explain this further please.
Pink noise in a receiver or pre/pro that lets you set the level of each individual speaker makes the SPL value in REW vary up and down a bit so one has to look at the figure carefully and use a general closest average, is that correct ?
Example, my aim was to set all speakers at 70bB but the value varies between 69.5 to 70.1 dB. I wish receivers and pre/pros offered level adjustments by 0.5 or 0.25 dB.
The problem is with the subwoofer, there must be a better way to set low frequency levels. Under Z weighting, if I set the sub level to 70dB it is just not enough and I have to raise the level by 4 to 5 dB for it to sound decent without it being detrimental to the mids and highs.
Let me have your views.
Sam Ash is offline
post #30 of 31 Old 12-22-2014, 10:25 AM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
The subwoofer level does not need to be dead on 75 db. A few db either way will get you there and then adjust to your taste. There are correction tables for the Radio shack meters. It is normal for the needle to bounce a bit since you are measuring the sub/room response at the meter. MCACC does a good job with setting sub level and adjustment can be made in 0.5 increments.
Setting the sub to exactly 75 db may be high by a couple db with the meter. Using 73 db with MCACC is a good starting place or just let autocalibration take care of things. Also, setting the sub to exactly 75 db is a moot point in the calibration process and can vary depending on how many subs are in the system. Most people will not leave the system as calibrated and post calibration, jack the subs up, lol.
I am not answering for Bill but, after I started reading this page, so much of the info was not good advice to a simple question.
derrickdj1 is offline
