Dilemma in selecting subs - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 08-28-2013, 10:38 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Those mains are 3-way speakers meaning they do have a woofer in them. Also forget about the 500Hz crossover; that is the crossover between the woofer and midrange driver on the speaker itself. For an HT setup you don't need 3-way speakers or else spending thousands of dollars on a dedicated subwoofer is useless. You will lose more and gain less. Do a bit of reading on 2-way and 3-way speakers. The crossover I am talking about is between your subwoofer and your mains that is part of the bass management performed in the AVR.
You should only be concerned about mains and to some extent the center channel for blending with the sub.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #32 of 33 Old 08-28-2013, 07:18 PM - Thread Starter
winwinc81's Avatar
Quoted: 120 Post(s)
hi braveheart123, sure. from all that explanations, looks like it will really be an advantage when my living room comes to reality. for the mains and surround, i am already using them, just that i have not really use a sub. smile.gif
so since i am already using them and to move them to my living room in future, apart from the distance from wall, the sub to get it later, do i need to focus on any other things?rolleyes.gif
winwinc81 is offline
post #33 of 33 Old 08-28-2013, 11:08 PM
Quoted: 311 Post(s)
Liked: 273
I have mentioned what I thought were odd; may be somebody else has a better hawk eye wink.gif
