Your Home Theater ULF Score - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 755Likes
post #271 of 5032 Old 09-17-2013, 09:12 PM
Archaea's Avatar
Quoted: 3075 Post(s)
Liked: 2689
:cool:You can see how he rated the orbit shifter at that same cached page, with higher max usable dB. I agree with everyone. It'd be nice to have some Cap measurements by Ricci.
Is anyone sure if the cap 2400 is using the same driver as the orbit shifter these days? The cap 4000 was for sure. Jeff confirmed it with me, but I'd not asked if he swapped drivers since the cabinet and power changed.
Mine is 20hz native, 15hz with port plug.
The 2400 is 17.5hz with no port plug option/recommendation.
I think he took those numbers down because they were sim numbers and he hadn't had the subs professionally measured. IIRC the numbers caused a bit of bench racer rage because they were sim numbers and some said could not be real world.
Archaea is offline
post #272 of 5032 Old 09-17-2013, 09:15 PM - Thread Starter
dominguez1's Avatar
Quoted: 1109 Post(s)
Liked: 962
Originally Posted by MKtheater View Post
Probably giving the Cap 2400 a little too much there. How about this, the GH hits 122 dBs with a tapped horn higher excursion 18. The OS would come at maybe 118-120 dBs at 20hz and that is 6 dBs more than the Cap 2400 at 20 hz. I would think that 114 dBs would be a good estimate at 20hz. Same goes for 17hz.
Looking at some of the other subs:
The DIY XXX Ported monster comes in at 116@20hz and so does the DTS-10 kit.
The PB-13 Ultra comes in at 110db. So I think you're probably right. 114db sounds a bit more accurate considering the OS output is more as well.
Is it generally agreed upon that the GH would have more than the OS at 20hz?
dominguez1 is offline
post #273 of 5032 Old 09-17-2013, 09:17 PM
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6451
114db @ 20hz sounds more realistic...that is still a ton of output for a single sub.
basshead81 is offline
post #274 of 5032 Old 09-17-2013, 09:22 PM
MKtheater's Avatar
Quoted: 1717 Post(s)
Liked: 1251
Well the GH uses the LMS-5400 or UXL which should be good for a couple dBs and it is a tapped horn so it uses both sides of the driver for more output. If the GH gets 122 dBs I would bet 120 dBs for the OS and Jeff mentions this. The cap has less output than the OS and I thought he mentioned 6 dBs or so. The DTS-10 and XXX ported both sacrifice output at 20hz for more output down low which the numbers indicate.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
post #275 of 5032 Old 09-18-2013, 09:03 AM
desertdome's Avatar
Quoted: 1283 Post(s)
Liked: 1484
My score for my 8 Acoustic Elegance IB15HT system in my 2153 cubic ft room is 384@10Hz.
However, I crossover to my GR-Research LS6 speakers at 40 Hz and use shallow slopes. Since the WinISD prediction for the IB15HT is 4.5 dB higher than what is being used, I also dropped 4.5 db from the prediction for the LS6 speakers at 31.5 Hz. If I go with 31.5 Hz output (112.7 dB x 2) for the LS6's in combination with my IB15HT''s, then my total score is 299. I don't reroute LFE bass to the mains, but since I use a phantom center, my mains are playing bass from the L, C, R for movies.
High Impact AV
desertdome is offline
post #276 of 5032 Old 09-18-2013, 09:15 AM
MKtheater's Avatar
Liked: 1251
Still liking the LS6's? I wish you can hear these DR's in my room. I bet we could figure out what happened.
Anyways, I will list the scores of all my systems I have owned(DIY) at their wheelhouses!
Marantz 7702 Atmos
post #277 of 5032 Old 09-18-2013, 09:31 AM
MKtheater's Avatar
Liked: 1251
4 CHT 18.2: 284 at 10hz
2 DTS-10's: 133 at 16hz
8 eD 190v2 sealed: 255 at 10hz
4 eD LLT's: 173 at 12.5 hz
12 eD 13av2: 247 at 10hz
8 IB318: 125 at 10hz
Marantz 7702 Atmos
post #278 of 5032 Old 09-18-2013, 01:49 PM
desertdome's Avatar
Liked: 1484
I love them!
The problem was that I was level matching using a frequency sweep rather than an RTA (Bill Fitzmaurice suggested I use an RTA). A frequency sweep is gated to eliminate reflected sounds, especially in the higher frequencies, and only captures a narrow slice of direct sound. The 120 degree dispersion and the hard walls to reflect sound combined for 9+ dB of output at higher frequencies than what a frequency sweep shows. It wasn't until I did a bunch of measurements with the Wedgehorn 6's I got from you that I started to understand what was going on.
As an experiment, Carp (or anyone else) could take his three Noesis speakers and set them close together up front with the side speakers pointing outward at an angle. Put a 2000 Hz High pass on the sides. Measure with the test signal going just to the middle speaker and take a measurement. Now send the same signal through all three and take another measurement. The measurements would probably be similar, but the output in the higher octaves with all three speakers would be much greater when playing actual content.
High Impact AV
post #279 of 5032 Old 09-18-2013, 01:56 PM
MKtheater's Avatar
Liked: 1251
I see, makes perfect sense and if you ran them as dual stacked that would be 40 tweets running extremely hot! No wonder they made ears bleed.
Marantz 7702 Atmos
post #280 of 5032 Old 09-18-2013, 02:57 PM
desertdome's Avatar
Liked: 1484
I went to a live outdoor concert in July and they were flying a line array on each side of the stage. At the back of the audience, each line array was covering an area several hundred feet wide. However, the sound was very similar across the width (as I made a trip to the porta potty). I realized that if I took a frequency response sweep in one spot, it wouldn't really capture the overall combined dB across the whole coverage area. Now imagine taking that output and cramming it into a small room with hard walls. Of course four DR250's have less output than two flying line arrays, but according to Bill's website, they can provide coverage to 400 people. It probably helps a lot that you have so much absorption.
High Impact AV
post #281 of 5032 Old 09-18-2013, 04:57 PM - Thread Starter
dominguez1's Avatar
Liked: 962
So, you would be 384@10hz and 299@31.5hz if I understood you correctly.
Very nice!
post #282 of 5032 Old 09-18-2013, 05:00 PM - Thread Starter
dominguez1's Avatar
Liked: 962
Sounds like the best is yet to come MK. 247 to 125 should be around 6 more db of headroom...not like you needed it before!
post #283 of 5032 Old 09-18-2013, 05:01 PM
MKtheater's Avatar
Liked: 1251
In my room the array starts at seat level and goes to the top of the screen which is perfect for an array! I have also measured THD at the seats and at 105 dBs sine wave I was under 1% THD throughout except at 2.2khz which I had a null which created about 3 % THD at 105 dBs. I am hoping the baffle wall will get rid of that null but either way it is very clean at reference so all one has to do is balance the response correctly and BAM!
Marantz 7702 Atmos
post #284 of 5032 Old 09-18-2013, 05:06 PM - Thread Starter
dominguez1's Avatar
Liked: 962
Your build is done? Link please...
post #285 of 5032 Old 09-18-2013, 06:17 PM - Thread Starter
dominguez1's Avatar
Liked: 962
So, wrapping up the JTR ported/horn subs max output estimates (for the S1 and S2, we'll just use the UXL as reference):
Cap 2400 (20hz) = 114db at 20hz or 3.1SI
  • see above estimation methdology
Cap 2400 (15hz - plug for 20hz model) = 102db at 12.5hz or 2.9SI
  • Both the VTF-15H and the FV15HP between the 2 port mode vs 1 port mode, yield aprox. the same 20hz output. In the Cap's case this would be 114db.
  • They are also around 11db down from 20hz to 12.5hz. This would put the Cap at 103db at 12.5hz.
  • If it is 103db at 12.5hz, that is damn impressive...
  • Thoughts here?
Cap 2400 (17.5hz) = 112db at 16hz or 5.1SI
  • Slightly lower than tune at 16hz, so I deducted 2db from the output
  • 5.1SI?? Wow. Looks like we found the ULF sweet spot here for the cap...
OS 120db at 20hz or 6.2SI
  • Slightly less output than GH (122db) because is doesn't use both sides of driver like a tapped horn does.
If we agree, I'll update my Estimated chart on the first page.
post #286 of 5032 Old 09-18-2013, 06:34 PM
carp's Avatar
Quoted: 2787 Post(s)
Liked: 2102
  • Thoughts here?
I don't know about that 16 hz output. I've owned dual Caps and demo'd the song Bass I Love you a ton of times both with the Caps and my SI's. That note that shakes the hell out of everything is centered at 17hz and my SI's have a lot more output and shake on that note than my Caps did. Granted I was powering with and ep4000 but still, Archaea has commented that the best he's heard Bass I Love you is on the 8 SI's, and according to the above he would have 10.2 SI's. I don't think that can be right....
carp is offline
post #287 of 5032 Old 09-18-2013, 06:39 PM
carp's Avatar
Liked: 2102
The Cap is a beast though to be sure, I've held the driver and it has to be close to twice the weight of the SI driver.
carp is offline
post #288 of 5032 Old 09-18-2013, 06:50 PM - Thread Starter
dominguez1's Avatar
Liked: 962
Hmmm, good feedback.
Maybe you're leaving 2 dbs on the table with the EP4000 compared to the plate amp? If that were the case, it would put it at 110db which is 4.1SI. Still to high.
What if we said 110db at 16hz, and with the EP, it gets it down to 108db.
108db would put it at 3.2SI, which would end up being 6.4 SI for duals compared to your 8 SI.
post #289 of 5032 Old 09-18-2013, 07:05 PM
MKtheater's Avatar
Liked: 1251
The Rhytmik and HSU both are tuned around 12hz with one port and the cap is at 15hz so it would drop off faster at 12.5 hz than the others.
Marantz 7702 Atmos
post #290 of 5032 Old 09-18-2013, 07:05 PM
MKtheater's Avatar
Liked: 1251
Oh, the build is not done, still waiting on the drivers.
Marantz 7702 Atmos
post #291 of 5032 Old 09-18-2013, 07:07 PM - Thread Starter
dominguez1's Avatar
Liked: 962
Actually, the HSU is tuned at 17hz and 24hz as listed in Josh's review...
post #292 of 5032 Old 09-18-2013, 07:28 PM
MKtheater's Avatar
Liked: 1251
I don't know how the THD keeps low under tune.
Marantz 7702 Atmos
post #293 of 5032 Old 09-19-2013, 09:53 AM
GoCaboNow's Avatar
Quoted: 875 Post(s)
Liked: 765
Cool idea!
How are you figuring the IB setups? I have 4x Fi IB3 18's (2ohm) paired with a EP4000. Sealed, 2600cf. I also have two 12" subs in the back of the room. (Athena AS-P6000 cool.giftongue.gif)
My Dedicated Home Theater Room
GoCaboNow is offline
post #294 of 5032 Old 09-19-2013, 10:55 AM
MKtheater's Avatar
Liked: 1251
Originally Posted by GoCaboNow View Post
Cool idea!
433 at 10hz.
Marantz 7702 Atmos
post #295 of 5032 Old 09-19-2013, 06:51 PM - Thread Starter
dominguez1's Avatar
Liked: 962
Sounds like we've got 'silent' agreement on the JTR subs...I think what we've come up with is within +-3db of what Josh's test would reveal.
Here's the new estimated chart, also posted on post 2:
post #296 of 5032 Old 09-19-2013, 07:14 PM - Thread Starter
dominguez1's Avatar
Liked: 962
Member scores updated.
Also, I refined some of the categories from an above reference and reference output from a 'lowest frequency' standpoint; meaning you get in-room reference or above reference bass at least at the anechoic frequency listed and higher.
Look at the member scores collected thus far. Does that feel about right? Remember, it ain't perfect...accurate to +- a half star. But generally...
Also, for those member that I don't have amps listed, please let me know what you're running.
5 Stars - Above Reference Output
mktheater - 125@10hz - 2048cf - Infinite Baffle 8x18 FI IB3 powered by a fp14000 clone
popalock - 163@10hz - 2605cf - 16 x 18 SIs powered by a 2 fp14000 clones
dominguez1 - 232@12.5hz - 1900cf - Dual FTW-21 in sealed cabs powered by 2 ep4000s, Dual FV15HPs
laugsbach - 247@12.5hz - 3000cf - 4 CHT 18.1s, Ricci's DIY XXX Ported w/RE Audio MX-18 D2 Driver, both powered by EP4000s
lukeamdman - 112@16hz - 2500cf - Dual Gjallarhorns, Dual Othorns
siefer300 - 156@16hz - 1404cf - 4 CHT VS18.1, 2 Cap 1000's, powered by Crown XTI 4000s
4.5 Stars - Reference Output (10hz & 12.5hz systems), Above Reference (16hz and higher)
steveo1234 - 324@10hz 1300cf - 6 AE IB 15 (Infinite Baffle)
carp - 379@10hz - 3035cf - 8 x 18 SIs
desertdome - 384@10hz - 2153cf - 8 AE IB 15
dominguez1 - 432@10hz - 1900cf - Dual FTW-21 in sealed cabs powered by 2 ep4000s, Dual FV15HPs
GoCaboNow - 433@10hz - 2600cf - 4x Fi IB3 18's paired with an EP4000
cubalis2 - 561@10hz - 3200cf - 2 x LMS-U 18's FP14K clone, 2 x LMS-R 15"s dual opposed inuke 6000DSP
archaea - 565@16hz - 3500cf - 2 Passive Caps (20hz model) with Crown XLS5000 amps
4 Stars - Reference Output (16hz and higher)
wth718 - 700@10hz - 1400cf - 2 x 18 SIs
MikeDuke - 714@10hz - 1000cf - 1 SubM HP
laugsbach - 836@10hz - 3000cf - 4 CHT 18.1s, Ricci's DIY XXX Ported w/RE Audio MX-18 D2 Driver, both powered by EP4000s
landshark1 - 781@16hz - 2500cf - Dual PB12 Plus
basshead81 - 800@16hz - 2400cf - 3 PSA XV15's
3.5 Stars
cowboys - 1400@12.5hz - 2660cf - Rythmik FV15HP (550w)
reddig - 1326@16hz - 1856cf - Dual  HSU VTF-2 MK4s
3 Stars
eNoize - 2066@12.5hz - 2500cf - HSU VTF-15H
qguy - 1954@20hz - 1368cf - Rythmik F15
2.5 Stars
None
2 Stars
tenderchkn - 3500@16hz - 3500cf - PSA XV15
1.5 Stars
SupaKats - 4761@16hz - 4600cf - Outlaw LFM1-EX
1 Star
None
post #297 of 5032 Old 09-19-2013, 07:33 PM
MKtheater's Avatar
Liked: 1251
My room will be 1547 cubic feet once the wall is done and it was 1820 for reference.
Marantz 7702 Atmos
post #298 of 5032 Old 09-19-2013, 08:39 PM
stereo2.0's Avatar
Quoted: 23 Post(s)
Liked: 29
Hey Dominguez1, could you add my info to the list?
stereo2.0 - 515@16Hz - 3500cf - single DTS-10, powered by a Proton D1200.
stereo2.0 is offline
post #299 of 5032 Old 09-19-2013, 08:51 PM - Thread Starter
dominguez1's Avatar
Liked: 962
post #300 of 5032 Old 09-19-2013, 09:20 PM
MKtheater's Avatar
Liked: 1251
I told many that for the $995 kit price they were a no brainer!
Marantz 7702 Atmos
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
