Your Home Theater ULF Score - Page 107 - AVS | Home Theater Discussions And Reviews
 243Likes
post #3181 of 3184 Old 04-25-2015, 10:29 AM
coolrda's Avatar
Quoted: 83 Post(s)
Liked: 82
Originally Posted by dominguez1 View Post
@coolrda ,
Does your riser have a resonant frequency or tune?
@Luke Kamp ,
I saw you posted that you built your riser, and tuned it to 10hz? Was that on purpose, IOW, did you play around with tuning?
Would love to see any tactile response measurements of your risers if you have them.
While it does, It may not come it play here. By that I mean that even if it resonates it could be so small as to not effect the overall response. Even if it was measurable it would be completely covered up by the fact that your seating's mass is probably a 100x or more compliant. I want a stable riser that feels solid as concrete but has a lighter mass and that what this provides. I believe and I'm finding TR can be changed/tuned somewhat by what you put on and don't put on the Riser. I'll go into more detail later. Remember the point is to decouple/free mass to Intensify tactile response. Whether its 10x, 100x, 1000x or more, this is what should be desired, a stable non intrusive platform that allows the full power of our sub systems to be realized.
coolrda is online now
post #3182 of 3184 Old 04-25-2015, 11:51 AM
Luke Kamp's Avatar
Quoted: 70 Post(s)
Liked: 134
Here is a thread on the Auralex product and why you might need to play around with how many are used for best results.
https://www.gearslutz.com/board/phot...ally-work.html
This post by Eric Desart
The problem with the U boats of Auralex is that they give no technical data.
An U boat is an elastic decoupler with a handy U shape to keep it in place.
Auralex gives no technical information whatsoever about dynamic stiffness making it not possible to calculate whatever.
Possible alternatives are CDM, Sylomer, Kinetics stuff and lots if others.
A good floating floor should be around 10 Hz MSM (mass-spring-mass) (lower is better) and not exceed around 16 Hz.
This value for +/- linear springs (the elastic U-boats or any alternative for that matter) is directly related with the deflection of the elastic material under static load.
Hence even without knowing the dynamic stiffness or the physical principles you can test and measure this yourself.
You have a good floating floor if your deflection is around 2 to 3 mm under static load.
Hence ANY elastic material can only be judged within a total construction taking top and floor mass into acount.
The same material can result in a bad or a perfect floor.
You can influence this deflection by in- or decreasing the number of U boats per surface unit, or by in- or decreasing the mass of the top floor.
The relation between MSM and deflection can be rather exact calculated from:
In metric
d = (15.8/fo)^2
fo = 15.8/sqrt(d)
where >>>
d = defection in mm
fo = MSM (mass-spring-mass resonance in Hz)
In Imperial
d = (3.13502/fo)^2
fo = 3.13502/sqrt(d)
where >>>
d = defection in inches
Hence you can easily see that the mass of this top floor, and the spread of the pads or U-boats is very defining.
The basic idea of ANY decoupler is to load them to the maximum technical allowed static load.
Underloading a decoupler will give the false feel of additional safety and more stability, but will cause loss in acoustic decoupling quality which should be avoided if possible.
A rough rule of thumb, in order not to overload such materials is that the deflection should not exceed ca 10% of the initial material thickness. But this can depends a bit on the type of material, the edge factor and so on. E.g. the standard sylomer types will be somewhat less, rubbers can be somewhat more. Best of course is that the supplier provides useful data to work with.
There are 2 main types: compressible decouplers (volume material decreases under load = foam or fibre like stuff) and deformable decouplers (the volume does not decreases or hardly, but the material deforms expanding sideways = rubber like stuff). This latter type doesn't work anymore when you prevent them to expand sideways under load.
Another good rule of thumb is making the top floor as heavy as possible.
That way the relative comparison of temperary loads as e.g. people become less defining.
The more spare (relatively) you have to foresee in order to cover these temperary loads the higher the MSM will become when these loads aren't present + are standard too high (since underloaded) on these spots where such loads aren't present.
I CERTAINLY should put mineral wool (fiberglass or rockwool with low density in that cavity since it does influence STC rather strongly (certainly with a light topfloor). And it also helps to diminish a drumskin effect of such a floor.
If hygro-thermal problems should be involved that's more a matter of the correct use of a good vapour barrier (dampscreen).
A further good improvement is the use of Green Glue which diminishes flanking extremely, makes that floor more dead (drumskin effect) and additionally increases TL somewhat.
About the John Sayers topic I agree with nosebleedaudio.
That topic arose strongly in function of typical drywall separations in a studio setup, where they meant that it has no sense to additionally strengten a link in a chain when the overall TL is defined by the TL of the walls anyhow.
Real high insulations need very low MSMs and can't be obtained with such applications, needing very large deflections. End post
I have been looking around and wonder if these FDS springs may be something worth looking into?
http://www.kineticsnoise.com/hvac/pdf/fds.pdf
Luke Kamp is offline
post #3183 of 3184 Old 04-25-2015, 02:21 PM
coolrda's Avatar
Quoted: 83 Post(s)
Liked: 82
Good info, Luke. I actually saved that web page several years back and read it again a couple times prior to building my latest platform. Like he states no data available probably because of the cost to do lab testing.
post #3184 of 3184 Old 04-25-2015, 08:04 PM
BassThatHz's Avatar
Quoted: 756 Post(s)
Liked: 650
Originally Posted by popalock View Post
Looky looky what came in the mail yesterday!
Careful, one day they might be able to reverse engineer DNA from fingerprints found in jpeg's. You just unwittingly gave the NSA your DNA! You'll now be cloned as a Universal Soldier. (Dolph Lundgren approves this message!)
BassThatHz is offline
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
