Your Home Theater ULF Score - Page 125 - AVS Forum | Home Theater Discussions And Reviews
 351Likes
post #3721 of 3743 Old 08-18-2015, 05:16 PM
lovinthehd's Avatar
Quoted: 2059 Post(s)
Liked: 2458
Time for an update, new card calc'd attached.....I'm gettin' there.
lovinthehd is online now
post #3722 of 3743 Old 08-18-2015, 06:19 PM
derrickdj1's Avatar
Quoted: 347 Post(s)
Liked: 254
You are in a large room like I am. I like the addition of the Clarks, it will save you the headaces of a gazillion sub, lol.
derrickdj1 is online now
post #3723 of 3743 Old 08-22-2015, 08:22 AM - Thread Starter
dominguez1's Avatar
Quoted: 335 Post(s)
Liked: 276
I think you fat fingered the ULF calculator somewhere...
Here's what I calculated your ULF Card to be:
dominguez1 is offline
post #3724 of 3743 Old 08-22-2015, 08:25 AM - Thread Starter
dominguez1's Avatar
Quoted: 335 Post(s)
Liked: 276
I don't believe we have many (if any) RA Home Theaters or new Captivator 1400 theaters on the ULF charts yet...
Come join and post your ULF cards!
post #3725 of 3743 Old 08-22-2015, 10:33 AM
derrickdj1's Avatar
Quoted: 347 Post(s)
Liked: 254
Any data on the Mini Marty which is just a tad bit smaller than the full Marty? I will finished the second Mini Marty this week.
post #3726 of 3743 Old 08-22-2015, 01:19 PM - Thread Starter
dominguez1's Avatar
Quoted: 335 Post(s)
Liked: 276
No, but would like to get the Marty's on here.
If anyone can run a sim comparing to the SI in a sealed 4cf box (same enclosure size as data-bass), I can estimate.
post #3727 of 3743 Old 08-25-2015, 11:17 AM
derrickdj1's Avatar
Quoted: 347 Post(s)
Liked: 254
Why a seal SI box since the Marty and Mini Marty are ported? I will download WinDis and see how far I get trying to do a sim.
post #3728 of 3743 Old 08-25-2015, 06:14 PM
coolrda's Avatar
Quoted: 231 Post(s)
Liked: 202
The ULF score card is based on the SI HT18D2 in a sealed box. See first post here.
coolrda is online now
post #3729 of 3743 Old 08-25-2015, 07:10 PM - Thread Starter
dominguez1's Avatar
Quoted: 335 Post(s)
Liked: 276
As coolrda said...
If you run both the si sealed at the marty, I'll take the difference between sims to estimate what the marty would be relative to josh's testing of the si.
post #3730 of 3743 Old 08-25-2015, 08:11 PM
MKtheater's Avatar
Quoted: 855 Post(s)
Liked: 732
Using the SI 18HT you gain 9 dB at 20hz, 12 dB at 16hz, and anything lower will be distortion as the x-max is off the charts so I did not take notice at the 12.5hz and 10hz. When I did all those sims it was based on the SI being able to reproduce 5hz at x-max sealed so if you HP the low stuff you will gain 3 dB on the sealed with double the power.
MKtheater is online now
post #3731 of 3743 Old 08-25-2015, 09:40 PM
coolrda's Avatar
Quoted: 231 Post(s)
Liked: 202
Here's what I came up with using WinISD on WindowsXP. Red is MiniMarty, Blue is MartyCube and Yellow is Ref Sealed. The two Marty boxes were using data and subs listing on the Martysub FAQ.
Max SPL@1M Frequency 10/12.5/16/20/25/31.5/40/50
MiniMarty 89.3/99.4/112.4/115.5/116.6/117.4/117.9/118.3
MartyCube 87.6/97.1/104.5/109.1/112.7/115.4/117.1/117.9
Ref Sealed 94.5/98.2/102.3/105.8/109.1/112.2/114.7/116.3
dominguez1 likes this.
post #3732 of 3743 Old Yesterday, 08:55 AM
derrickdj1's Avatar
Quoted: 347 Post(s)
Liked: 254
Thanks for the explanation guys. The main thing I was trying to accomplish was to increase the 15 Hz and up spl since I am still dealing with a large room. I am using the UM 18 in the Mini and full Marty subs. The full Marty will be around 20 ft. from the MLP.
My system does not incorporate nearfield and is a distributed bass system due to the room layout. One guy put some Infinity 12's behind his last role of seating. I will see how this performs before considering that option to take advantage of the PV from nearfield subs.
I will run the Mini and full Marty with port 1/4 port plugs in the slots at the bottom which is how I run the 2 other large vented UM 18 subs. This should give me just a wee bit of extension
Here are a couple of pic's of the full Marty that I just finished painting this AM and the Mini Marty next to my old Chase SS 18.1 box. The Mini is alinged on the right with the chase sub. It looks like I could almost put two of the Chase boxes in the Mini, lol.
I will run the Mini and full Marty with 1/4 of the port blocked at the bottom for a wee bit of extension. I have did this with the other large vented UM 18 subs.
ID:	908706   Click image for larger version
post #3733 of 3743 Old Yesterday, 05:31 PM - Thread Starter
dominguez1's Avatar
Quoted: 335 Post(s)
Liked: 276
Thanks @coolrda !
What is the tune of the MiniMarty? How about the Marty Cube, or is that a sealed design?
Also, is the driver the SI in the Marty's or the UM18?
post #3734 of 3743 Old Yesterday, 05:33 PM - Thread Starter
dominguez1's Avatar
Quoted: 335 Post(s)
Liked: 276
You've definitely got the disease sir... Well done!
post #3735 of 3743 Old Yesterday, 05:50 PM
coolrda's Avatar
Quoted: 231 Post(s)
Liked: 202
Originally Posted by dominguez1 View Post
Thanks @coolrda !
Copied from @chalugadp 's post
Martycube
volume = 4.75 c.f. , tuning=20hz SI HT18
Minimarty
volume = 9.0 c.f. , tuning=18hz Ultimax 18
post #3736 of 3743 Old Yesterday, 07:28 PM
coolrda's Avatar
Quoted: 231 Post(s)
Liked: 202
I can't believe its been two and a half weeks. Healing up nicely and I got a ton of stuff done including some stuff I didn't plan on fixing. So tomorrow starts phase two which is cool because it includes theater work. Anyway I got in some playtime today. Lots of VSensor testing and more importantly the sub relocate as 4x15's will be placed under the screen. The front subs were relocated to their permanent home at the rear.
And EoT before .......
and after, a few db down.
Scott Simonian likes this.
post #3737 of 3743 Old Yesterday, 08:28 PM
coolrda's Avatar
Quoted: 231 Post(s)
Liked: 202
Heres a few more before and afters.
Looking at the LogPSD we see gains of 7/13/4/7/2 units(db) respectively at 10/15/20/25/30hz. Apparently the front rear arrays were interacting causing the 15hz null. So the huge gain at 15hz is a combination of null removal and near field placement, not one or the other. The other frequencies fall in line with what you would figure on if you co locate subs and double the numbers.
How does this feel? Like a physical assault on the body. It feels like 3x the TR or more. Approaching 1g@10hz combined with the pressure I'm feeling is lunacy. Make no mistake, I'm not giving it back, but, its more that anyone could stand for more than 10 mins. Jupiter Ascending was brutal. Course theres always the I wonder what that would feel like. This is the first time I can say my system sounds balanced regarding TR and SPL quantity. Spl and pressure has always dominated. But no longer. More to come.
post #3738 of 3743 Old Today, 03:59 AM
3ll3d00d's Avatar
Quoted: 744 Post(s)
Liked: 226
some data from @markymiles who has just dropped in a pair of 1260w (in ~2.5-3ft3 sealed I think) behind his sofa while he waits for his UXL-18 to arrive, no other subs in the room at all. I think that shows about +/- 0.5g peak which is pretty nice going.
3ll3d00d is online now
post #3739 of 3743 Old Today, 09:04 AM
coolrda's Avatar
Quoted: 231 Post(s)
Liked: 202
The new data is greatly welcomed. Thanks @markymiles . Great performance out of a popular sub around here. It makes you wonder wants the point of placing subs anywhere but nearfield.
I mentioned this before but might add that if your making a test run with EoT clip, pause the clip @20Seconds . Set VS to this.
Then start the VS and then the clip when delay zeros. This will give you 3 sec bookends on the 14 sec clip. This helps with the limited display of our devices used.
post #3740 of 3743 Old Today, 09:13 AM
markymiles's Avatar
Quoted: 43 Post(s)
Liked: 27
Yeah understood re the measuring. I didn't even know about this thread which is why matt posted it here. Wish I had known as it was mostly guesswork on the app.
Is this better? Played it a touch louder, I think it's getting near the limit.
markymiles is offline
post #3741 of 3743 Old Today, 09:59 AM
coolrda's Avatar
Quoted: 231 Post(s)
Liked: 202
Much better, nicely done. I'll add it to the database. What phone/PED are you using?
post #3742 of 3743 Old Today, 10:14 AM
markymiles's Avatar
Quoted: 43 Post(s)
Liked: 27
Motorola Moto G. Don't know why they have ended up so extreme close up .
post #3743 of 3743 Old Today, 04:58 PM
lovinthehd's Avatar
Liked: 2458
While I have no doubt in my abilities to fat finger....where's my Epik Empire in your calc? Isn't that .7 of an SI? I did think the totals in mine looked too good but would have to go look at my first calc again....
NM, just looked at that 3.0 in the 10hz column for a sec and looking back at my first card think the fat fingering goes back to that one.... Back to building subs....
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
