Your Home Theater ULF Score - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 715Likes
post #361 of 5011 Old 09-26-2013, 09:15 PM
HopefulFred's Avatar
Quoted: 510 Post(s)
Liked: 453
HopefulFred is offline
post #362 of 5011 Old 09-27-2013, 07:30 AM
MKtheater's Avatar
Quoted: 1706 Post(s)
Liked: 1238
THat shows the 15 to be 3 dBs less than the 18 so I guess you can say it is 3 dBs less at 10hz or around 83 dBs to the SI's 89.2 dBs.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
post #363 of 5011 Old 09-27-2013, 07:52 AM
MKtheater's Avatar
Liked: 1238
I get 85.1 for the Dayton driver so I am not sure how big your room is.
Marantz 7702 Atmos
post #364 of 5011 Old 09-27-2013, 07:49 PM
Quoted: 510 Post(s)
Liked: 453
It's 2300 cubes - give or take - mostly take. . Thanks for the help guys!
post #365 of 5011 Old 09-28-2013, 05:48 AM
JapanDave's Avatar
Quoted: 170 Post(s)
Liked: 124
I'll play,
Half my subs running, not max SPL in a 3600cf room. How do you figure out a score for IB?
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #366 of 5011 Old 09-28-2013, 07:05 AM
carp's Avatar
Quoted: 2782 Post(s)
Liked: 2089
Originally Posted by JapanDave View Post
I'll play,
carp is offline
post #367 of 5011 Old 09-28-2013, 07:59 AM
Ricci's Avatar
Quoted: 240 Post(s)
Liked: 566
Dave yours should be about the same as mine. Let's just assume its somewhere between don't worry about it and -13
Ricci is online now
post #368 of 5011 Old 09-28-2013, 08:03 AM - Thread Starter
dominguez1's Avatar
Quoted: 1096 Post(s)
Liked: 932
Thanks MK!
Room size in cubic feet 2300
Hz SI Sub/Driver Your Sub's lowest freq's max output (ground plane) dB Difference Equivalent SI(s) Quantity Total SI(s) HT ULF Score
 (cf per SI)
10 89.2 UM15-22 85.1 -4.1 0.6 4 2.4 958
This puts you at 4 Stars! Nice!
dominguez1 is offline
post #369 of 5011 Old 09-28-2013, 08:54 AM
MKtheater's Avatar
Liked: 1238
Dave and Ricci, you guys have the most displacement I know of, so it depends on room size. WE are just getting an idea on what people might be experiencing in their rooms compared to others. Basically, A 12 inch sub in a small closet can feel like 8 REXXX's in a theater. Small room equals lots of savings!
Marantz 7702 Atmos
post #370 of 5011 Old 09-28-2013, 09:00 AM - Thread Starter
dominguez1's Avatar
Liked: 932
I'll play,
What the ?? :eek:
102db @ 2hz??? 1/2 your subs running, not max SPL? This is sick...do you get sick when you watch movies? ;) :D
Let me dig through this thread...I thought MK estimated that for IB.
post #371 of 5011 Old 09-28-2013, 09:00 AM
MKtheater's Avatar
Liked: 1238
JapanDave,
Your score is 171 at 10hz with 8 drivers running!
Marantz 7702 Atmos
post #372 of 5011 Old 09-28-2013, 09:05 AM - Thread Starter
dominguez1's Avatar
Liked: 932
JapanDave,
Cool, what max output did you use for the XXX IB?
Also...again, this is a rough estimate on your ULF experience, so I wouldn't get to hung up comparing exact ULF scores. To be exact, you have to factor in more things. IIRC, I think Dave's room has ALL concrete walls around his room? Hardly any output (if any) is lost through walls, and goes right back into the room!
Another 5 star ULF Theater!
post #373 of 5011 Old 09-28-2013, 09:11 AM
MKtheater's Avatar
Liked: 1238
I used 8.4 dBs more than the SI. I use the same winisd sims for all drivers. The XXX was limited at DB with a small box. Just use the chart I posted. All the numbers I posted are from that chart. Again these numbers say nothing about distortion and if the driver rolls off as simulated. Data-bass shows that info except some drivers were not in their ideal boxes. Also I am using power for 5 hz x-max. To give an idea the sim shows the SI hitting 95.3 dBs at 10hz with 897 watts reaching x-max at 5 hz.
Marantz 7702 Atmos
post #374 of 5011 Old 09-28-2013, 09:19 AM - Thread Starter
dominguez1's Avatar
Liked: 932
post #375 of 5011 Old 09-28-2013, 11:02 AM
MKtheater's Avatar
Liked: 1238
I will have to redo them
Marantz 7702 Atmos
post #376 of 5011 Old 09-28-2013, 04:27 PM
JapanDave's Avatar
Quoted: 170 Post(s)
Liked: 124
Hey Ricci, I did forget to mention that I ended up getting another XXX 18" like you suggested. So I have 4 drivers up the front and 4 drivers down the back of the room now.
My build thread
post #377 of 5011 Old 09-28-2013, 04:30 PM
JapanDave's Avatar
Quoted: 170 Post(s)
Liked: 124
JapanDave,
Thanks MK, I would love to know how you got that number, I got lost half way through the first post.
My build thread
post #378 of 5011 Old 09-28-2013, 04:37 PM
JapanDave's Avatar
Quoted: 170 Post(s)
Liked: 124
Thanks, and you are correct. All concrete walls, floors and ceiling. If you want to feel a solid 10" concrete floor flexing, come and stand above my basment while WOTW is playing.
My build thread
post #379 of 5011 Old 09-28-2013, 04:55 PM
carp's Avatar
Liked: 2089
Wow man that's unreal!!
That's another factor that makes it hard to score our rooms; I guarantee I'm losing a lot of low end due to the ceiling and walls flexing which makes your room all the more impressive.
James, isn't your room similar to Dave's? Lots of concrete?
carp is offline
post #380 of 5011 Old 09-28-2013, 05:43 PM - Thread Starter
dominguez1's Avatar
Liked: 932
MK ran winisd for the XXX (in an optimal sized box) and the SI (MK's chart above). The XXX was 8.5db higher than the SI in that sim.
Josh tested the SI @10hz and measured an output of 89.2.
XXX = 89.2 + 8.5 = 97.7db at 10hz
Using the calculator attached to the first post, 1 XXX = 2.7SI. Since you have 8, it would be 8 x 2.7 or the equivalent of 21.6 SIs in your room!!!! :eek:
To calculate your ULF score, it is room size in cubic feet / subwoofage in SI
3600 / 21.6 = 167 ULF Score. (MK is probably using an older version of the calculator where it was carrying all the decimal places and why he got 171).
post #381 of 5011 Old 09-28-2013, 06:01 PM
JapanDave's Avatar
Quoted: 170 Post(s)
Liked: 124
Using the calculator attached to the first post, 1 XXX = 2.7SI. Since you have 8, it would be 8 x 2.7 or the equivalent of 21.6 SIs in your room!!!! eek.gif
OK, I see now. So I should not be including the space behind the wall where the IB subs lie correct? The actual cubic ft of the space? In that case, my room total volume will be about 2900 cf.
So 2900 / 21.6 = 134
So the lower the score the better I am guessing?
My build thread
post #382 of 5011 Old 09-28-2013, 06:29 PM - Thread Starter
dominguez1's Avatar
Liked: 932
That's right, don't include the space behind the wall, and yes lower is better! 134 is your score then!
Based on the scoring range below, that places you in the 5 star category (as if you needed reassurance...).
Regardless of score, Dave I have to think you hold the 'real' ULF record of all AVS members (and likely non-members). Not only because of your crazy displacement, but the 10inch concrete walls, ceiling, and floor! MK is close with 3 walls and the floor concrete!
post #383 of 5011 Old 09-28-2013, 06:54 PM
MKtheater's Avatar
Liked: 1238
Yup, well actually I built all my walls out of double drywall and double layer sound board with insulation in between. The floor is carpet over concrete. Beyond all the walls is a concrete basement or all walls of concrete. The only non concrete barrier is the ceiling and guess where all the bass goes, up there and destroys all the marble flooring directly above! So I built a room within a concrete bunker surrounding it. The problem with the room is that before the SPL's can get too crazy the pressure from the bass will blow your ears out. When I pin the meter my ears plug up all the time. When I watch a movie with max 125 dBs peaks the ears don't plug and that was with a score of 247! All this extra stuff won't even be used so I guess it will just be lower distortion now.
Marantz 7702 Atmos
post #384 of 5011 Old 09-28-2013, 07:13 PM
JapanDave's Avatar
Quoted: 170 Post(s)
Liked: 124
I hear that! No pun intended.
One of my favorite things to do when testing is to plug the ears and let WOTW's rip above reference, the visceral experience literally rips your insides apart!
MK, have you thought about building a small 1-2" hollow riser? Even though the concrete floor now transmits vibrations as it is now, I was thinking of doing this to further increase the visceral experience.
My build thread
post #385 of 5011 Old 09-28-2013, 07:40 PM
MKtheater's Avatar
Liked: 1238
My back row of seats are on a riser which does shake more but the back row is blocked by the front row and the front row you can feel the waves or air move you like a wind tunnel. If I build a riser for the front seats it will block the view of the back row. I have been thinking of just having one row of 5 seats with a riser and forget two rows.
Marantz 7702 Atmos
post #386 of 5011 Old 09-28-2013, 08:00 PM
JapanDave's Avatar
Quoted: 170 Post(s)
Liked: 124
I just have 3 seats in my theater, but I don't have anybody over so no need. How wide is your theater to fit 5 seats?
My build thread
post #387 of 5011 Old 09-28-2013, 08:08 PM
MKtheater's Avatar
Liked: 1238
Not wide enough that is why I have not done it. It would almost fit but no go. I need to make this work some how. My kids will use the theater much more as they grow so maybe I should just leave it.
Marantz 7702 Atmos
post #388 of 5011 Old 09-30-2013, 04:35 PM - Thread Starter
dominguez1's Avatar
Liked: 932
Hey MK, any luck on that graph? Alternatively, you could just post the difference for each of those drivers compared to the SI, and I will update my chart.
post #389 of 5011 Old 09-30-2013, 06:59 PM
MKtheater's Avatar
Liked: 1238
Tomorrow
Marantz 7702 Atmos
post #390 of 5011 Old 10-01-2013, 07:08 AM
MKtheater's Avatar
Liked: 1238
Marantz 7702 Atmos
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
