Your Home Theater ULF Score - Page 141 - AVS Forum | Home Theater Discussions And Reviews
 522Likes
post #4201 of 4762 Old 03-12-2016, 09:12 AM
MKtheater's Avatar
Quoted: 1589 Post(s)
Liked: 1116
Yeah, I hit print screen and then when I paste to paint it is tiny. The settings have to be setup wrong.
Marantz 7702 Atmos
MKtheater is offline
post #4202 of 4762 Old 03-12-2016, 09:16 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
Originally Posted by bgtighe23 View Post
Hey Dom, MK, and Derrick -
TL;DR (and some laziness ) is that vibsensor thing a phone app?
I was asking because I haven't given much thought into it until now. I purchased 2 SI HT18s which will be powered by an iNuke 3kDSP to go along with my 2 UM-18s (6kDSP) which are already up front. The HT18s are going to be placed on each side of the LP so that makes each HT18 about 3 ft away. All sealed 4 cu. ft. cabs.
My room is about an 1150 - 1200 cu. ft. closed off room so I'd figure I would try to get more involved now (well, by next week) that I have a better score card.
Tracking from PE and UPS says all that extra stuff (SpeakOn, disconnects, etc.) should be on Tues, March 15th. Hopefully I can assemble the cabs after work a couple days out of the week and finish them on that weekend to have them up and running no later than Sunday the 20th.
I hate and love my small room....Thanks.
EDIT: Proposed new card - just the addition of the HT 18s (which adds about 6dB)
Nicely done...what was your score prior to the HT18 additions? I'm sure you're in for a HUGE difference, especially placing them nearfield.
The Vibsensor is on both the Android and iPhone platforms. Give it a whirl...
I will be adding VS results to the ULF Score. Check out the new format:
dominguez1 is offline
post #4203 of 4762 Old 03-12-2016, 09:18 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
Copy and paste the ULF Score Card cells into paint, that should fix your problem...
post #4204 of 4762 Old 03-12-2016, 09:41 AM
MKtheater's Avatar
Liked: 1116
I will try it out.
Marantz 7702 Atmos
post #4205 of 4762 Old 03-12-2016, 09:44 AM
MKtheater's Avatar
Liked: 1116
This is what happens.
Marantz 7702 Atmos
post #4206 of 4762 Old 03-12-2016, 10:17 AM
bgtighe23's Avatar
Quoted: 1506 Post(s)
Liked: 841
Subtract about 6 dB from my scorecard and that's what it was with just the UM-18s. But since the new HT18s are going to be near field, I'm sure I'll get some extra tactile response.
Will the 5hz card now be included? I know that it's on a separate sheet currently, but it would be nice if its "all in one".
The new card looks nice. I'll take a swing with the app now with just the UM-18s and get some results posted. I'm sure adding near field 18s will make a huge difference.
EDIT: VibSensor app > setting > frequency range > high or low? Default was high, so I'd figure I would just ask.
Another Edit: Not now...
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 3 Towers/RBH R5Bi Front and Rear Heights
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is online now
post #4207 of 4762 Old 03-12-2016, 10:30 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
You have to size the 'white part' in paint (essentially get rid of it), so it's just the ULF card. Try that.
Also, if that doesn't work, try the snipping tool...if you have Windows, you should already have it. Make when you snip, the spreadsheet is at 100% zoom.
post #4208 of 4762 Old 03-12-2016, 10:33 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
The 5hz card is by invitation only . Why? You have to show your response to 5hz to get it.
Check out the Vibsensor thread...it will tell you how to use it, etc.
The VibSensor Accelerometer Test Thread
post #4209 of 4762 Old 03-12-2016, 10:44 AM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
Read over the first couple of pages of the Vibsensor thread. This will help with setup and understanding.
derrickdj1 is offline
post #4210 of 4762 Old 03-12-2016, 10:54 AM
coolrda's Avatar
Quoted: 852 Post(s)
Liked: 614
Just to add. Yes high is correct. Low is for averaging when running a long test. Because we're limited to the small graphs, unless your using a tablet or in the case of @3ll3d00d , using a separate program with VS upload data file, it's best to keep all test runs under 30secs.
coolrda is offline
post #4211 of 4762 Old 03-12-2016, 11:36 AM
bgtighe23's Avatar
Liked: 841
I appreciate all the responses. This guy Dom up here takin applications for the 5hz club... I'll be there...I'll be there...
post #4212 of 4762 Old 03-12-2016, 02:21 PM
Okv
Okv's Avatar
Quoted: 101 Post(s)
Liked: 88
Originally Posted by DotJun View Post
Too bad mk doesn't have his dts or f20s still cause I'd love to see a comparison of port vs horn now.
A well tuned horn will have better impact across a wider frequency range, higher up in frequency, as well.
For a direct compare the horns would have to be tuned just as low as the ported, and that is easy to do on paper but the size will make it impractical, at least you would have to design something to build on location.
dominguez1 likes this.
I am Øyvind Kvålsvoll, owner and founder of Kvålsvoll Design.
Okv is offline
post #4213 of 4762 Old 03-12-2016, 02:42 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
@MKtheater ,
Can you play the 6hz helicopter scene that you love with the Vibsensor? Would be interesting to see what kind of results you get there.
@coolrda , any luck on the 5hz sample in your HT? Also need a 12.5hz sample to complete your ULF card.
post #4214 of 4762 Old 03-12-2016, 02:53 PM
MKtheater's Avatar
Liked: 1116
My ported sub system is 248 cubes, the horn would be the size of my 1430 cubic ft room!
post #4215 of 4762 Old 03-12-2016, 03:03 PM
bgtighe23's Avatar
Liked: 841
What movie?
post #4216 of 4762 Old 03-12-2016, 03:47 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
post #4217 of 4762 Old 03-12-2016, 07:41 PM
MKtheater's Avatar
Liked: 1116
When I get to my office computer tomorrow I will upload my vibsensor of the seat over from the middle closer to the ports of one of the back subs. It was over .5 g at 10hz and over 1g at 25hz or 20hz, I have to look. My friend came over to listen and he said it is night and day from the sealed to the SLLT. BTW, I would not give up the low end from my sealed for the increased TR without the low end with a higher tuned ported sub. I will run Lone Survivor tonight, I don't remember if I ever took a reading with the IB to compare.
derrickdj1 likes this.
post #4218 of 4762 Old 03-12-2016, 10:20 PM
coolrda's Avatar
Quoted: 852 Post(s)
Liked: 614
Should have been done but I got side-swiped by all the immersive audio threads. I'm refocused now. Here's the deal. I do have all those but soon as you mentioned the 5 & 12.5 it got me thinking that we need a complete test track suite made. I haven't had time to even check out @Okv 's new 7.1 test tracks which needs to be incorporated. Then I thought why stop at 1/3 oct when we might as well go 1/6 octave level matched -.01dbfs. Then, narrow band or wide and on and on. So, my thought is, instead of random, off the wall, throw everything in the pot, type testing, lets everyone put our heads together and come up with one awesome test suite. We need something all encompassing that thoroughly runs through a series of tests quickly. We have a good grasp of measuring FR&TR, so let's take the time so we don't waste more time later. For example, EOT served its purpose well, but it's a rising curve as frequency drops Nd there square waves, etc. We need legitimate test tracks with match levels and consistent duty cycles. We need sines and impulse. We need various sweeps as well and then a few short, well doc'd, movie demo's. Then make the files or iso available to everyone. The new scorecard with then be a major step forward. Now this scorecard will be even more valuable, during the HT design/layout stage, to troubleshoot rooms that aren't performing as expected and to test all types and classes of gear. We can hear you and MK describe the experience of vented and sealed but graphs are graphs. I know exactly the TR gain MK experienced between the two systems because I know what that gain feels like. That's my opinion. Whatcha think?
coolrda is offline
post #4219 of 4762 Old 03-12-2016, 10:49 PM
MKtheater's Avatar
Liked: 1116
That BEQ scene of Transformers 2 starts at 30hz and goes down to 1hz with real content. I need to look up at data-bass what the digital signal is because mine has my frequency response involved or my room. I am completely starting over with my sound panels as I just made 10 4 inch panels and 4 6 inch panels which will be added to my 8 2 inch panels and 4 small 4 inch panels. I am going to treat all the first reflection points from all speakers including ceiling as I am curious if they all meet in the middle somewhere on the ceiling. The 6 inch will be open back corner traps which will absorb from both sides.
post #4220 of 4762 Old 03-13-2016, 07:28 AM
MKtheater's Avatar
Liked: 1116
Here is the seat next to the MLP which I sit in when I have company, or seat number 2.
I will have to try this again because the phone was moving and settles in a creased which caused that lower 15hz portion.
Marantz 7702 Atmos
post #4221 of 4762 Old 03-13-2016, 12:18 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
I like it, and am with you....but, we just have to keep in mind that the scorecard needs to remain simple to get more broad adoption. The ULF score was more about your systems capability, rather than what's really going on in-room. I do think the two would be fairly close (with in-room likely showing better performance). The ULF score assumes that you can optimize your room, FR, etc. to get the most out of it.
Adding the VS data is somewhat straying from the original principle as we're integrating the ULF score with actual measured results...but unfortunately, there is no other way to get this information without using VS. So ultimately, it will be a hybrid.
Having said that, Frequency Response, Speclab graph, and VibSensor would represent the pinnacle of information to really describe the experience you have in your room. That should be the norm when trying to optimize your system. The ULF card is more about showing you your systems minimum potential; FR, SL, and VS will give you the tools to optimize it all to meet and most likely exceed the ULF card.
Ultimately, I'm all for exactly what you described! Just need an easy way to pull out the 1/3 octave info to match up with the ULF card.
coolrda likes this.
post #4222 of 4762 Old 03-13-2016, 12:22 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
Damn...1G puts you in the "Violent" category...
Run the Lone Survivor clip! Curious to see what VS does with 5hz range.
post #4223 of 4762 Old 03-14-2016, 04:36 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
No comparison but not really fair, the F20 dropped off at 15hz and I did not have enough DTS-10's. I have 12 ported 18s now but I do believe a giant 9hz tuned horn would be the best! Think of a GH but bigger and tuned to single digits so you don't lose that low end which creates pressure and that heavy or deep sense to the bass. Without it bass seems artificial to me, my shakers could shake the crap out of the seat and pull 1g on VS but it seemed unnatural compared to everything else on screen. I should hook them up again and try to dial them in so it adds but subtle. This is why Scott's riser is best because it is a shaker but adds the pressure and depth to the sound.
I'd like to see if there is a difference for enclosure types, wrt vibsensor, by testing the three types at the same spl at an easier to achieve 20hz.
DotJun is offline
post #4224 of 4762 Old 03-14-2016, 08:05 AM
MKtheater's Avatar
Liked: 1116
Lone Survivor at reference and subs flat
Marantz 7702 Atmos
post #4225 of 4762 Old 03-14-2016, 08:19 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
which sub should I add to my card if I am adding 2 si 18d4 each in a 4cu' sealed box?
Brian Fineberg is offline
post #4226 of 4762 Old 03-14-2016, 08:22 AM
MKtheater's Avatar
Liked: 1116
What? How about 2 Si!
Marantz 7702 Atmos
post #4227 of 4762 Old 03-14-2016, 08:25 AM
Liked: 3514
i cant find them in the calculator
post #4228 of 4762 Old 03-14-2016, 08:27 AM
MKtheater's Avatar
Liked: 1116
Marantz 7702 Atmos
post #4229 of 4762 Old 03-14-2016, 08:31 AM
Liked: 3514
Im an idiot...its the first one...sorry
post #4230 of 4762 Old 03-14-2016, 08:31 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5212
I agree, an earthquake can destroy a home, our subs shake our floors, not the same.
Yup...I hit 7 on the Vibration meter app(above 30hz)...while the tactile sensation is strong, it's by no means knocking buildings down.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
