Your Home Theater ULF Score - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 704Likes
post #4321 of 5004 Old 04-22-2016, 03:07 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5679 Post(s)
Liked: 4667
Originally Posted by bgtighe23 View Post
We have similar cards, just that my room is a bit smaller.
And pretty much the same subs, minus the PSA
But I have UM-18s and you have DS4s
But I do have 4 1262s that are sitting in boxes still...
Get to work on those, man!
Young guy.... not doing too bad at your age. I think when I was 20-ish I still was rocking a single vented Adire Tempest.
Time to wrap up the 1262's so you can move on up the ladder here.
Scott Simonian is online now
post #4322 of 5004 Old 04-22-2016, 04:54 PM
bgtighe23's Avatar
Quoted: 1555 Post(s)
Liked: 882
The issue with the 1262s is I will need to start getting dedicated circuits...but I don't believe this will be the permanent HT room so I don't want to invest too much into those things.
But trust me, climbing up the ladder is something I very much so plan to do and I hope it's with more 18s and not 1262s
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 3 Towers/RBH R5Bi Front and Rear Heights
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is online now
post #4323 of 5004 Old 04-22-2016, 10:03 PM
DotJun's Avatar
Quoted: 582 Post(s)
Liked: 156
I so envy you people with sealed dedicated small rooms. That's it, we need a non-ulf scorecard for us big, open-room, concrete floor having people
DotJun is offline
post #4324 of 5004 Old 04-26-2016, 11:11 AM
raynist's Avatar
Quoted: 1491 Post(s)
Liked: 1436
Originally Posted by dominguez1 View Post
^^^This
^^^Using this conversion
^^^Equals your the new and improved ULF Card with Tactile Response metrics
Nice work...
I don't see a 5hz rating - should there be one?
raynist is online now
post #4325 of 5004 Old 04-26-2016, 11:16 AM
raynist's Avatar
Liked: 1436
Originally Posted by coolrda View Post
The things I do for my fellow AVSers.
Curious about this ULF card. All of the other cards I see on the first page with 5hz readings have the score higher (worse) the lower you go in hz. On Brian's card his 5hz score is 2.5 times better than his 10hz score. That doesn't make sense to me. Is that accurate?
post #4326 of 5004 Old 04-26-2016, 11:23 AM - Thread Starter
dominguez1's Avatar
Quoted: 1067 Post(s)
Liked: 853
Sorry, are you already in the 5hz club?
dominguez1 is online now
post #4327 of 5004 Old 04-26-2016, 11:24 AM - Thread Starter
dominguez1's Avatar
Liked: 853
No, you are correct. They should be the same for a sealed setup.
@coolrda may have fat fingered...
post #4328 of 5004 Old 04-26-2016, 11:33 AM
raynist's Avatar
Liked: 1436
Not sure - I think you created the card for me and I bought maybe there wasn't a good 5hz rating to you left it off.
post #4329 of 5004 Old 04-26-2016, 11:33 AM
coolrda's Avatar
Quoted: 943 Post(s)
Liked: 669
Good catch Raynist. Not my fault man. I defer to Mr Fineberg. I used the card posted on post 4300. It does indeed have a different 5hz than the smaller card a few posts proceeding. I'll see if the smaller card is workable.
coolrda is offline
post #4330 of 5004 Old 04-26-2016, 11:49 AM
coolrda's Avatar
Quoted: 943 Post(s)
Liked: 669
Originally Posted by Brian Fineberg View Post
new card...why is it so little?
This isn't a viable sample. Needs a name on it. Jeez, why does this feel like I'm splicing genes ?
coolrda is offline
post #4331 of 5004 Old 04-26-2016, 11:53 AM - Thread Starter
dominguez1's Avatar
Liked: 853
Can you post your FR to 5hz? That will get you in...
post #4332 of 5004 Old 04-26-2016, 12:01 PM
raynist's Avatar
Liked: 1436
Sure.
What db level do we need it at? I can probably do it this weekend.
post #4333 of 5004 Old 04-26-2016, 02:19 PM - Thread Starter
dominguez1's Avatar
Liked: 853
Sure.
With your setup? 125db sweep
A 75-80db sweep will be fine. Your score will dictate your max output levels, so don't need to push your system...of course you can if you'd like!
post #4334 of 5004 Old 04-26-2016, 05:54 PM
coolrda's Avatar
Quoted: 943 Post(s)
Liked: 669
We should all be doing this. Short mono sine sweep w/5db spacing until comp sets in.
coolrda is offline
post #4335 of 5004 Old 04-26-2016, 07:04 PM
derrickdj1's Avatar
Quoted: 952 Post(s)
Liked: 673
I read that there was a GTG in PA. I think it was at your house. One guy came away and was blown away literally and figuratively, lol. He left think that he has to re- look at his entire bass system.
derrickdj1 is online now
post #4336 of 5004 Old 04-26-2016, 07:11 PM
BassThatHz's Avatar
Quoted: 2249 Post(s)
Liked: 1954
That won't work. The loudest systems on the ULF Score chart exceed the dynamic abilities of what a UMIK-1 can handle in-room.
There are only a few mics that can record over 130db and not sound like distorted farts, and I don't have any... but I do have a TermLab rated for over 180db
For example here is my HzHorn. The sub isn't compressing (but the UMIK-1 is. )
That's only 1 sub... what if I activated all of my subs?
There is a reason why data-bass uses a $2000 mic and measures at 10m, rather than 1m. It is to keep the THD of the mic low enough for capturing 140db+, you want to measure the subs THD not the mics THD
data-bass also has a huge open field with a zillion-amp breaker. How many users have access to something like that to avoid room-modes (not many...)
All it takes to clip a UMIK-1 is one 21" with 300watts nearfield.
Now imagine the SPL at the full-output of a FP14000 with multiple nearfields!!!
Besides... I'm sure data-bass has smoked many drivers making compression-charts with a 10 or 20kW amp into a single coil. Kind of risky...
BassThatHz is online now
post #4337 of 5004 Old 05-02-2016, 07:27 PM - Thread Starter
dominguez1's Avatar
Liked: 853
Originally Posted by Peterc613 View Post
Below is an earlier picture of the area behind my sofa back when I was planning to build DIY subs instead of going ID. The large cardboard boxes along the back wall on either side of the main LP are placeholders for two of the four JTR Cap 1400's that were on order. Both rear Cap 1400's are now placed sideways with their driver/port facing the center position. Each one is about 4 feet from the LP in the center. The other Cap 1400's are at the front of the room with my main speakers.
The rear sofa table has a opening below that's currently housing my two old Energy ESW 150 subs. This is where I want to build a near field sub for tactile response as I'm on a concrete floor in a huge 10,000 cf room. The 18 x 48 x 16 space under the existing sofa table would accommodate a 6.1 cu ft internal volume enclosure. it could be painted in black and relatively east to build.
I could also replace the existing sofa table with a larger enclosure at 24 x 54 x 18 with 10.3 cu ft internal volume. It would need to be finished in Qtr Teak to match other furniture and would require the use of a woodworker I know to build and finish.
Lastly, the opening in the rear sofa table could also accommodate a Captivator S2 if I cut out the bottom shelf if I didn't want to go DIY. But that would be a lot more money, so I am in the process of getting two UXL-18 drivers for my near field subwoofer.
You're suggesting that ported near field subs have more tactile response than sealed. Which of the SEALED/PORTED options below will give me the best response in combination with the two Cap 1400's that are already there?
SEALED
I already have two cap 1400's on the rear wall to either side of the main LP, each one is about 4-5 feet away from the center position. Sealed UXL-18's in the rear center wall about 2 ft behind the LP might help bring up the ULF tactile response below the cap's 17 Hz port tune.
PORTED
I can put the UXL's in two DIY Sound Group Stonehenge enclosures centered 2 ft behind the LP. This might have more tactile response although their higher port tune at 22 Hz might create problems with the Cap's tune at 17 Hz
MOVED FROM JTR CAP 118 THREAD
If it were me...based on my experiences...
Output is not an issue for you with the 4 Cap1400s. Check the box on output.
Sounds like what you're wanting is extension, by way of a sub placed nearfield. IMO, sealed 2ft away probably won't get you the TR you're looking for from a 15hz and below perspective. I've read that nearfield sealed are very effective, especially when the driver is almost touching your HT seating. 2ft may not sound like a lot, but I do think that matters quite a bit for sealed designs.
Given that, the sub that I would select would be a low tuned, ported design. That pretty much limits you to two subs commercially available: Cap4000ULF and the FV15HP
Sounds like the CapULF doesn't meet your size requirements, but I believe 2 FV15HPs do (18x24x24) fit. Additionally, Rythmik is coming out with the FV25 in the late summer, and should rival the CapULF from 20hz to 12hz, and then the CapULF will pull away below that. The advantage with the Rythmik is that it is a much smaller footprint compare to the CapULF...likely the size that you're looking for.
Of course, I say all of this without have a good idea what happens to TR in a huge space like yours...but there's only one way to find out.
Do you get a lot of TR from your Cap1400s now?
post #4338 of 5004 Old 05-06-2016, 09:33 PM
MKtheater's Avatar
Quoted: 1696 Post(s)
Liked: 1220
Hey guys, been on vacation and finally got pics. My panels are all DIY using denim and Ecose. The fabric is from ATS. The bass traps are 6 inches thick and the walls are all 4 inches. The ceiling are 2 inches. All of them are open back leaving a space to trap on both sides. My system is all behringer including the amps. Marantz processor running the show. What you can't see are the back subs which each bank of 215s and bass traps are sitting on. They are dual ported 18s. Actually all subs are the same, dual SI 18HT with dual ports.
DotJun likes this.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- BFM TLAH
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
post #4339 of 5004 Old 05-06-2016, 11:13 PM
derrickdj1's Avatar
Quoted: 952 Post(s)
Liked: 673
Very nice MK. I like the all cinema style speakers. I can see you put a lot of work into the room, kudos!!!
post #4340 of 5004 Old 05-07-2016, 07:37 AM
MKtheater's Avatar
Liked: 1220
Thanks! I can't just change one thing, I changed everything!
derrickdj1 likes this.
post #4341 of 5004 Old 05-07-2016, 09:20 AM
coolrda's Avatar
Quoted: 943 Post(s)
Liked: 669
The B series sure make good sound.
coolrda is offline
post #4342 of 5004 Old 05-07-2016, 09:39 AM
MKtheater's Avatar
Liked: 1220
Yes they do. They are much better than the JBL pro 825's I owned as well.
post #4343 of 5004 Old 05-07-2016, 09:43 AM
bgtighe23's Avatar
Liked: 882
^ Time for an avatar update ^
Make it spiffy
love the space btw.
post #4344 of 5004 Old 05-07-2016, 11:29 AM
MKtheater's Avatar
Liked: 1220
It always looks better in person and thanks. I think it is the first pic of the berry room
post #4345 of 5004 Old 05-08-2016, 07:21 AM - Thread Starter
dominguez1's Avatar
Liked: 853
Nice MK! The berry's look great...and you did Atmos with them!
So those are 215s all around?
I've got to get over there and check it out again...major improvements since I last visited. Perhaps June again...need to check schedule.
Can I request that you upgrade to a 4K projector by the time i get there?
post #4346 of 5004 Old 05-08-2016, 08:43 AM
MKtheater's Avatar
Liked: 1220
I am using the LG LED projector, I love it! 4K will be in my future! I have 215s all around and 212s as ceilings. The 15s were just too big and even the kids would hit their heads walking under them. The room sounds much better now and the bass is crazy! I have 3 settings on the bass amps, flat, then one click for my normal, and one more click makes it nuts.
post #4347 of 5004 Old 05-08-2016, 09:41 AM
BassThatHz's Avatar
Liked: 1954
Seat-gripping bass!
I've worn out 3 chairs myself thus-far: 1 cloth and 2 real-leather... You aren't an audio black-belt until the black-belt turns white from ACTUAL usage!
ID:	1429258   Click image for larger version
dominguez1 likes this.
post #4348 of 5004 Old 05-08-2016, 10:00 AM
MKtheater's Avatar
Liked: 1220
That would be kid hands. I can't keep them clean! Those seats are the only original equipment left.
post #4349 of 5004 Old 05-08-2016, 11:07 PM
DotJun's Avatar
Quoted: 582 Post(s)
Liked: 156
That guy kinda looks like popalock
DotJun is offline
post #4350 of 5004 Old 05-29-2016, 05:17 PM - Thread Starter
dominguez1's Avatar
Liked: 853
Originally Posted by CherylJosie View Post
Then again, the 'nearfield' effect is due to particle velocity, not pressure, and it feels quite different on the body. How to measure that? Anyone? It has been done, obviously, but I do not know what sort of transducer does that in the audio band. High-pass the microphone starting at its low frequency -3dB? Use a venturi-like sensor similar to what 'boats' use to measure speed in knots? dunno
BOOM!
Sound Intensity, Particle Velocity, and Pressure Visualized...
1st - Microflown Acoustic Camera
2nd - Sound Intensity Mapping of a Speaker
3rd - Low Frequency Mapping of Sound Intensity of Speaker/Subwoofer
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
