Your Home Theater ULF Score - Page 151 - AVS Forum | Home Theater Discussions And Reviews
 545Likes
Old 08-03-2016, 02:38 PM
MKtheater's Avatar
Quoted: 1646 Post(s)
Liked: 1170
My front 8 drivers are running off one amp channel and the back 4 drivers are running off the other amp channel. I guess I can just plug the back subs and test.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- TBD
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
Old 08-03-2016, 02:48 PM - Thread Starter
dominguez1's Avatar
Quoted: 969 Post(s)
Liked: 710
Originally Posted by coolrda View Post
Couple of quick questions. Should we be using VS data, in a comparison like this, that's been taken more than 4 months apart? Were the FR taken at the same time/date as the VS? Why is the graph offset 20db when your showing a +10db scale?
Ideally no, but doesn't mean its not valid and directionally correct given the other tests/evidence performed by dj and I in a more controlled manner.
Not sure I understand your question with the 20db offset. It's explained in my original post.
dominguez1 is offline
Old 08-03-2016, 04:39 PM
coolrda's Avatar
Quoted: 872 Post(s)
Liked: 628
I'm wondering if the reason SPL doesn't increase as much as your TR is due to TA cancellations. Try it with front alone, then both.
coolrda is online now
Old 08-03-2016, 04:53 PM
coolrda's Avatar
Quoted: 872 Post(s)
Liked: 628
That why we need to rerun these tests. It's not clear to me so how can a casual poster hope to follow this. I'm guessing the SLLT is cal'd to 85db and the IB to 95db due to the IB being +10db hot. I follow the top overlay with the 10db offset. The bottom though has an additional 10db of offset showing 20db of total offset.
Old 08-03-2016, 11:02 PM
3ll3d00d's Avatar
Quoted: 1587 Post(s)
Liked: 573
AIUI he measured one at 85 and the other at 95 so that is one 10dB offset and then he bumped the IB by 10dB to try to get more feel out of it.
3ll3d00d is online now
Old 08-04-2016, 04:21 AM - Thread Starter
dominguez1's Avatar
Quoted: 969 Post(s)
Liked: 710
I'm not sure how I can make it more clear than the below?
Below is your IB Response superimposed over your ported response. They were superimposed so that the 85db and 95db lines were matched as that is the calibration point of each as you mention above.
You'll notice here that they are within 2db or so at 10hz. Remember, we are looking at 10hz because that is the frequency in consideration to test the hypothesis that around tune, ported produces more TR. Mk's IB ported setup is tuned to 7hz.
However, when MK took readings with the VibSensor, he took the reading for his sealed IB running 10db hot. When he did the ported reading with VS, he ran flat.
In the below graph, I increased the IB by 10db to compensate for running his IB hot.
As you can see, MK was running 8db hot (once you calibrate the two responses) when comparing FRs. Yet the Vibsensor shows drastic differences in the TR at 10hz...18db difference!
More evidence that TR can be increased without an associated increase in SPL, and that around port tune, ported subs produce more TR as compared to sealed.
^^^this.
I took the below two responses and just superimposed them. Nothing more straightforward than that.
Perhaps you can circle the area in the above summary graph that's confusing?
I will post my data again. VS, response, and spectrum.
IB Response(low end about 5 dB hot compared to crossover)
Now here is the same data running the SLLT flat at crossover.
Old 08-04-2016, 06:54 AM
coolrda's Avatar
Quoted: 872 Post(s)
Liked: 628
^^^this.
Ok, gotcha. I was thinking the SSLT was set to 85db and the IB was set to 95db and that this was the +10db hot. But he actually set the IB at 95db plus ran another +10db and thats why the 20db offset. Is that correct? So the IB was 20db above the SLLT?
There's no question on the VS graphs because they overlay perfectly. I don't care if he took those 4 months ago or 4 years, you can easily see his 18db gain in TR. Those two were clearly taken at the same level so i wasn't understanding why the FR's need offsetting if taken at the same time as the VS. When I move my mike a few feet I get as much difference as between these graphs. It can be difficult taking FR's even if you move the mic a little. I don't expect any difference by retesting using the new method, only more precise data and easier to follow.
Old 08-04-2016, 07:51 AM
MKtheater's Avatar
Liked: 1170
Those were just sweeps for calibration purposes to show frequency. I am not sure even if the mic is accurate down low. My spl meter was tested to be accurate with other mics and it showed a different response for the IB. I will take a sweep of the SLLT with it once the HDMI cable comes in tomorrow. Again, the levels are irrelevant to each other, they were to see the response as compared to the crossover and how the ports changed the response.
Marantz 7702 Atmos
Speakers- TBD
Old 08-04-2016, 02:20 PM
MKtheater's Avatar
Liked: 1170
Cable just came in, running sweeps tonight.
coolrda and derrickdj1 like this.
Marantz 7702 Atmos
Speakers- TBD
Old 08-05-2016, 10:57 AM
coolrda's Avatar
Quoted: 872 Post(s)
Liked: 628
Remind again why we should build/buy sealed? It's tighter and goes deeper in a smaller box? I don't know. It's always good to re-evaluate every so often but I'm seeing less and less reason to go sealed. This is coming from a pro-closed box guy. I'm seeing less and less pro's. Maybe it because driver/amp performance has increased so much recently or now we have new measurement devices we didn't have before. What's the point if we have to use multiples of drivers. We're not talking doubling any more, it's more like 4-8x's.
Consider this. MK got an 18db ULFTR gain. At 3-6db I'm giving it serious thought, but at 18db@10hz. I'll rebuild my screen wall, if not my whole theater. To put this in prospective, in MK's case that's 8x increase to his 12x18's array. That doesn't take into account power for them and all the complexity getting those setup. If fact, if using TT's and MA's to fill in the bottom, we don't even need a tune as low as MK's. I still think we need 3-4 subs placed properly as it flattens FR.
Old 08-05-2016, 01:39 PM
3ll3d00d's Avatar
Liked: 573
the difference is that port bandwidth is fundamentally limited and that the box required to support a low tune is massive, I mean MK has ported an IB to achieve his results hasn't he?? suffice to say this isn't not an option open to many people!
there's also the question of PR which we can't measure atm, does ported or sealed produce more on that front?
why do you need a low tuned ported sub btw if you have an MA?
Old 08-05-2016, 01:40 PM
3ll3d00d's Avatar
Liked: 573
in other news, I've managed to pick up another UXL-18 2nd hand and am going to design/build a ported sub to replace my current dual infinity 1260w sealed NF. I figure I need to find out what this ported gives greater TR fuss is all about
coolrda and dominguez1 like this.
Old 08-05-2016, 02:01 PM
MKtheater's Avatar
Liked: 1170
I never got to measuring last night as we had company stay over until midnight. I only ported the IB because I could, I would not trade my old ported at 13hz for my recent IB as I like the weight and pressure from the full bandwidth system. However, Porting the IB is another level as it requires less power and boosts right where most sealed systems start to roll off! I can really say low end from real subs and not room gain makes a big difference. I never had a real IB but an enclosed a baffle wall and sealed it from the front 3 speakers. It just made sense to at least try in my situation.
Marantz 7702 Atmos
Speakers- TBD
Old 08-05-2016, 03:41 PM
coolrda's Avatar
Quoted: 872 Post(s)
Liked: 628
I don't need it. I'm very happy with mine now. Just find the 18db TR gain as something others could seriously consider if contemplating a ULF upgrade.
Old 08-05-2016, 04:05 PM - Thread Starter
dominguez1's Avatar
Quoted: 969 Post(s)
Liked: 710
PR (Pressure Response or the impact that Sound Intensity has directly on your body; not through another object) is the primary reason why to use a sub vs an MA. MAs will never produce PR, only TR (Tactile Response; vibration of objects touching your body).
Old 08-05-2016, 05:36 PM
derrickdj1's Avatar
Quoted: 906 Post(s)
Liked: 613
OK, we will meet you over in the DIY section to check out your carpentry skills, lol.
derrickdj1 is offline
Old 08-05-2016, 11:34 PM
3ll3d00d's Avatar
Liked: 573
I didn't think we could measure PR?
Anyway if full bandwidth PR is important then that is an argument for sealed isn't it? (given that low tune ported is, for most people, infeasibly large)
Old 08-06-2016, 05:11 AM - Thread Starter
dominguez1's Avatar
Quoted: 969 Post(s)
Liked: 710
Exactly!
PR ULF provides the pressure our ears feel, it provides the weight of an explosion, and the uneasy feeling during tense scenes.
PR LF provides that kick in the chest/midbass slam. It creates that feeling of your heart racing and that shortness of breath at times.
PR provides the realism to the content. The more your ht is capable of full bandwidth, the more you will achieve this, IMO.
Can it be measured? Yes, with Sound Intensity meters and pvl meters.
Can we do it? If we had those tools... Otherwise (in absense of those tools), we might be able to infer it by a combination of high spl capability (ULF card), FR, TR, and proximity of subs to the listening position.
coolrda likes this.
Old 08-06-2016, 07:02 AM
coolrda's Avatar
Quoted: 872 Post(s)
Liked: 628
Well.....with dual array, I've found some interesting things playing around with the OM distortion function while moving the mic.
Correct.
Old 08-06-2016, 09:13 AM
MKtheater's Avatar
Liked: 1170
newc33 likes this.
Marantz 7702 Atmos
Speakers- TBD
Old 08-06-2016, 11:30 AM
newc33's Avatar
Quoted: 927 Post(s)
Liked: 1149
I know where 2 more barely used uxl18s are... Pm if interested.
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is offline
Old 08-06-2016, 12:18 PM
derrickdj1's Avatar
Quoted: 906 Post(s)
Liked: 613
Today I had some time to tested the sealed Bum Buster VS vented. It is not perfect as can be seen by the FR. The sealed had a better low end VS slightly higher spl for the venter 20 Hz and up. This was as close as I could get the two alignments.
It should be noted that the vented testing had a major disadvantage on the low end over a considerable range included in the Eto clip. Correlate the peak raw and resonance with both graphs in the data in the next few post.
Eot clip played at -15 MV for all testing.
iphone 6 with 10 lb weight on phone for testing
sub location- nearfield behing MLP
FR done with Omnimic
Name:	8.6.2016 vented.png
ID:	1587729   Click image for larger version
Name:	8.6.2016 dealed 2.png
Old 08-06-2016, 12:19 PM
derrickdj1's Avatar
Quoted: 906 Post(s)
Liked: 613
Vented VS data:
ID:	1587745   Click image for larger version
ID:	1587753   Click image for larger version
ID:	1587761   Click image for larger version
Old 08-06-2016, 12:20 PM
derrickdj1's Avatar
Quoted: 906 Post(s)
Liked: 613
Sealed VS data:
ID:	1587777   Click image for larger version
ID:	1587785   Click image for larger version
ID:	1587793   Click image for larger version
Old 08-06-2016, 12:39 PM
derrickdj1's Avatar
Quoted: 906 Post(s)
Liked: 613
The vented testing showed more movement in the Z plane. This is consistent with the nearfield position of the sub behind the MLP. The activity in the X and Y planes is obscured in the vented VS graphs due to the heavy blue in the Z plane. The resonance of the sealed extended down to 15 Hz compared to 20 for the vented testing. This is consistent with the two alignments.
Peak raw Z values of 1.72 vented VS 1.31 sealed. Are these differences of vented VS sealed significant enough to support the hypothesis that vented produce more TR than sealed at equivalent spl.? Sample size is to small to give P values. Dom and coolrda can do some overlays and calculate the max decibel difference for discussion. It should be interesting to see what MK's further testing of this hypothesis shows.
Old 08-06-2016, 12:52 PM - Thread Starter
dominguez1's Avatar
Quoted: 969 Post(s)
Liked: 710
Old 08-06-2016, 01:08 PM
3ll3d00d's Avatar
Liked: 573
what better excuse to buy a new saw than building a big sub Ported NF UXL-18 Build
Old 08-06-2016, 01:10 PM
coolrda's Avatar
Quoted: 872 Post(s)
Liked: 628
Nice. I'd like to see the sealed graphed to 5hz though. Then overlay both on same graph. I take it the blue line is just because the mic is plugged in. You can save those, unplug the mic then reload all of those. You prolly know that, though.
What's the deal with the VS data. Your not the first I've seen with this X axis dominate. At first I thought you changed phone orientation but the numerical data says otherwise. Numerical and Graphical aren't matching up? Somethings glitchy. Are you use VS 2.0.0?
Old 08-06-2016, 01:12 PM
3ll3d00d's Avatar
Liked: 573
Your Z plane looks odd for the vented...what's the tune? You are showing a TON of TR 10hz and below...
both vented and sealed have an odd, and very strong, spike at the start of the measurement. Perhaps something knocked the phone at the start of the measurement? I think that renders the measurement void tbh as you just don't know what is in there.
Old 08-06-2016, 01:13 PM
coolrda's Avatar
Quoted: 872 Post(s)
Liked: 628
Ha, good catch. Even weirder look at the Numerical v Graphical. Something amiss huh?
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
