Your Home Theater ULF Score - Page 156 - AVS Forum | Home Theater Discussions And Reviews
 502Likes
post #4651 of 4667 Old 09-12-2016, 09:27 AM
MKtheater's Avatar
Quoted: 1469 Post(s)
Liked: 1039
I really like the ported subs I have. It is funny because the size of my enclosures turned out to be the right size for a tune of 7hz anyways.
Marantz 7702 Atmos
Front subs 8 SI 18ht ported SLLT powered by Peavy IPR 7500
Rear subs 4 SI 18HT ported SLLT powered by Inuke 6000.
MKtheater is online now
post #4652 of 4667 Old 09-12-2016, 03:31 PM
coolrda's Avatar
Quoted: 680 Post(s)
Liked: 510
Originally Posted by lz7j View Post
I plan on adding at least 4 more 24's, but in an IB configuration at our new home. I'm leaning towards ported IB like yours (using an 800ft^3 room in the basement).
Single digit feels cool and all with sealed, especially on suspended floors but it doesn't give me the "my ears are getting plugged and blurry vision/watery eye sensation" compared to my ported setup in my main HT.
My othorn will be done at the end of the month, so I hope I can get that "take my breath away" in my current family room too.
Attaboy. Like I've said repeatedly, we need to keep pushing the envelope until there's a fatality, then we'll back off from there.
coolrda is offline
post #4653 of 4667 Old 09-23-2016, 07:00 AM
MKtheater's Avatar
Liked: 1039
Ok, changes are coming because I am bored and want to build something. I am building 4 10hz tuned UM18s for my rear subs powered with the IPR2 7500 and the front wall will get 4 more or the same 4 SI 18HTs. I will tune the wall to 10hz as well as it still gets me 5hz.
post #4654 of 4667 Old 09-23-2016, 10:20 AM
bgtighe23's Avatar
Quoted: 1339 Post(s)
Liked: 709
Ok, changes are coming because I am bored and want to hike something. I am building 4 10hz tuned UM18s for my rear subs powered with the IPR2 7500 and the front wall will get 4 more or the same 4 SI 18HTs. I will tune the wall to 10hz as well as it still gets me 5hz.
I love the UM-18s. Care to post lots of pics in this thread of the build/progress?
What made you decide on at particular amp?
First time working with the UM-18s?
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 3 Towers/RBH R5Bi Front and Rear Heights
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is offline
post #4655 of 4667 Old 09-23-2016, 10:50 AM
MKtheater's Avatar
Liked: 1039
Yes first time with the UM18. I have not ordered anything yet except my Jasper jig. I am going to actually build a proper box and not wall types of enclosures for the rear subs. 16 cubes per driver. I really like the Inuke amps as well.
post #4656 of 4667 Old 09-23-2016, 01:15 PM
coolrda's Avatar
Quoted: 680 Post(s)
Liked: 510
Your killin me MK. You know this is gonna start a chain reaction.
coolrda is offline
post #4657 of 4667 Old 09-23-2016, 01:33 PM
MKtheater's Avatar
Liked: 1039
Well I have two Cap4000ULF type subs already with my Si drivers but I want to make them bigger and much better braced. Ports and drivers will all be facing the seats. It will be a slot port as well. I will buy MDF from wherever see what happens. I know that my DTS-10s dug to 9hz with a 14-15hz tune so 10hz so be hitting 5hz in my closet, I mean room.
post #4658 of 4667 Old 09-23-2016, 07:06 PM
bgtighe23's Avatar
Liked: 709
The only real common denominator between those two subs mentioned is that they are ULF ported 18s. The HT18s are great, but not so much if you only have 1 or 2 compared to the other 18s out there.
There is seriously a notable difference between my UM-18s and the HT18s in the same enclosure and I'm sure that difference is even greater with that Cap driver.
Either way, looking forward to this moving/upgrade your pursuing.
post #4659 of 4667 Old 09-23-2016, 08:07 PM
MKtheater's Avatar
Liked: 1039
The UM-18 is more like a 28mm xmax driver and the Cap is 30mm. You can see the cap S2 results and minus 5 dB or so to get a Cap S1 vs the UM18 which would be about a dB at 10hz.
post #4660 of 4667 Old 09-23-2016, 09:50 PM
bgtighe23's Avatar
Liked: 709
What I'm trying to say is that both of those drivers, the UM-18 and the Cap is just so much better than the HT18 and that you will be floored with the results upgrading to something like the UM-18
post #4661 of 4667 Old 09-23-2016, 11:11 PM
coolrda's Avatar
Quoted: 680 Post(s)
Liked: 510
Describe floored.
coolrda is offline
post #4662 of 4667 Old 09-24-2016, 07:46 AM
MKtheater's Avatar
Liked: 1039
They measured similar on the low end with the extra x-max favoring above 30hz.
Marantz 7702 Atmos
post #4663 of 4667 Old 09-24-2016, 08:45 AM
bgtighe23's Avatar
Liked: 709
Originally Posted by coolrda View Post
Describe floored.
Impressed with the results.
The tactile difference between the UM-18s and the HT18s was most noticeable in my room.
Following the additional output and pressure feel
post #4664 of 4667 Old Yesterday, 08:02 PM
derrickdj1's Avatar
Quoted: 733 Post(s)
Liked: 520
I have the UM 18 and the SI HT 18 and both are great drivers. Just mate it with the right box!
derrickdj1 is online now
post #4665 of 4667 Old Yesterday, 09:24 PM
MKtheater's Avatar
Liked: 1039
It will be a 16 cubic foot box tuned at 10.9 hz in theory. It always works out lower in room. As long as I get 5 hz I am good. The enclosures the SIs are in s one big box and these will be 4 separate boxes per driver as it is easier to work with smaller boards in my small space. I am never too concerned with port velocity as I never run just one sub to xmax to matter. I should build one with the UM18 and the other with the SI and see what they can do.
post #4666 of 4667 Old Today, 05:59 AM - Thread Starter
dominguez1's Avatar
Quoted: 697 Post(s)
Liked: 470
While you're at it......
Why not replace your front HT18s with UM18s?
Would you benefit from that?
dominguez1 is offline
post #4667 of 4667 Old Today, 07:56 AM
MKtheater's Avatar
Liked: 1039
If you guys heard my room would be telling me I am nuts but we already know that. The front wall is built great and I don't need to change it, the rear subs were built crappy IMHO and just wanted to change that. I still want to build a speaker but after I watch a movie I say why bother. The little improvement I may get if any won't be worth the time and money. I have a $800 CD now that sounds great but not even enough to want to use it. I am hoping DIYSG comes out with a JBL 4722 clone but 18 inches wide for me to change.
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
