Your Home Theater ULF Score - Page 167 - AVS Forum | Home Theater Discussions And Reviews
 702Likes
post #4981 of 5004 Old 05-18-2017, 12:32 PM
MKtheater's Avatar
Quoted: 1690 Post(s)
Liked: 1211
Originally Posted by dominguez1 View Post
Is that the lowest tune you could get? I thought your 8 SIs had a 7hz tune?
That is what I designed for but the enclosure is at least 50 cubes bigger so it will probably end up 8hz or lower in my room.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- BFM TLAH
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is online now
post #4982 of 5004 Old 05-18-2017, 03:48 PM
coolrda's Avatar
Quoted: 943 Post(s)
Liked: 669
Yep! Your subriser must completely go through that futon cushion...having more dense seating wouldn't get you the same result!
Not necessarily.
coolrda is offline
post #4983 of 5004 Old 05-18-2017, 07:09 PM
derrickdj1's Avatar
Quoted: 947 Post(s)
Liked: 663
Originally Posted by coolrda View Post
Not necessarily.
This is a maybe but, a heavier couch may adhere to the rise. The same fore will be transmitted. The couch will shake a bit less but, sence energy does not disappear, it has to go somewhere, the occupant of the seat.
I say this because a few folk with riser have demo'ed my HT which, is on concrete and are amazed at the force coming to the seats.
coolrda and SBuger like this.
derrickdj1 is offline
post #4984 of 5004 Old 05-18-2017, 09:26 PM
coolrda's Avatar
Quoted: 943 Post(s)
Liked: 669
What I was referring to was the seat testing I did where I changed the support from rubber to jute to MDF. My thought would be if rubber is a 2 and jute is a 5 then mdf is a 8. Not so. If I remember correctly it was MDF 2 rubber 5 jute 8.
Now to your point. Its quite possible that in the end good ol' concrete is the best option. Riser most definitely have a resonance. Couldn't they have a null as well? I'm thinking more and more about removing my riser.
coolrda is offline
post #4985 of 5004 Old 05-19-2017, 09:51 AM
derrickdj1's Avatar
Quoted: 947 Post(s)
Liked: 663
My main point was some energy is being lost from the seat between the coupling of the couch and riser. Isolation feet and keeping the couch in solid contact with the riser is of benefit. There are to many variables to say with certainty. I am not discounting the study on risers done early in the ULF thread. Riser vs concrete will have different emphasis on seat movement vs energy transfer to the person sitting.
post #4986 of 5004 Old 05-19-2017, 12:33 PM
mthomas47's Avatar
Quoted: 3079 Post(s)
Liked: 4217
^^^This.
It's definitely a balancing act. Too much TR and Intensity can take away from other nuances of the HT experience (weight, pressure, snappiness, detail, etc.). It's analogous to running your bass to hot...run it hot enough and you start to lose detail from your mains, surrounds, etc. as the bass becomes so prominent, it overpowers everything.
I agree with your summary and with the posts you quoted in making it. The only thing that I would add is that the appropriate balance at any given time may not necessarily be a static one. Like several of the other posters, I may choose slightly different things to emphasize, depending on the content, and on my own mood. A couple of people noted that they don't max out their volumes all the time. With me, it's partly a matter of the mood that I'm in. Some days it's fun to really let it rip with loud volumes and low bass, and on other occasions I might be content with lower volumes and less low bass.
As SBuger noted earlier, the listening volume can affect the equilibrium between mid-bass and ULF, due to the way our hearing works (the Equal Loudness Contours). So, for instance, if I leave my subs at the same +15 setting when I am listening at -10 MV, and at -15 MV, I will hear relatively more ULF at -10, and relatively more mid-bass at -15, because we hear mid-bass frequencies more easily than we do lower ones. Depending on what I'm in the mood for, I may just raise or lower my master volume to change the acoustic balance in the way I want it for that particular movie or mood.
Mike
SBuger likes this.
mthomas47 is online now
post #4987 of 5004 Old 05-23-2017, 07:01 AM
coolrda's Avatar
Quoted: 943 Post(s)
Liked: 669
Your saying better/heavier seating will be better on a riser and even better on concrete than cheaper/lighter seating. I could be wrong but I'm starting to think the same way. I'm sold. Even if its not a quantity improvement, a quality one, would be as much or more welcome.
coolrda is offline
post #4988 of 5004 Old 05-23-2017, 09:55 AM
MKtheater's Avatar
Liked: 1211
I do like when I shake more than my chair and I do like the quality of bass better on concrete than the riser. My two XXX 18s equal my 8 18 wall!
derrickdj1 likes this.
post #4989 of 5004 Old 05-24-2017, 11:06 AM
coolrda's Avatar
Quoted: 943 Post(s)
Liked: 669
Mike
So true. Even our perception can be off day to day, and without any changes to the system, the feel is different. Changing gear and placement of subs can disrupt that balance and while you may increase both quantity and quality of your system in doing so, you simply may not like it as much due to it feeling different. Then, over time and after tuning the new setup, you can get to a point were you may like it better.
SBuger, mthomas47 and unretarded like this.
coolrda is offline
post #4990 of 5004 Old 05-24-2017, 12:56 PM
derrickdj1's Avatar
Quoted: 947 Post(s)
Liked: 663
The thread has taken on an interesting point. The TR will be different on a riser vs a a more solid surface like concrete. This remind me of the roller coaster at 6 Flags VS the space shuttle. They are both great ride but way different. Is one better, ask me on different days.
One day I may like my chair/seat to shake the hell out of me and the next day I want the force not to be sent to the seat and sent directly to me. This is the possible difference between a riser and concrete.
Now, we know you will need a mega system to do this on concrete because you need to make up around 14 or 15 db of spl. to equal a riser. There are mega system that can do this, I have one. Now the question is which way do I go,, flow with the river for the easy path. Maximize your room with it resources or tear everything out and reconstruct the space. This will ouch! or cost a ton more money. From my view, there is no one and only way to go so, don't break the bank because it can be bested in another scenario
SBuger likes this.
post #4991 of 5004 Old 05-24-2017, 12:59 PM
derrickdj1's Avatar
Quoted: 947 Post(s)
Liked: 663
I have watched this thread grow and help many in elevating their HT experience. This thread has repeatedly questioned it's self and end points. Data integrity has been a hallmark for this type of ongoing thread.
It is apparent that some conclusion can be drawn with this much data accumulated and tested. The HT is complex and there is no one perfect scenario. There are large variances mostly because of the room. Different experiences will largely depend on the room. There is enough data to have a good ideal of what that experience is in a given room.
We may be at a point that subjective data is relevant since the goal is also what people perceived to be a good HT experience and are comfortable with.
SBuger and unretarded like this.
post #4992 of 5004 Old 05-24-2017, 02:00 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5667 Post(s)
Liked: 4656
WOAH!!!
You rode the Space Shuttle?!?!? F**k yeah, man! That's awesome! I didn't know you were/are an astronaut.
Got any GoPro footage of it??!
Scott Simonian is offline
post #4993 of 5004 Old 05-24-2017, 05:04 PM
derrickdj1's Avatar
Quoted: 947 Post(s)
Liked: 663
I never left the planet Scott, lol. It is just that the two style of HT will differ. What is better, I sure as hell don't know. To many variables but, either way, I will enjoy the ride.
post #4994 of 5004 Old 05-25-2017, 10:38 AM
coolrda's Avatar
Quoted: 943 Post(s)
Liked: 669
We're moving You and Scott from the VibSensor's Max G's vibration measurement to the Lbs of Thrust category. Instead of vibration you guys will be judged on how quickly you can place a payload in orbit. Sorry Dom, you'll have to redo the card again.
coolrda is offline
post #4995 of 5004 Old 05-25-2017, 10:58 AM
carp's Avatar
Quoted: 2685 Post(s)
Liked: 1956
Mike
I've always felt this way. My perceptions of my system can change from day to day, or even from song to song (or movie to movie). It's all about what mood we are in. People laugh when they see all my bass curves (haha, and rightly so) for my mini 2x4 but that's why I have them, because what I want isn't set in stone.
Some days I swear that music in 2 channel is better and why would I ever use the upmixer... and then the next day it's the opposite. Some days I want my chest to feel every kick drum even at lower volumes and the next day it's annoying. Ok, rarely is it annoying but it does happen.
Bottom line, as long as we have a system that is capable of playing content back how we want/when we want it and we are set! The trick is we need to have enough time tinkering to find out all these different preferences to match our mood.
carp is offline
post #4996 of 5004 Old 05-25-2017, 01:30 PM
MKtheater's Avatar
Liked: 1211
Yes, it has always been preference but one needs to experience as much as possible to decide. One of the reasons I swap out so much is I want to test stuff. I like comparing subs from DB and see how they compare in my room with my wall. I can tell you guys the XXX 18 in my wall is a whole different beast than that small sealed box tested in. It is my favorite bass system so far. Mid bass is not lacking at all. I can't wait to get the rest of the speakers finished for my next atmos. I can't do 7.2.4 with these speakers but a properly placed 5.2.4 is coming.
Brazle likes this.
post #4997 of 5004 Old 05-25-2017, 03:34 PM
Bass Enabler
Liked: 4656
Aww! I thought I knew a real astronaut I could space-nerd out on.
MKtheater and derrickdj1 like this.
post #4998 of 5004 Old 05-26-2017, 12:56 PM
biliam1982's Avatar
Quoted: 448 Post(s)
Liked: 230
I worked closely with NASA in the past, 13 years as a Meteorologist, 3 years in Solar Physics and the Near-Earth Space Environment, finishing my degree in Aeronautical Science with minors in Space Studies and Meteorology, and am a Pilot. Might be the closest you'll get.
coolrda, MKtheater and dominguez1 like this.
biliam1982 is online now
post #4999 of 5004 Old 05-26-2017, 02:16 PM
Bass Enabler
Liked: 4656
Sweeet!
post #5000 of 5004 Old 05-27-2017, 08:26 AM
MKtheater's Avatar
Liked: 1211
This is Rocket Science!
Marantz 7702 Atmos
Speakers- BFM TLAH
post #5001 of 5004 Old 06-03-2017, 02:26 AM
Quoted: 444 Post(s)
Liked: 321
I am not sure what the differences are in all these transducers, but I just picked up the clark 209`s, bottom of the line and they do pretty good.
First ones I have ever used and I have one per recliner hooked to a niles si275 amp......they are pretty outstanding.
Not sure the difference since they will produce vibrations up to 800hz and make sound to 17,000hz, but they hit pretty hard.
They are rated down to 15hz, but go much lower than that.......
They were a good addition to the fun of this room !
I wish I was able to check out all the different ones to get a real first hand feel for the differences in them.....
Even though I will be doing 4, 18`s in a LLT, these will be staying in the chairs.........they do a additive that is hard to describe......
Link to budget Home Theater build
http://www.avsforum.com/forum/19-ded...i-version.html
unretarded is offline
post #5002 of 5004 Old Yesterday, 07:47 PM
derrickdj1's Avatar
Quoted: 947 Post(s)
Liked: 663
The Clark's should be a nice addition to the HT. Checkout the Vibsensor thread. I don't think we have any data on the Clarks.
post #5003 of 5004 Old Yesterday, 10:20 PM
Quoted: 444 Post(s)
Liked: 321
Link please...my searchfu on this site is weak....
post #5004 of 5004 Old Today, 05:14 AM
biliam1982's Avatar
Quoted: 448 Post(s)
Liked: 230
The VibSensor Accelerometer Test Thread
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
