Your Home Theater ULF Score - Page 169 - AVS Forum | Home Theater Discussions And Reviews
 794Likes
post #5041 of 5059 Old 08-25-2017, 11:14 AM
SBuger's Avatar
Quoted: 436 Post(s)
Liked: 644
Originally Posted by coolrda View Post
You can buy a powder gun and nail/pins to anchor the OSB. A lot of flooring guys just float the OSB and nail tongue and groove solid flooring to that. Or you could go click lock. Or OSB, pad and carpet. I even use liquid nails to secure the OSB to the concrete. It still resonates. Same thing happened when I removed the pad and placed a piece of 3/8" OSB. It did provide a firmer base that gave the MA's TR gains but it also had the same effect as this subfloor. Certainly my wood floor topping the subfloor could help but the key, I believe, is the subfloor, not what tops it. I will cut and bind(edging) my carpet basically turning it into an area rug with felt backing like we have throughout the house, for the sound benefit. But again, thats not important. If you need a riser for sightlines, don't use isolators. Just lay it on the subfloor. I lost TR when I placed rubber isolator feet on the subs. I'm using simple stick on, one inch felt pads. The fronts sub weigh about 225lb and I can move them by slide if needed. Yet they stay put and couple really well to the subfloor. Again, the important thing is that resonates and its almost impossible to mass couple to concrete slab no matter how attached or unattached it is. It makes sense why sand is used to fill stages and risers. Unless you need a purpose built riser, don't waste your time and effort. There no question the riser works but the subfloor is much more effective and far simpler to place. I don't think the type of sheet wood makes a difference, so use the cheapest. Likewise with the thickness. There may be a small difference between the 1/2" and 1 1/8" OSB, but I doubt its much.
Thanks for the info! So you did this to your whole floor in you HT room then right? I was thinking at first that you were just talking about just that section under your seating area (with riser removed), like what you said about using the 3/8" OSD without the pad for your MA's (I think I remember when you did that a while back).
SBuger is online now
post #5042 of 5059 Old 08-25-2017, 05:19 PM
coolrda's Avatar
Quoted: 1094 Post(s)
Liked: 1001
Correct.
SBuger likes this.
coolrda is online now
post #5043 of 5059 Old 09-05-2017, 08:39 AM
rdb1276's Avatar
Quoted: 48 Post(s)
Liked: 30
Hey guys. I was reading a couple different forums of using plywood under couch for more tactical bass. My theater is in the basement on concrete. Was wondering if it does help and what kind of wood to use plywood or OSB and what thickness. I was going to use the Buttkicker Ri-4 isolation pads for feet of the plywood.
Thanks for any info
rdb1276 is online now
post #5044 of 5059 Old 09-05-2017, 09:20 AM
Sekosche's Avatar
Quoted: 627 Post(s)
Liked: 1203
Thanks for any info
For a makeshift riser, most people seem to be using 0.5" to 0.75" plywood, and those BK are good isolation feet to start with. I installed 0.75" pine plywood under my loveseat with a pair of Crowsons, and just ordered a couple of ButtKickers, and it works wonders for directly transmitting tactile effects. Perusing AVS, I've read mixed reports though on how helpful such a "mini riser" can be when only subwoofers are providing the main source of tactile energy. I'd probably shy away from using baltic birch for this purpose or making it too thick/rigid, as a little flex is necessary.
Do you run or intend to add a tactile transducer? Concrete floors and a couch on a plywood riser (with proper isolation feet) are beckoning for the additional bass reinforcement that bass shakers or motion actuators can provide.
unretarded likes this.
Speakers: PSA (MT-110 x2, MTM-210C, MT-110SR x2); SVS Satellite x4
Subs: PSA V1801 x2 & V1800 x2, B1200D x2
Actuators: Crowson Tech Shadow-8 x2
Processing/EQ: Denon X4200, MiniDSP HD x2, NU6000DSP
Sekosche is offline
post #5045 of 5059 Old 09-05-2017, 11:10 AM
rdb1276's Avatar
Quoted: 48 Post(s)
Liked: 30
I might look to run transducers. I thought having 4 large subs would be enough tactical bass, but being on concrete floor that is not that case. I will be using 3 8 foot long pieces of plywood for this. I have a large sectional couch. How many feet would you recommend per piece for this. Is more feet better?
post #5046 of 5059 Old 09-05-2017, 03:33 PM
Sekosche's Avatar
Quoted: 627 Post(s)
Liked: 1203
I hear you there. I've got four 18" subs, and still needed more on hard floors over concrete; thus, transducers under and over the plywood base. You don't want to add so many feet to where the pads don't compress at all, need some compression to decouple the couch from the floor. @Mark Seaton just wrote a great post on this exact subject, but I forget which thread they were in. I'd say 4 feet per couch section to start and see what you get.
Sekosche is offline
post #5047 of 5059 Old 09-05-2017, 03:44 PM
rdb1276's Avatar
Quoted: 48 Post(s)
Liked: 30
thanks for the info. I see you Have PSA subs also. I have 4 of the PSA S3600i's and love them, just need more tactical bass. is this the kind of plywood that you would recommend?
https://www.carterlumber.com/product...sanded-plywood#
post #5048 of 5059 Old 09-05-2017, 06:25 PM
Sekosche's Avatar
Quoted: 627 Post(s)
Liked: 1203
That's what I used, just the 0.75" standard, sanded 5 ply pine from Home Depot...never got around to staining the front edge that barely shows, but I cut it down to fit my frame so the couch modifications aren't even noticeable until the transducers kick in.
Have you tried any near field placement with your subs? I bet four S3600i sound pretty incredible! It's harder to get a strong tactile effect from dual opposed and sealed subs when place nearfield, but some have had luck with it.
Even with ported subs, I still needed more oomph, so I put a couple MBMs behind the seating and that helped a bit with midbass slam, then added the Crowsons and they made a huge difference. I'd definitely look into adding some tactile transducers in the future.
Sekosche is offline
post #5049 of 5059 Old 09-30-2017, 12:03 AM
SBuger's Avatar
Quoted: 436 Post(s)
Liked: 644
@dominguez1 - I'm trying out a new room upstairs compared to my setup in the huge open room downstairs. I'm just now getting things hooked up and calibrated and just curious what my ULF scorecard might look like.
INFO:
Room is 1400 cuft (13x13.5x8)
Suspended Floor
4 sealed SI DS4-18's (3 sealed VNF surrounding single recliner + 1 sealed FF - the "Johnny Sub" is now sealed with ports plugged)
1 1200d MBM VNF up high on back stacked on an 18
2 Crowsons
2 BK LFE's (not sure if I'll need these or not but will try it)
2 iNuke6000DSP's
2 Buttkicker BK-1000 Amps
I only have the 4 18's compared to some guys like bgtighe23 and coolrda in a similar sized room, but I'm thinking it'll still have quite a bit of ULF power, especially since 3 of the subs will be very close to me (surrounding me Very Near Field).
I'm getting some pretty good extension now, so I guess this means I'm in the 5hz club now right!? ....at least for a little while if for some reason I decide to move my setup back downstairs like I had it before.
Here's a few pics the way it's setup ...
coolrda, carp, dominguez1 and 4 others like this.
post #5050 of 5059 Old 09-30-2017, 09:13 AM
Hopinater's Avatar
Quoted: 2344 Post(s)
Liked: 5905
INFO:
Suspended Floor
2 Crowsons
2 iNuke6000DSP's
LOL... That's awesome. If that set up doesn't rattle your bones and blur your vision then I don't know what will.
coolrda, SBuger and Pradeep2 like this.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203
Denon X4200 - Panamax M4300 - Apple TV - Xbox360 - Crowson Motion Actuator's
Hopinater is offline
post #5051 of 5059 Old 09-30-2017, 09:20 AM
MKtheater's Avatar
Quoted: 1759 Post(s)
Liked: 1358
Nice! It is like wearing a headphone!
MKtheater is online now
post #5052 of 5059 Old 09-30-2017, 12:06 PM
coolrda's Avatar
Liked: 1001
I have a DEFCON chart on each of you guys here. I just moved SB’s from Enthusiast to Extrememist.
SBuger, Hopinater and Pradeep2 like this.
post #5053 of 5059 Old 09-30-2017, 01:45 PM
MKtheater's Avatar
Liked: 1358
This is ported? Yes it is!
coolrda, SBuger, Hopinater and 1 others like this.
post #5054 of 5059 Old 09-30-2017, 04:18 PM
coolrda's Avatar
Liked: 1001
Show off.
post #5055 of 5059 Old 10-01-2017, 12:12 AM
coolrda's Avatar
Liked: 1001
I was playing around with the OM today and while taking a break from curve testing deciding to crank it for a few secs. I always wondered what the Omnimic max SPL reading was so I blasted away, three runs with reset in between, exact same peak, 139.4db and not a fraction more. It’s disappointing I couldn’t get it to turn over but maxed out is maxed out. That’s way to loud in a HT environment, btw.
Hopinater, Nalleh and unretarded like this.
post #5056 of 5059 Old 10-21-2017, 11:52 AM - Thread Starter
dominguez1's Avatar
Quoted: 1119 Post(s)
Liked: 986
INFO:
Suspended Floor
2 Crowsons
2 iNuke6000DSP's
Sorry all, I've not responded to a ton of great posts in the past month or so! Been heads down trying to launch my tech startup Juble it!. I had some spare time so trying to catch up...
@SBuger , I pronounce you King TR and yes, 5hz club. Wow! That is one crazy setup! Can't imagine how that feels! You must be exhausted after movies...
coolrda, SBuger, eng-399 and 2 others like this.
dominguez1 is offline
post #5057 of 5059 Old 10-21-2017, 11:04 PM
SBuger's Avatar
Quoted: 436 Post(s)
Liked: 644
Thanks Dom!! The setup is a bit crazy I guess (until I see @eng-399 's VNF madness ), but this is AVS forum right!? LOL Should be a whole lotta fun while I have only the one recliner in there
Congrats on your new tech startup!! Yep looks like you've been busy. That could be very, very big!!
dominguez1 and eng-399 like this.
post #5058 of 5059 Old Yesterday, 01:53 PM
coolrda's Avatar
Liked: 1001
A little birdy told me @eng-399 ’s VNF madness is about to turn into full blooded insanity.
SBuger and eng-399 like this.
post #5059 of 5059 Old Yesterday, 03:33 PM
eng-399's Avatar
Quoted: 1755 Post(s)
Liked: 3052
I tell ya John wick 2 is the demo for my room. Everyone has there favorite demo where your system really shines mine is John Wick 2 when he’s in the tunnel firing all his different guns. The gun shots and explosions now after mtg90 RE calibrated the room is so much fun. I now know that with proper calibration things sound much better. The VMF is now just pain crazy and a lot of fun. My ears after yesterday felt like they were bleeding 12-9 of loud music and bass... If your ever in the Chicagoland area swing by.
SBuger likes this.
eng-399 is online now
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
