Your Home Theater ULF Score - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 522Likes
Old 11-14-2013, 04:06 PM
nfraso's Avatar
Liked: 172
I believe it's 126 or 5-star, Fatshaft
nfraso is offline
Old 11-14-2013, 08:30 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
Originally Posted by MKtheater View Post
I always felt that including adjacent rooms depends on how the layout is. Is it an open room or is it a open door to the next room? I say this because my room is small(thank you short ceilings) and I have double doors that open in the middle to create a big opening for big equipment, you know, just in case. They are standard 7 feet by 3 feet each so combined they open to a 7 feet tall by 6 feet wide space. If I open those doors I am seeing another space that is much larger than my theater. However, all my measurements and spl are the same at my LP as the bass hits me the same way. Just like Pop's room, yeah it opens to another area but I bet it acts like a 1600 cubic foot room and not a 2600 cubic foot space. I don't know how big of an opening matters but the main room matters most. Now if you have a huge room that is separated by a island or something then the whole area will be used and the sub will lose that battle. I wonder at what size of an opening where it really matters.
I've been meaning to post this on the first post, but I remember reading a post from basshead that I think is a good guideline and the basis for the below:
  • If the opening is approximately less than half the size of the longest wall, then don't include the adjoining space. If it is larger, then include it.
Certainly odd shaped rooms this will be more difficult to determine, but you get the picture.
I know, not much science to support it other than a gut feeling, but what do you all think?
dominguez1 is online now
Old 11-14-2013, 08:44 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
Originally Posted by Fatshaft View Post
I'm curious where I'm at...
Room is 16'6" x 14' x 7'
Have 4x FTW21's and 4x SI18's
Amps are Fp10000Q and EP4000
10Q is bridged.
1 channel driving 4200W to 2x FTW21 at 8ohm, other channel driving 5000W to 4x SI18's at 4 ohms
EP4000 bridged driving 2x FTW21's at 8ohm.
Can someone help?
Right on! Very Impressive Fatshaft! Good to hear from a fellow FTW'r. :)
Old 11-14-2013, 09:02 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
So......,,..if I'm getting this right
In 4300cf room
One S2 = 3 SI at 12.5 hz
Four UXL-18's @ 12.5 hz is 4X1.5 SI = 6 SI
4300/9= 478 ULF rounded?
doublewing11 is offline
Old 11-15-2013, 04:52 AM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
nfraso,
Thanks for the help...is that 126@10HZ?
Originally Posted by dominguez1 View Post
Right on! Very Impressive Fatshaft! Good to hear from a fellow FTW'r. smile.gif
You know dominguez1 that the purchase of my FTW21's was all your fault right? (Thanks) biggrin.gif
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
Old 11-15-2013, 05:14 AM
BeeMan458's Avatar
Liked: 813
Via measurements, a correction factor can be created?
Expected output vs measured output; creating a correction factor when openings are given a ratio based on the longest wall?
Total square foot measurement of openings/total square foot measurement of longest wall?
If a cathedral ceiling, does a correction need to be added in to allow for the increase of height, due to the angle of incline of the ceiling, attached to the longest wall?
BeeMan458 is offline
Old 11-15-2013, 05:35 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
nfraso,
Glad I could help. :D
Yes, 126@10hz, and 3 away from JapanDave! You guys are sick...
Old 11-16-2013, 08:27 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
New ULF Score Calculator Released
  • Much more intuitive. Just enter room size, find your subs, and enter qty
  • Automatically identifies ULF Score, Stars, and relative Reference Output by ULF frequency
  • Now you can factor in the cost of your subs to determine how much your willing to spend or have spent to get a certain ULF perspective (category). I've input the cost of Commercial Subs, but you can also input the cost for DIY subs manually.
  • Calculates the cost per SI: This is an indication for the "bang for the buck" of your all your subs from a ULF perspective
  • Calculates the cost per ULF Star: This is an indication for the "bang for the buck" for your HT from a ULF perspective (factors in room size, subs, and cost)
  • I've also tweaked the Star methodology: Your highest star for your lowest frequency carries forward to the other ULF frequencies. Example: If you can reach 5 stars at 10hz, you can reach 5 stars for all ULF frequencies. However if you can only reach 3 stars at 12.5hz and can reach 4.5 stars at 16hz, it will not change the 12.5z rating to 4.5 stars.
I've attached it to this post, as well as post 1.
Home Theater ULF Score Calculator v12.1.xls 101k .xls file
Below is an example of my full ULF Score:
Let me know of any errors and what you all think!
-Dom
File Type: xls Home Theater ULF Score Calculator v12.1.xls (100.5 KB, 60 views)
Old 11-16-2013, 08:36 AM
Cowboys's Avatar
Liked: 107
Sweet dude. Thanks for all the great work. I love this thread smile.gif. My second FV15hp has been ordered. Should be awesome 4- 4.5 stars.
Cowboys is offline
Old 11-16-2013, 08:55 AM
BeeMan458's Avatar
Liked: 813
Was a correction factor figured out for main listening room openings to adjacent rooms?
(and as always, I don't have XLS. don't need it so I haven't purchased and installed a copy)
Old 11-16-2013, 09:03 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
Originally Posted by BeeMan458 View Post
Was a factor figured out for room openings to adjacent rooms?
Unfortunately no...not sure how to tackle that one in a simple way. I'd go by the guideline I mentioned here.
Old 11-16-2013, 09:45 AM
BeeMan458's Avatar
Liked: 813
From above link:
Then the above is what I'll go by as the three openings our listening room contends with, is a bit "...less than half the size of the longest wall...".
The above being the case, when installed in our 3300^3 room, a pair of FV15HPs will give us a ULF score of 868 or a four star system. That'll work. biggrin.gif
(and later, should I feel the need more, the simple addition of a third FV15HP will seal the deal)
Old 11-16-2013, 10:17 AM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
Do we round off our room sizes to get the sq footage? Like my ht rm is 19'6" x 17'8" x 9'8"= 3332 sq exact dimensions. So should I round off to 20 x 18 x 10= 3600 sq
rhed is offline
Old 11-16-2013, 10:18 AM
BeeMan458's Avatar
Liked: 813
In nature, since analogue sine waves don't round themselves off, I'd stick with your first total. But if for ease of memory, you rounded to 3,300^3, I don't think anybody is going pull your beer.
(and if they do, I'll get the next round)
Old 11-16-2013, 10:32 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
Time to pay some homage to the new ULF champion, N8DOGG!
His HT ULF score ended up being: 78@10hz and 53@16hz!!! Check out above how many SIs that is in his room!
To put things in perspective, JapanDave and MK have been past ULF leaders: you'd have to double their subs in each of their rooms to mimic N8DOGGs ULF score at 16hz! :eek:
Here are some pics of his room:
Originally Posted by N8DOGG View Post
Heres a couple pics of the kids biggrin.gif :
Old 11-16-2013, 10:37 AM
BeeMan458's Avatar
Liked: 813
You need a six star category.....anything under a score of 100, for "Insane Output"
How much more output (power) does one need to go from four star to what N8DOGG has?
Old 11-16-2013, 10:51 AM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1122
You don't need another category as I can assure you that any 5 star system can not be played at max already because it would destroy some ear drums. A score of 250 would do that, at 10hz!
dominguez1 likes this.
Marantz 7702 Atmos
MKtheater is online now
Old 11-16-2013, 11:05 AM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Que?
eNoize likes this.
popalock is offline
Old 11-16-2013, 11:09 AM
BeeMan458's Avatar
Liked: 813
That's why I named a six star system, "Insane Output." At that level of output, I would hazard a guess, normal listening isn't the point. I see it in the light of really, really, really fast cars, aren't for the mentally stable. A mentally stable person, still has their survival instinct intact. tongue.gif
Ourselves (me), a four star system, with an option to grow to a four-and-a-half star system, is more than enough output for our needs.
Old 11-16-2013, 11:28 AM
MKtheater's Avatar
Liked: 1122
Define insane output? If I added 8 more drivers I would be in the 50's for a score and able to play 6 dBs louder. I can already play ear bleeding levels so 6 dBs more would be more blood!
Marantz 7702 Atmos
Old 11-16-2013, 11:50 AM
MKtheater's Avatar
Liked: 1122
BTW, I am welcoming anyone to go crazy as it is fun BUT how loud one enjoys their system should be what you go after. I could get reference levels at 10hz with a 650 score. That would be 2 of my eD subs I had. The rest is for spirited levels. I personally can not take that much of 130 dBs of bass in my room as it causes so much pressure it hurts the ears! I can produce more than that but I do like hearing. I probably play lower than many that have crazy systems. My limit is reference for the speakers and 10 dBs for the LFE. With the new IB that might be 5 dBs hot on the bass.
Marantz 7702 Atmos
Old 11-16-2013, 12:00 PM
popalock's Avatar
Liked: 1712
Wait till beast gets his sixth order bandbass in order.
It sims at 130db at 10Hz...That doesn't include his 8 SI's.
From a "ULF" standpoint...yeah...what does that score?
popalock is offline
Old 11-16-2013, 12:05 PM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
Thats it...I'm buying 3x SI24's to add to my already insane room ...then we'll see!!!
I agree do an insane level 6!
My Build Thread
Equipment Speakers:
Fatshaft is offline
Old 11-16-2013, 12:43 PM
BeeMan458's Avatar
Liked: 813
Well, there's "ear bleed" and there's "more ear bleed." At this point, it's all a matter of how much blood is being pumped out through your ear canals. eek.giftongue.gif
Okay, here is is, when you're outproducing the sonic output of a 747 (140dB) you're in the "insane" level.
(does that work?)
(what's the output of a Shuttle launch?)
"Top 10 Loudest Noises"
Old 11-16-2013, 12:49 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1041
I'm about with MK, reference + 8-10dB hot on the subs is about as much as I can handle. To the guys who have crazy systems, it's not about watching movies super loud, it about having the power to listen to any level, with minimal distortion. At reference, I'm using around 500 watts per driver, that means ultra clean, distortion free bass. It really does make a difference (though it's fun to crank it up and have some ultra insane demos once in a while! lol)
The JTR's can handle any output you can stand in the room with ease, so now finally, my subs can match any output the JTR's can dish out..... lol.
What I'm planning in my new house (once it gets built) will easily double what I have now. Mark from Mach 5 just laughed at me and when he dropped off my last 4 FTW's, he just smiled and rolled his eyes lol. I'm hoping it will be the end to any possible upgrades....... the key word is "hope" hahaha.
Every driver other than the G-horns, has 1 channel of a FP14 clone on them (4400 watts per channel) each amp is on it's own 20A line and 2 are on a 30A line. The G-Horn is on a peavy ipr2 7500 and my 2242's have a inuke 6000dsp.
N8DOGG is offline
Old 11-16-2013, 01:27 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
I'd try and get it as exact as impossible, so 3332cf is fine. Quad S2s, right???
3332cf / 11.2 SI = 298 or 5 Star ULF!
Awesome choice of subs! That's going to be one heck of a setup...I do believe you may be the first Commercial sub HT with a 5 Star@10hz ULF score!
Old 11-16-2013, 01:32 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
:eek::eek: :eek:
Are you doing IB?
Old 11-16-2013, 02:18 PM
MKtheater's Avatar
Liked: 1122
I am loving the IB/baffle wall setup. If anything the wall has decreased decay times by a significant amount.
Marantz 7702 Atmos
Old 11-16-2013, 02:32 PM
carp's Avatar
Quoted: 2493 Post(s)
Liked: 1753
Have you done any comparing to see how many FTW's it takes to = the output of 1 GHorn?
carp is offline
Old 11-16-2013, 02:46 PM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
Wow thanks Dominguez1. I was just in the beginning part of this thread reading how to calculate it. I kinda didn't understand it. After fast forwarding to see the replies ran into yours. Thanks again. But I still don't know what it means..lol. I need to read more here.
rhed is offline
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
