Your Home Theater ULF Score - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 522Likes
Old 12-04-2013, 12:47 PM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1123
I have all concrete except the ceiling. 4 walls and the floor, just a bigger gap in between on 2 of them. My whole basement is surrounded by concrete. Underground!
Marantz 7702 Atmos
MKtheater is online now
Old 12-04-2013, 01:03 PM
steve nn's Avatar
Liked: 433
Originally Posted by dominguez1 View Post
DIY is just sick...puts things in perspective compared to commercial. Congrats. Wish I had the DIY skills.
Lol.. Wish we had some good examples of 10-18 cu ft 15-18" LLT's ($1000-1300 dual) to compare. smile.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 12-04-2013, 01:17 PM
Point Source
beastaudio's Avatar
Quoted: 3518 Post(s)
Liked: 2835
Now I wish I had done compression measurements of the big LLT's I built out!!! Darn.... Scott Simonian probably could with his RLP 18's
beastaudio is offline
Old 12-04-2013, 01:27 PM
Cowboys's Avatar
Liked: 107
Originally Posted by basshead81 View Post
sub placement is key. I get great tactile response at low levels and can feel the bass at -30. The beauty of my setup(granted its nothing compared alot of setups her on AVS) is the entire seating area gets the exact same tactile sensation.
Is your room seal or open?
Cowboys is offline
Old 12-04-2013, 01:38 PM
steve nn's Avatar
Liked: 433
I bet he could! We got to get to him before he goes off the deep-end with his 8 18"s. PM sent..
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 12-04-2013, 02:15 PM
ahmedreda's Avatar
Quoted: 302 Post(s)
Liked: 216
I have 4 concrete surfaces in my room. Using those calculations, that would put me at reference at 4.5 stars at 12.5hz (reference) and above reference at 16 hz and up using the 2xF15HPs that I exchanged. I am fairly sure that the output was being compressed before hitting reference when compared to the output of the FV15s at the same levels. The idea seems correct but may be lower factors. just my 02 smile.gif
The above post shows the impact of transmission loss compared to a suspended wood floor versus concrete construction.
We've always known that the construction materials that encase your HT room does have an impact on db in your room. Where you have lossy construction, you will get less gain as compared to dense material like concrete or brick. The current ULF score methodology does not currently consider the construction of your HT walls and floor. So I'm going to take a shot on how this might be integrated in:
Currently, to calculate your ULF score we need two variables: Room Size and Subs. Trying to keep this simple, we could add 1 more variable; # of concrete/brick surfaces. From the post above, it looks as though from 10-20hz, there is an avg of 6db gain compared to the single raven. The HT owner has 3 surfaces that are concrete (2 walls and floor). Generally speaking and being conservative, what if we say for every concrete surface of your room, we add 2db to your room output. Let's take some examples on how this might change the current scoring:
Using the log calculation, for every 2db gain, we would multiply the number of SIs for HT by a certain factor:
1 concrete wall = 1.26
2 = 1.58
3 = 2.00
4 = 2.51
5 = 3.16
6 = 3.98
JapanDave's HT is all concrete; walls, floor, and ceiling
6 concrete walls = a factor of 3.98
3.98 * 23.5SI = 93.6 SI
2900cf / 93.6 = ULF Score of 31
GP 1/8 space estimate = 134.6db @ 10hz
MK's HT has 4 concrete surfaces (3 walls, floor)
4 concrete walls = a factor of 2.51
2.51 * 12 SI = 30.1 SI
1510cf / 30.1 = ULF Score of 50.1
GP 1/8 space estimate = 124.8@10hz
I have 3 concrete surfaces (2 walls, floor)
3 concrete walls = a factor of 2
2 * 4.4 SI = 8.8 SI
1900cf / 8.8 = ULF Score of 216.4 (upgrading me to 5 star)
GP 1/8 space estimate = 114.1@10hz
Basshead has 1 (?) surface; concrete floor
1 concrete wall = a factor of 1.26
1.26 * 3.6 SI = 4.5 SI
2400cf / 4.5 = ULF score of 529 (remains 4.5 star)
GP 1/8 space estimate = 116.9@16hz
Based on the above examples, it seems reasonable. The only way to see how well it works is to go through more member examples.
Check your score based on the new methodology above...does it make sense compared to what you've measured?
Depending on the feedback will determine if this is instituted or not.
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is online now
Old 12-04-2013, 02:24 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
How big is your room?
dominguez1 is offline
Old 12-04-2013, 02:28 PM
BeeMan458's Avatar
Liked: 813
It's not fair. We don't have any concrete surfaces. (long, pathetic, sad, old man face) Boo-hoo me. tongue.gifbiggrin.gif
BeeMan458 is offline
Old 12-04-2013, 02:30 PM
ahmedreda's Avatar
Quoted: 302 Post(s)
Liked: 216
It is 12x20. I have concrete floors, 3 walls are concrete. 1 wall (12ft) and the ceiling are drywall.
My home theater
Display: JVC RS400
Old 12-04-2013, 02:47 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
8ft ceilings? This would put you at 1920cf. IMO, you should be at those levels. Same size room as mine, but with an additional concrete wall. Your room should have plenty of gain to get you high output.
Is it sealed?
Old 12-04-2013, 03:43 PM
carp's Avatar
Quoted: 2493 Post(s)
Liked: 1757
Dom, I hear what you are saying and I like the idea but here is where it gets even messier and hard to calculate. Take my room for example. I do have 3 concrete walls, but my room doesn't take up the whole space in the basement I have a wall that separates my room from the laundry room next to me. What i mean is my room has 2 concrete walls and a drywall/studs wall but on the other side of that wall is room that is 8 feet wide and then has a concrete wall.
Add that to the fact that the right side wall in my room (when facing the screen) doesn't have concrete all the way up to the ceiling (concrete up to 5 feet), the screen wall has concrete up to about 6 feet, and the concrete wall on the other side of the laundry room has concrete up to 8 feet.
carp is online now
Old 12-04-2013, 03:49 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
Maybe it would be better to approximate or calculate the percentage of surface area made by concrete/brick - and see here that gets you.
HopefulFred is offline
Old 12-04-2013, 03:50 PM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5248
I have one 5ft opening along a 20ft wall.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 12-04-2013, 04:19 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
I should have specified better. You should count the walls if they fall within your home theater area. In your case, it would be the 2 walls and floor. Its an estimate, so I wouldn't worry about the 6ft thing as you described.
Remember, there is no replacement for accurate measurement gear. This is the only way to truly know how what your room performance will be. However, hopefully this should give you a general idea of what to expect.
Old 12-04-2013, 04:41 PM
carp's Avatar
Liked: 1757
Gotcha, thanks.
carp is online now
Old 12-04-2013, 05:10 PM
booga24's Avatar
Quoted: 20 Post(s)
Liked: 44
Pros,
I am considering VTF- 15 or FV15HP in a 12x20x8 sealed room, please let numbers speak for me smile.gif.
booga24 is offline
Old 12-04-2013, 05:14 PM
BeeMan458's Avatar
Liked: 813
Originally Posted by booga24 View Post
Pros,
Have you looked at the first post in this thread? The first spreadsheet contains information regarding the FV15HP and the second spreadsheet contains information regarding the VTF-15H.
What are your expectations?
Have you checked out the Hsu and Rythmik threads?
Old 12-04-2013, 05:44 PM
ahmedreda's Avatar
Quoted: 302 Post(s)
Liked: 216
It is sealed. The concrete walls are really concrete blocks. They have furring strips and 2.25" of XPS foam then drywall. Do they still count as concrete walls?
Is it sealed?
My home theater
Display: JVC RS400
Old 12-04-2013, 05:45 PM
ahmedreda's Avatar
Quoted: 302 Post(s)
Liked: 216
Pros,
I have the same exact dimensions and I went with 2 of the FV15HPs and I am fairly happy with them.
My home theater
Display: JVC RS400
Old 12-04-2013, 06:01 PM
Cowboys's Avatar
Liked: 107
^^ Only fairly happy???
Cowboys is offline
Old 12-04-2013, 06:11 PM
ahmedreda's Avatar
Quoted: 302 Post(s)
Liked: 216
My home theater
Display: JVC RS400
Old 12-04-2013, 07:54 PM
Cowboys's Avatar
Liked: 107
^^ that's better.
Cowboys is offline
Old 12-04-2013, 08:04 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
Carp, so I recalculated your score with the concrete surfaces. This puts you at 5 Star, 191@10hz
It also estimates that you can hit 119db at 10hz. Does that seem realistic? Have you ever ran a max sweep?
That does seem like a lot...
Old 12-05-2013, 01:52 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5310 Post(s)
Liked: 4190
Scott Simonian is offline
Old 12-05-2013, 03:12 AM
popalock's Avatar
Quoted: 1234 Post(s)
Liked: 1716
Hummm...
The concrete wall issue seems to muddy up the waters a bit. For instance, based on how my room volume is calculated in this thread, I have 4 concrete surfaces (including the floor), but all walls are built out with 2x4's and drywall. Since my walls are built out, are they still counted as concrete surfaces?
Also, since ULF is perceived through tactical sensation, wouldn't having a suspended floor deliver more ULF sensation vs a concrete floor?
Archaea likes this.
popalock is offline
Old 12-05-2013, 05:45 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
Hummm...
Yes, they would be considered concrete. My walls are also drywall/studs, but behind them are concrete.
Love your thought about ULF and tactile sensation, but for this thread, we're only measuring ULF via room size/displacement/spl. Otherwise, tactile transducers would play a part in the score. I definitely think there is merit to that...just quantifying it needs to be hashed out more...see the link in my sig about measuring tactile feeling. smile.gif
With your 4 concrete surfaces, spl estimate is 127@10hz...does this sound right to you?
Old 12-05-2013, 06:09 AM
carp's Avatar
Liked: 1757
No, I don't think I could hit 119 db's at 10hz but I'm not positive. I did do compression sweeps once but i had problems with my omnimic clipping and I also got scared eek.gif but one of these days I'm going to do it again.
carp is online now
Old 12-05-2013, 06:14 AM
BeeMan458's Avatar
Liked: 813
Well, that's one way of articulating how you think you have plenty of headroom.
Old 12-05-2013, 06:29 AM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5248
Dom, I think this is pretty accurate myself. I have 1 concrete wall and 3 dry wall/stud walls. You calculated 116.9db @ 16hz which seems to be real close to what I have measured. Actually I have measured around 119db but thats at subs limits and distortion is up there a bit. So I would say your calculation is spot on in relation to clean output.
Old 12-05-2013, 06:36 AM
BeeMan458's Avatar
Liked: 813
Maybe if you added a fourth XV15 and stacked it on top of the corner placed unit. Would that take care of this stress?
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
