Your Home Theater ULF Score - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 522Likes
Old 08-29-2013, 11:28 PM
eNoize's Avatar
Quoted: 24 Post(s)
Liked: 88
Only measurements I could find for the VTF-15H are from 2011 by Sound & Vision, but the lowest they measured were at 20Hz. So, I'll have to go with those numbers for the moment until Josh posts his findings, which hopefully will be soon. smile.gif I also have a slot-ported, dual-opposed DIY build, but I won't add that into the equation until I make proper measurements with mic and REW.
Hopefully, I'm doing this right.
VTF-15H is 114 @ 20Hz (1 port open, EQ1) inside a 2500ft^3 Space, which comes out to 809@20hz
M. Enois Duarte
High-Def Digest
eNoize is offline
Old 08-29-2013, 11:38 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Is the 114 @ 2m?
dominguez1 is offline
Old 08-29-2013, 11:39 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Originally Posted by dominguez1 View Post
Is the 114 @ 2m?
no thats 1m peak...need to subtract 9db. should be within a db or so of the xv15.
dominguez1 likes this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 08-29-2013, 11:50 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
No thats not correct. The 2m rms numbers would be 104-105db...so the si number @ 20hz would be 1.0
2500÷ 1 = a ulf score of 2500 @ 20hz.
You need 3 VTF-15's to get a ulf score of 833 @ 20hz.
Old 08-30-2013, 12:04 AM
eNoize's Avatar
Quoted: 24 Post(s)
Liked: 88
Is the 114 @ 2m?
Probably @ 1m from Sound & Vision review, which is why I'm anxiously awaiting Josh's measurements, but I think basshead is right that the 15H is comparable to the XV15.
So, plugging in those numbers, this looks more accurate
2451 @ 16Hz
2874 @ 20Hz
M. Enois Duarte
High-Def Digest
eNoize is offline
Old 08-30-2013, 12:13 AM
eNoize's Avatar
Quoted: 24 Post(s)
Liked: 88
BTW, dom, really love the thread, though it only makes want to add more subs to my room. Looking at probably making a pair of Othorns with SI 18s.
M. Enois Duarte
High-Def Digest
eNoize is offline
Old 08-30-2013, 07:04 AM
laugsbach's Avatar
Quoted: 130 Post(s)
Liked: 199
Here is my score with some guess work:
3000 cubic foot theater room...(3) EP-4000 amps.
10Hz - Ricci's DIY XXX Ported with a RE Audio MX-18 D2 Driver = 836
(IIRC, Josh said to subtract 2dB down low from the XXX...)
12.5Hz - (4) CHT 18.1 = 1027
(I am using the numbers from the eD A7S-450...should be close)
Total score of both = 461
As you are gathering the ULF scores maybe add the room size next to the score to see the effect the room has...just a thought.
laugsbach is offline
Old 08-30-2013, 07:11 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Thanks L! Good idea with the room size. I'll put that in.
Have you seen what the big guy can do at 12.5hz??? Check the first post (updated last night). It's like 10 SI! Calculate your score at that hz and see what you get...
Old 08-30-2013, 07:32 AM
Frohlich's Avatar
Quoted: 1164 Post(s)
Liked: 1112
Sorry for the temporary thread jack. Paolo, thanks for coming over last night. It was a pleasure meeting you and Larry. Sorry I had to cut it short but I had "dad" duties I needed to get to. We will have to carve out a bigger window of time next go around so you can measure out my dual JTR S2 subs. I am sure there is plenty of room for improvement with sound treatments,etc.. Take care.
Frohlich is offline
Old 08-30-2013, 09:21 AM
laugsbach's Avatar
Quoted: 130 Post(s)
Liked: 199
Old 08-30-2013, 09:25 AM
laugsbach's Avatar
Quoted: 130 Post(s)
Liked: 199
Originally Posted by Frohlich View Post
Paolo, thanks for coming over last night. It was a pleasure meeting you and Larry....
I look forward to coming back...
Old 08-30-2013, 09:31 AM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Originally Posted by basshead81 View Post
I do not think thats figured correctly. you are suppose to use the si conversion number from dominguez chart, not the output at the given frequency from my understanding.
Using the PB13, the si number is 1.0 @ 16hz and .7 @ 12.5hz
Dual PB13's would have a si of 2.0 in 20hz mode @ 16hz and a si of 1.4 in max ext. mode @ 12.5hz
2500÷1.4=1786 @ 12.5hz
2500÷2 = 1250 @ 16hz
The PB12 plus would have a si of .7 @ 16hz, so duals would give you a si of 1.4.
2500÷1.4 = 1786 @ 16hz
landshark1 is offline
Old 08-30-2013, 09:48 AM
Frohlich's Avatar
Liked: 1112
I always thought I had overkill for subs in my set-up..now, after meeting some felllow local HT nuts, I realize I have "underkill" :-)
Frohlich is offline
Old 08-30-2013, 09:50 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Originally Posted by landshark1 View Post
actually I hosed your score...since dominguez changed the chart this is what I come up with
The 12+ has a si of 2.0 in 16hz mode @ 16hz. 2500÷4 = 625
The 12+ has a si of 1.8 in 20hz mode @ 20hz. 2500÷3.6=694
Old 08-30-2013, 02:48 PM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Old 08-30-2013, 04:16 PM
carp's Avatar
Quoted: 2486 Post(s)
Liked: 1741
Carp. If it's too much trouble to move a few subs behind your LP this weekend, can you try something else for me if you get the chance.
Take one of your subs currently under your screen. Move it a few feet out from the wall. Play those same two tracks again...but this time, sit on one of the subs. Let us know how the 6-7hz tactical feeling is when you sit on the sub.
Impractical?...Maybe...but should provide a slightly better ideal of what ULF adds to the experience in a near field situation.
Do it for the Science of it!
I'll try it out when I get a chance, I'll try moving one of the subs out from the screen and sitting on it.
It looks like I should try some more scenes too, I probably shouldn't completely make my mind up from just bass I love you and Irene.
carp is offline
Old 08-30-2013, 04:45 PM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Olympus Has Fallen. About 29min in. Washington Monument Scene... Epic.
popalock is offline
Old 08-30-2013, 05:12 PM
SupaKats's Avatar
Quoted: 66 Post(s)
Liked: 120
Olympous Has Allen. About 29min in. Washington Monument Scene... Epic.
Haven't seen that one. Got to love funny typos.
My Basement HT/Gaming/Bar Space.
Official Hip Hop Thread
Equipment
Epson 8350 on a 100" Visual Apex screen, Pioneer VSX-53, Polk RTi A5(x2) CSi 5 RTi A1 (x2) RTi 4(x2), Outlaw Audio LFM-1 EX, PS3, XBox 360 with HD-DVD add-on.
SupaKats is offline
Old 08-30-2013, 06:52 PM
popalock's Avatar
Liked: 1712
lol... I hate my mother ****ing phone with a passion.
popalock is offline
Old 08-30-2013, 07:23 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Hey Fro!
Thanks for having us! You've got some stellar equipment, that's for sure. Your S2's were very impressive. I'd be glad to come over and really help optimize your system! Shoot me a pm and we'll get it on the calendar.
Also, you're more then welcome to swing by either of our places to hear our setups! It's always fun to hear other's HT rooms.
Old 08-30-2013, 07:26 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Impressive. Looks like we both have 12.5hz sweet spots...
Old 08-30-2013, 07:40 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Had to use the calculator on this one. As you said Landshark, I used the PB13 Ultra and subtracted 3db: 2500cf room
Hz SI Sub/Driver Your Sub's lowest freq's max output (ground plane) dB Difference Equivalent SI(s) Quantity Total SI(s) HT ULF Score
 (cf per SI)
16 97.8 PB12 + (16hz) 102.1 4.3 1.6 2 3.2 781
20 104.2
PB12 +
(20hz)
107.6 3.4 1.5 2 3.0 833
Old 08-30-2013, 07:46 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Old 08-30-2013, 07:49 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Have you seen OHF or Oblivion? Those scenes have strong <15hz content.
Old 08-30-2013, 08:11 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Old 08-30-2013, 08:15 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Thanks eNoize.
Othorns would be killer...but why not the Gjallarhorn? Extends down to 10hz, and at 16hz it equals 10.6 SI! Two of those and it's 21.2 SI at 16hz??? Wow.
Old 08-30-2013, 08:59 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
lukeamdman's horn setup
2 gjallarhorns and 2 othorns in a 2500cf room!
1 gjalla = 10.6 SI, 1 othorn = .6 SI, all at 16hz
luke has an equivalent of 22.4 SI @ 16hz!
2500 / 22.4 = 112@16hz.  Pure insanity...and lowest score for 16hz!
Old 08-30-2013, 09:02 PM
eNoize's Avatar
Quoted: 24 Post(s)
Liked: 88
Thanks eNoize.
I'm tempted to go Gjallahorn, but not too sure I have enough space. My goal is definitely for 10Hz with as small a footprint possible, so we'll see by the time I ready to start building.
M. Enois Duarte
High-Def Digest
eNoize is offline
Old 08-31-2013, 08:45 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Sounds like single SIs or Dual Oppossed SIs might be the best fit. For the smallest size and most capability, you may want to step up drivers. More costly, but will save on space.
What interested in the othorn? I didn't think that extended low.
Old 08-31-2013, 09:59 AM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
Hi Dom,
Great stuff, thanks for the efforts.
My problem is in the assumption that each SI-18 (or equivalent) is equally powered.
The SI reference being used for these calcs was powered by a K10 on a 220V/50A line. eek.gif
It's not realistic to assume that (for example) a system of 8 of them would each have its own K10/220V/50A power plant.
It's also not realistic to assume that a system of 1-SI-18+K10/220V/50A would last more than one sitting of WOTW in my 3500 cubes HT at any sort of spirited playback level.
I think that your formula will only work accurately with commercial subs, using a commercial subs results as the reference.
I apologize for this post in that I usually I have some alternative choices or an equalizer to the existing formula, but in this case I don't because I haven't had enough time recently to do much extra-carricular thinking. I've just been watching the greatest MWB ever made and enjoying the heck out of it. cool.gif
Anyway, keep up the great work and hopefully this will evolve into a world class standard for actual use in actual rooms... something that has always been sorely lacking for the general sub-buyeing public.
bossobass is offline
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
