Your Home Theater ULF Score - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 692Likes
Old 06-19-2014, 06:01 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Room size = 2720 actually it is a little bit smaller but I don't think that will effect the over all score.
Subs JTR cap s2 and 8x infinity 1260w 1.5 cubes (they just about have the same output in winisd)
is it ok to assume that this is equal to two cap s2's? If so....
10hz= 485
12.5hz= 453
16hz= 412
20hz= 438
that would be 4.5 stars across the board.
How do I figure 5hz?
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
Old 06-19-2014, 11:56 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1994
Originally Posted by dominguez1 View Post
Send both! Still trying to master the DIY estimates...
Are most sims at 1M ground plane?
So here's the simulated graph from LTD for one of my cabinets with the UXL-18 driver powered my one channel of my iNuke 6000DSP amp.
That graph was for a 11cubic/ft cabinet, mines actually 13cubic/ft but I'm sure its close enough to mine.
Name:	LTD-M18 graph.png
jbrown15 is offline
Old 06-19-2014, 07:29 PM
BassThatHz's Avatar
Quoted: 2225 Post(s)
Liked: 1909
They have a different number of subs...which has the correct sub count?
Neither are my correct scores because the spreadsheet doesn't have my actual subs listed for me to select from.
I am having to approximate my SPL by selecting other subs and quantities to make up the difference.
I'd need you to add these two to the list if you can:
Originally Posted by BassThatHz View Post
box models for my missing subs:
BassThatHz is offline
Old 06-19-2014, 07:56 PM
BassThatHz's Avatar
Liked: 1909
For those that want to be included, just post your frequency response to 5hz.
I make no claim to the accuracy of my ECM8000 and CM-140 mics, but this is what it is telling me I get:
Wish I had an ACO pacific mic, that would make things easier...
ID:	127394   Click image for larger version
Old 06-20-2014, 05:27 AM
Quoted: 978 Post(s)
Liked: 506
I have my chart but I never do a max spl reading. This was measured at -20MLV.
Name:	all subs newest.jpg
Old 06-20-2014, 10:51 AM
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 1037 Post(s)
Liked: 3264
Post 2 Member Scores Updated
  • MiniHT 4.5 star (10hz)
  • laugsbach - 5 star (12.5hz), 4.5 star (10hz)
I've also calculated and added Ralph Potts score. I respect his work, and thought it would be interesting to understand what kind of ULF experience he has in his room.
Room Size = 14x23x8 = 2576cf
Sub = SVS PB13-Ultra (15hz mode)
1 PB13 = 2.3 SI @ 16hz
2576cf / 2.3 SI = 1120@16hz or 4 star
So, he's right on the edge of 4 and 3.5 star so he's probably right around reference output at 20hz or so...
Greetings,
Thanks for adding this dominguez1!
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is online now
Old 06-20-2014, 04:54 PM - Thread Starter
dominguez1's Avatar
Quoted: 1065 Post(s)
Liked: 852
10hz= 485
12.5hz= 453
16hz= 412
20hz= 438
Do you have 1 sim of the infinity you can post? I can figure out from there.
Impressive! Nice signal chain...rare to get to 5hz without thought out equipment selection.
That's all it takes to get into the 5hz category. Your ULF score will estimate at what output you can achieve.
dominguez1 is offline
Old 06-20-2014, 05:17 PM - Thread Starter
dominguez1's Avatar
Liked: 852
Here you go:
I basically subtracted 7db from your response to calculate your estimated output. 7db is the aprox. difference between the SI sim, and data-bass's measurements. Not perfect, but should be close.
Nice work! In that small room, it has to be plenty tactile!
Name:	jbrown15 ulf score.png
ID:	128873   Click image for larger version
Name:	jbrown15 Ported SI Estimate.png
Old 06-20-2014, 05:21 PM
jbrown15's Avatar
Liked: 1994
Thanks Dom! It's crazy to have 5 stars down to 10hz....lol
Pretty crazy what you can do with only 3 grand.
jbrown15 is offline
Old 06-20-2014, 05:26 PM - Thread Starter
dominguez1's Avatar
Liked: 852
Are these sims at 1M? Something seems off. Your Mal-X once I subtract the 7db at 20hz equates to 106db...too low. The UXL-18 is 108, and the FTW-21 is estimated at 110.
Old 06-20-2014, 05:30 PM - Thread Starter
dominguez1's Avatar
Liked: 852
Originally Posted by Ralph Potts View Post
Greetings,
At 16hz, a ULF Score of 1148 you are 3.5 stars and can produce an estimated 110db ground plane, 4M distance.
At 20hz, a ULF Score of 902 you are 4.5 stars and can produce an estimated 119db ground plane, 4M distance (above reference output).
The ULF star is just a very general way to group you at each ULF frequency. It becomes more meaningful when you compare others with a similar ULF score or star.
For example, Ralph Potts has a ULF score of 888 (since I added his PC12NSD), and is 4 stars at 16hz. Now you have a little better understanding of his ULF experience as compared to yours as he reviews movies.
Ralph, I actually will be updating your score since you added the PC12NSD. See above!
Ralph Potts likes this.
Old 06-20-2014, 05:37 PM - Thread Starter
dominguez1's Avatar
Liked: 852
Originally Posted by Tom Vodhanel View Post
Hi all,
Josh will be measuring a new XV15se before too long so I figured posting our in house data on it won't hurt. I believe this is only the warm weather tests averaged but I will need to triple check that. Cold weather can lead to 1-2dB more output.
16 / 97.2
20 / 107.5
25 / 110.7
31 / 112.9
40 / 114.2
50 / 116.5
63 / 116.7
80 / 117
100 / 116.3
16-100 / 113.7
this is all 2m/rms. Add 9dB to scale to 1m/peak
Tom V.
Power Sound Audio
Will be revising the XV15SE numbers to the above on the next update.
I imagine Tom feels pretty good about the accuracy of these as his test likely matched very closely to Josh's with the XS15SE and XV30SE
Old 06-20-2014, 05:53 PM
Quoted: 978 Post(s)
Liked: 506
Thanks! I sent you a pm of sim that LTD02 made for me.
Old 06-20-2014, 07:11 PM - Thread Starter
dominguez1's Avatar
Liked: 852
The blue line represents 4 infinity 1260ws (as you told me) and produces 109db @ 20hz.
109db - 6db = 103db for 2 drivers
103db - 6db - 97db for 1 driver
97db - 7db = 90db at 20hz for the SI calibration
Based on the above, I calculated the below:
Multiply this by 8 drivers with appropriate power, and your S2 and you get:
Great theater btw! Love the nearfield placement of your infinity's!
Name:	Infinity 1260w.png
ID:	128985   Click image for larger version
Name:	Pain Infliction ULF Score.png
Pain Infliction likes this.
Old 06-20-2014, 07:27 PM - Thread Starter
dominguez1's Avatar
Liked: 852
Here you go:
Ugh...that doesn't look right Jbrown...there's no way that 10hz number is correct. The UXL in a sealed design only produces 92.2db at 10hz, so no way a ported design with a 16hz tune can produce 96db at 10hz.
MK, can you run a sim like you've done in the past where you have the SI sim on the same chart as Jbrown's sim?
Old 06-20-2014, 08:06 PM
jbrown15's Avatar
Liked: 1994
I was wondering about that, I know my inroom output is really strong at 10hz though. With just two subs up and running I measured with REW around 123dB.
I know its not scaled correctly but the graph still clearly shows around 123dB at 10hz from just two subs.
I'm hoping to get a chance to take some proper measurements this Sunday if I have a chance.
Name:	sub meas #2.jpg
jbrown15 is offline
Old 06-20-2014, 09:20 PM - Thread Starter
dominguez1's Avatar
Liked: 852
Old 06-20-2014, 09:35 PM
jbrown15's Avatar
Liked: 1994
Crazy output for ported...what mic do you use?
I have a Cross-Spectrum UMIK-1 usb mic.
We LTD02 came up with the design we were shooting for a port tune of 15-16hz, but he thinks with the elbow in the port its actually closer to 13-14hz. Which some of my measurements kind of suggest also.
jbrown15 is offline
Old 06-21-2014, 05:26 AM
Quoted: 978 Post(s)
Liked: 506
Thanks! Those infinity subs are small and cheap and perfect for behind my seats. I wouldn't use them anywhere else though, because I would definitely go with 18's. I just couldn't fit anything large behind my seats and be able to recline.
Thanks for figuring all of this out for me. Can you figure out 5hz with the chart that I posted or do you need a sim?
Old 06-21-2014, 05:42 PM - Thread Starter
dominguez1's Avatar
Liked: 852
That smoothing and scale is the problem and why it is misleading.
I ran across another response of yours in a different thread that looks more realistic.
You should probably not use that chart any more as it is not representative of what you're really getting...especially below tune.
Old 06-21-2014, 06:21 PM
jbrown15's Avatar
Liked: 1994
Yes but this measurement sweep was taken with my AVR master volume set at like -30 from two subs, the first graph while scaled incorrect was with my AVR at -10 if I recall. I'm not even pushing the subs yet. The first graph was not a max SPL sweep. Take away the null at around 68-70hz and that's a fairly flat graph with very little EQ work on my part to flatten it out. From 60hz down to 10hz there's only about a 7dB difference. That's not bad, I need to get my miniDSP setup and running before I can't really dial everything in. Both of those graphs were with 1/12th smoothing also.
I know the first graph is scaled incorrectly because its increments of 20dBs and the second graph is 5dB increments, but the two graphs both show the same thing, one is just stretched out more from 10hz-30hz.
jbrown15 is offline
Old 06-21-2014, 06:45 PM
bear123's Avatar
Quoted: 1733 Post(s)
Liked: 2542
The first graph uses the correct logarithmic scale on the x axis, the second one is not using a log scale. There is a simple fix...just reopen the first REW measurement, scale it properly, and re-save the image.
X axis log scale 10-200 Hz
Y axis 85-145(60 dB spread at higher level)
Oddly scaled graphs, which both of those are, make it difficult to get a clear visual representation of the FR
Its not the issue of 5 or 20 db spacing on the Y axis, it is too large of a total spread which makes the FR appear much smoother than it should be. A 60 dB total scale results in 5 dB increments....but if you had a 0-200 dB scale in 5 dB increments, it would still appear overly smooth.
bear123 is offline
Old 06-21-2014, 06:53 PM
bear123's Avatar
Liked: 2542
For example, improper scaling followed by proper scaling, same exact sweep:
Name:	110 non standard scaling.jpg
ID:	130082   Click image for larger version
Name:	110 scaled properly.jpg
bear123 is offline
Old 06-21-2014, 06:54 PM
Quoted: 978 Post(s)
Liked: 506
With eq I can see jbrown flat to 10hz and rhed flat to 5hz. Cutting that is, so I would tune jbrown's to 91db and boost the 65hz-90hz.
Old 06-21-2014, 08:52 PM
MKtheater's Avatar
Quoted: 1679 Post(s)
Liked: 1199
The problem is that 123 dBs at 10 hz with a MV at -10 is way off with a sweep. The mic is not calibrated to correct levels or the bass is running 18 dBs hot. These subs are tuned to 15hz? All of you should extend the graphs to 3-120hz and a range of 105 to 63 dBs just for response. After that then turn the MV up 5 dBs for compression sweeps adjusting the y axis accordingly. How big is the room jbrown and how far are the subs?
MKtheater is offline
Old 06-21-2014, 09:16 PM
bear123's Avatar
Liked: 2542
Have the PSA subs been fully updated? Not sure if I need to repost my numbers again?
bear123 is offline
Old 06-21-2014, 09:19 PM
bear123's Avatar
Liked: 2542
Although there is no "official" rule for scaling graphs, everything I have seen suggests 45-105 dB and low end of roll off to 200 i.e 10-200 or 3-200 or 5-200 depending on extension. Otherwise there is no standardization for how smooth one's graph appears compared to others that are in the more standard format.
bear123 is offline
Old 06-21-2014, 09:21 PM - Thread Starter
dominguez1's Avatar
Liked: 852
Not yet. I'll post the new ulf Calc soon, and let you know .
Old 06-21-2014, 09:22 PM
bear123's Avatar
Liked: 2542
Cool, thanks Dom.
bear123 is offline
Old 06-21-2014, 09:29 PM
jbrown15's Avatar
Liked: 1994
The mic was run with the calibration file, the room is 1803cubic/ft and the subs are about 10ft away. I run my speakers and subs level matched to 83dB which is what's used with the Disney WOW disc though. So I guess that's 8dB hot?
jbrown15 is offline
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
