Your Home Theater ULF Score - Page 68 - AVS Forum | Home Theater Discussions And Reviews
 755Likes
post #2011 of 5032 Old 06-21-2014, 09:31 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
I just need more time to properly set them up and get them fully EQ'd.
Sadly I just don't seem to have much free time lately and its only going to get worse as my wife is expecting our third child in September LOL
jbrown15 is offline
post #2012 of 5032 Old 06-22-2014, 05:16 AM
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6457
Originally Posted by jbrown15 View Post
The mic was run with the calibration file, the room is 1803cubic/ft and the subs are about 10ft away. I run my speakers and subs level matched to 83dB which is what's used with the Disney WOW disc though. So I guess that's 8dB hot?
It sounds as if your mic is reading 10db off. You should verify that your mic is correctly calibrated with a spl meter using pink noise test tones. -10 on th AVR running +8db hot should put the subs around 113db. If you were actually running +18db hot the bass would be drowning out the mains or atleast sound very unbalanced.
Congrats on the third child but it sounds like your free time is being spent working on the wrong things.
Subwoofers come first, making babies 2nd.
basshead81 is offline
post #2013 of 5032 Old 06-22-2014, 06:32 AM
MKtheater's Avatar
Quoted: 1717 Post(s)
Liked: 1251
I forgot which is the bottom number but as long as one gets 5 dB increments on the y axis. 3-120 hz is the LFE bandwidth so one can see their crossovers effects as well. We like to see the signal chain drop off too.
I meant level calibration with the mic, not the correction files. What levels are the Disney sweeps? Are they 0 dBFS?
MKtheater is online now
post #2014 of 5032 Old 06-22-2014, 09:41 AM
notnyt's Avatar
Quoted: 2726 Post(s)
Liked: 2511
Originally Posted by Pain Infliction View Post
With eq I can see jbrown flat to 10hz and rhed flat to 5hz. Cutting that is, so I would tune jbrown's to 91db and boost the 65hz-90hz.
Boosting below tune is no good.
notnyt is offline
post #2015 of 5032 Old 06-22-2014, 09:51 AM
jbrown15's Avatar
Liked: 1995
Agreed, I won't be boosting anything below the port tune. Which is around 14hz, Notnyt what was your port tune again?
jbrown15 is offline
post #2016 of 5032 Old 06-22-2014, 09:52 AM
notnyt's Avatar
Liked: 2511
aimed for 15, ended up with 14.7
notnyt is offline
post #2017 of 5032 Old 06-22-2014, 11:07 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
I never said boosting below tune. I said cut everything to 91db and then boost the 65 to 90 area.
For rhed, I would tune everything to 75db.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #2018 of 5032 Old 06-22-2014, 11:25 AM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
Definately sounds like a plan Pain. Though, I'll just wait till the 215's,S8's, and new amps arrive and redo all the calibrations again. Probably might move the subs around too and see if my room can give me a more better response. The latest measurement I posted was just a auto calibration from the Antimode dual core. No house curve or boosting. Then I reran MCACC. I just redid everything since my electrician came by for a day and did work on my dedicated circuits. And to see if I could get bumped up from the 10hz category to 5hz category.
rhed is offline
post #2019 of 5032 Old 06-22-2014, 11:39 AM
Quoted: 978 Post(s)
Liked: 506
rhed, you actually have a great response. No auto calibration that I have seen can do it like a person can, but it seems like your room and subs work well together. That makes tuning so nice and easy and I bet it wouldn't take long to get a flat tune out of your subs. Mixing the 215's in with the cap s2's might make it a little bit harder though. Going to have to set some delays around port tune on the 215's. Are you still getting the other two cap s2's? Maybe that is another reason you had an electrician come by?
post #2020 of 5032 Old 06-22-2014, 12:04 PM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
I'm no worries with the 215's. As with movies, I would still run them as small and X over 60 or 80hz. But with music is the main reason for me with those speakers. So when I listen to music I'll set subs to "no" and "large" for mains in pure direct mode. That was my plan.. As with the two more caps? My wife told it's either that or the Sony projector.. Dang.. Don't know which way to go.. Lol..
rhed is offline
post #2021 of 5032 Old 06-22-2014, 01:37 PM
Quoted: 978 Post(s)
Liked: 506
Depends on what Sony projector and how big your screen is. However, you already have FOUR cap S2's! It's all good though because I am more of an audiophile than a videophile too.
post #2022 of 5032 Old 06-22-2014, 03:10 PM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
Yea so am I. More audio then video. Btw, I meant JVC not Sony. As far as which one, I don't know. As I will decide which route by end of this year or early next year.
rhed is offline
post #2023 of 5032 Old 06-22-2014, 04:23 PM
BassThatHz's Avatar
Quoted: 2317 Post(s)
Liked: 2065
Originally Posted by dominguez1 View Post
Are these sims at 1M? Something seems off. Your Mal-X once I subtract the 7db at 20hz equates to 106db...too low. The UXL-18 is 108, and the FTW-21 is estimated at 110.
I put in the single coil numbers instead of the dual coil. I was wondering why there was a bump in the response. LOL
It's 1m anechoic.
For the FTW-21 in the same box I get this.
Both of these are way over their rated power.
FTW 21 has 34mm and 1.2kW RMS.
Mal-X 21 has 32mm and 1.5kW RMS.
Which looks like this:
ID:	131426   Click image for larger version
ID:	131434   Click image for larger version
ID:	131458   Click image for larger version
ID:	131466   Click image for larger version
BassThatHz is offline
post #2024 of 5032 Old 06-22-2014, 04:57 PM
BassThatHz's Avatar
Liked: 2065
Ugh...that doesn't look right Jbrown...there's no way that 10hz number is correct. The UXL in a sealed design only produces 92.2db at 10hz, so no way a ported design with a 16hz tune can produce 96db at 10hz.
MK, can you run a sim like you've done in the past where you have the SI sim on the same chart as Jbrown's sim?
Here is what I modeled for it:
With a 48db/oct filter at tune you could probably squeak this number out by avoiding bottoming out at 13hz.
Or limit the power so that you can get a 10hz score (your are probably somewhere in-between these two extremes with a reasonable filter):
Here it is in a sealed box, just for comparison:
ID:	131522   Click image for larger version
ID:	131530   Click image for larger version
ID:	131538   Click image for larger version
ID:	131546   Click image for larger version
post #2025 of 5032 Old 06-22-2014, 05:42 PM
BassThatHz's Avatar
Liked: 2065
That's one thing that I like about having the TermLab meter, it's calibration is constant, factory set into the silicon and then they submerge it into epoxy, it's all glued in place and not overridable.
It has to be that way otherwise people would be tampering with it to win and make money and sponsors at bass-comps.
Not only that but it doesn't register non-bass, so thumping it with 140dbA of 300-20000hz from your JBL line-array won't do ANYTHING to improve your bass-score.
BUT that also makes it incomparable to any other flat mic, or G/C/A weighted mic on the planet; thus those mic's will always read the higher 140dbA value etc.
It's pretty much plug and play which is handy.
Scott Simonian and basshead81 like this.
post #2026 of 5032 Old 06-22-2014, 06:34 PM
jbrown15's Avatar
Liked: 1995
BassThathz, maybe if you end up coming to the GTG at some point you could help me try to measure my subs? And dial them in a little better?
jbrown15 is offline
post #2027 of 5032 Old 06-22-2014, 08:34 PM
BassThatHz's Avatar
Liked: 2065
It looks like you have them dialed-in perfectly already, if your mic isn't lying to us.
Hard to say 100% for sure unless my ears are in the room; I know what musical bass sounds like (or at least I think I do ).
What's weird is that you don't have any roll off until at least 9hz, which is weird for a ported sub, although the UXL-18 is beefy (to say the least) so there could be some room gain that is adding to it(?)
At 7hz your ~14hz tune should be unloading like crazy and/or be filtered out by the high pass filter (if you enabled one).
Can you take a sweep to 2 or 5hz?
Take a look at NotNyt's ported subs, they are down -3db @ 12.5hz or so. Your UXL-18's should be very similar, although he has a 5000cuft room so you'll have more room gain.
If your mic has no roll-off until 1hz with ported subs, then that's a clear sign something is wrong with
the soundcard/mic (USB though right?)
that or, you have some real funky boost going on...
post #2028 of 5032 Old 06-22-2014, 08:50 PM
jbrown15's Avatar
Liked: 1995
If you take a look at the other graph from the previous page there's one of my graphs that's scaled better in 5dB increments. It definitely shows some roll of below the port tune, I have a high pass filter set at 13hz to prevent the drivers from bottoming out.
Although notnyt has 8 LMS-U drivers I would think that we would have similar ULF performance considering his room is 5000cubic/ft and mine is only 1800cubic/ft.
jbrown15 is offline
post #2029 of 5032 Old 06-22-2014, 09:56 PM
BassThatHz's Avatar
Liked: 2065
Based on my box model above of 98db @ 10hz for 1; for 4 it would be +12db or about ~110db.
Have you tried lowering 50hz by 3db and increasing 67hz by 7db to smooth it? That would get you closer to +-3db from 100 to 13hz, which is darn good.
post #2030 of 5032 Old 06-23-2014, 08:35 PM - Thread Starter
dominguez1's Avatar
Quoted: 1109 Post(s)
Liked: 962
Thanks for the charts bassthathz! Busy traveling for work this week, but when I get some time will update!
dominguez1 is offline
post #2031 of 5032 Old 06-23-2014, 08:44 PM
jbrown15's Avatar
Liked: 1995
I'll give that I try when I get a chance, thanks for the suggestion.
jbrown15 is offline
post #2032 of 5032 Old 06-23-2014, 11:00 PM
tvuong's Avatar
Quoted: 1769 Post(s)
Liked: 1061
^^ you have the 10db vertical scale. The graph has about 12db drop from 10 to 5hz.
tvuong is online now
post #2033 of 5032 Old 06-23-2014, 11:06 PM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
Ok.. What does that mean? Sorry i'm still new to this measurement stuffs.. lol
Btw, Im using a cross spectrum labs mic.
rhed is offline
post #2034 of 5032 Old 06-23-2014, 11:12 PM
tvuong's Avatar
Liked: 1061
^^ it means your output from 10 to 5hz drops tremendously. Depends on your max output at 5hz which your graph does not show, you might not have reference or sufficient output at 5hz to be felt. Scale your vertical to 5db and use 1/12 or no smoothing to make it easier to interpret. You also have a 60hz dip. What is your crossover?
post #2035 of 5032 Old 06-23-2014, 11:14 PM
bear123's Avatar
Quoted: 1799 Post(s)
Liked: 2661
Most graphs I am seeing are scaled horribly which makes it impossible to see a true representation for the FR.
X-axis 45-105 dB (5-125 makes it appear way to smooth, as does 1/6th smoothing)
Y-axis 5/10-200 (oddball scaling here drastically affects how smooth the graph looks as well)
bear123 is offline
post #2036 of 5032 Old 06-23-2014, 11:14 PM
jbrown15's Avatar
Liked: 1995
rhed, I know I don't give two cr@ps but some would frown on posting graphs with 1/6th smoothing. I know the graphs that I've posted were 1/12th smoothing, so I don't see it as a big deal..lol
But I know guys were making comments about mine being 1/12th ..... but I got a good laugh out of the posts.
jbrown15 is offline
post #2037 of 5032 Old 06-23-2014, 11:25 PM
bear123's Avatar
Liked: 2661
Well, if people are taking the time to try to measure their room and improve response, improper scaling and excess smoothing simply hides things and does not make them better. Or, does not help one to visualize their FR in an accurate way in order to see if improvement is needed or not. Take this identical sweep, first with meaningless scaling that hides everything, then scaled properly:
Name:	1-6th bad scaling awmergerd look how smooth.jpg
ID:	133281   Click image for larger version
Name:	proper scaling, how it really looks.jpg
bear123 is offline
post #2038 of 5032 Old 06-23-2014, 11:36 PM
jbrown15's Avatar
Liked: 1995
If the second graph was his it really isn't that bad, find a way to fix the null at 38hz and pull down the peak at 60-62hz and that's a pretty respectable graph from 70hz and down.
jbrown15 is offline
post #2039 of 5032 Old 06-23-2014, 11:40 PM
bear123's Avatar
Liked: 2661
Those two graphs are both mine, and are the exact same sweep before eq. I got things a lot smoother prior to eq, just had to knock the big peak down.
bear123 is offline
post #2040 of 5032 Old 06-23-2014, 11:41 PM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
You know what? It's ok guys. Don't need to turn this into a debate thing.. It's all good. It's just a hobby for me and I'm happy with what I have. Dom.. I'll remove my graph post. Sorry guys if this graph offends anyone.. Lol..
rhed is offline
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
