Your Home Theater ULF Score - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 743Likes
post #2071 of 5030 Old 06-25-2014, 12:18 AM
tvuong's Avatar
Quoted: 1768 Post(s)
Liked: 1060
^^ +1. Keep that amp. It is a very good amp. I had the very first Sherbourn 5x200W (5 separate mono blocks in one chassis) over a decade ago and liked how it sounded. I wish I didn't sell it. I am still pissed about not getting that 7-350 amp a while back on sale for $950 as I didnot need it. I still do not need an amp but it was so cheap. I have been running my HTPC for about 10yrs now. It is sooooo cheap to build a nice one now.
tvuong is online now
post #2072 of 5030 Old 06-25-2014, 01:51 PM - Thread Starter
dominguez1's Avatar
Quoted: 1108 Post(s)
Liked: 955
Still traveling, so no ULF calc update yet. Likely in the next few days.
Regarding the scaling...agree with the X axis and Y axis precision that have been mentioned. Definitely 5db for y axis.
Now for smoothing...IMO, it depends what you're trying to do.
I typically use no smoothing to ensure that I'm not hiding any peaks or nulls. Once I've dialed the response in so that I'm confident that those don't exist, I'll eq at the 1/6 scale. Once that is to my liking, I'll then flip to unsmoothed to ensure there are still no peaks or nulls I created in the process. Assuming I'm good there, I'll post my final curve at 1/6 smoothing.
Ultimately (from what I've gathered on this forum),1/6 smoothing is what we hear. If that's the case, then I want my final frequency response graph to show that.
However, if you're posting your response because you want assistance with your FR, or are comparing subwoofers, further precision is beneficial to really help reveal any potential issues. The minimum however for any posting of a response would be 1/6 scaling.
IMO, YMMV
dominguez1 is offline
post #2073 of 5030 Old 06-26-2014, 12:22 AM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
IMO, YMMV
Thanks Dom.. Anyway, I was kind of playing around with moving my subs around this pass weekend and today again. Been board lately so I figured try see what kind of other response I can get just by moving them around.lol..Not the greatest graph now I got nasty dip at 100. Which is my Xover point. But not final yet because my speakers should be done soon and shipped out. That's when I will do my final calibrations. Anyway this is what I got just by moving subs around and auto EQ and some manual cuts with the Antimode dual core. One is unsmoothed and the other 1/6 smoothed. Don't know if this is still enough to boost me in the 5hz cat. But this is fun though. Something to work for lol..
Attachment 136185
Attachment 136193
rhed is offline
post #2074 of 5030 Old 06-26-2014, 03:37 AM
bear123's Avatar
Quoted: 1796 Post(s)
Liked: 2651
Attachment 136185
Attachment 136193
Your scale of -30 db to 170 dB (200 dB), is giving a very inaccurate view of your frequency response. Try a range of 45-105 to get a more standardized appearing sweep with the proper 5 dB increment.
bear123 is offline
post #2075 of 5030 Old 06-26-2014, 08:08 AM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 962
Hypothetically speaking......
If I stacked another four on top of these ie four UXL's to total of eight......would I be able to enter "The Right On Group".......ie. ULF score of 5. I can hit 115 db's down to 8 Hz currently......maybe I can hit 118-120 db's? Maybe?
its phillip likes this.
doublewing11 is offline
post #2076 of 5030 Old 06-26-2014, 08:42 AM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
Ok.. Thanks.. I'll try that..
rhed is offline
post #2077 of 5030 Old 06-26-2014, 08:55 AM
MKtheater's Avatar
Quoted: 1717 Post(s)
Liked: 1249
Here is my response without LT boost
MKtheater is offline
post #2078 of 5030 Old 06-26-2014, 09:00 AM
popalock's Avatar
Quoted: 1271 Post(s)
Liked: 1774
You seem to be down about 40db @ 2Hz vs @ 18Hz. You are right, that is massive null at 100Hz.
Go ahead and fix your scale like bear suggested so we can really see what is going on.
With 4 S2's you should be able to smooth that 100Hz null with proper placement. What are you crossing your mains at?
popalock is offline
post #2079 of 5030 Old 06-26-2014, 09:04 AM
MKtheater's Avatar
Liked: 1249
That was the LFE channel only
post #2080 of 5030 Old 06-26-2014, 09:49 AM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
Ok thanks.. I'll do it and post it today after work. Btw, how do I adjust the scale? Sorry, still don't know that much on the REW interface. Thanks again guys..
rhed is offline
post #2081 of 5030 Old 06-26-2014, 10:43 AM
bear123's Avatar
Liked: 2651
With REW open and a saved sweep open(or a new one up), click on the box in the upper right hand area of the screen that says "limits". Set top to 105 and bottom to 45. Set left to your lowest extension i.e. 5/10, and right to 200.
If you do max output sweeps, adjust BOTH top and bottom levels the same amount to keep the sweeps on the graph, such as 65-125 rather than 45-105. Any 60 dB increment. No smoothing allows you to see all nulls that smoothing sometimes hides, allowing you to make minor tweaks to phase, distance, placement, and even individual sub gain. This can often dramatically lessen a lot of nulls before eq is applied.
bear123 is offline
post #2082 of 5030 Old 07-06-2014, 02:49 PM - Thread Starter
dominguez1's Avatar
Liked: 955
Attachment 136185
Attachment 136193
Rhed,
Too difficult to tell from the chart because of the scale. 5hz is really a question of signal chain if you have enough fire power. It looks like you're down 10db at 5hz from 10hz...
post #2083 of 5030 Old 07-06-2014, 02:51 PM - Thread Starter
dominguez1's Avatar
Liked: 955
Jbrown15,
Here is your updated ULF score from bassthathz's sim (post 2026) of your system. The 10hz looks more realistic now as its below its sealed counterpart.
Name:	jbrown15 ulf score v2.png
post #2084 of 5030 Old 07-06-2014, 02:59 PM - Thread Starter
dominguez1's Avatar
Liked: 955
Version 14.4 of the ULF Calculator now available (Post 1)
  • Added Mal-X21 Estimate
  • Modified PSA XV15SE estimated output
  • Added Infinity 1260w estimate
Below is the latest member score update, with changes highlighted in yellow.
Keep the scores coming!
-Dom
Name:	Member Scores 7-6-14 new.jpg
post #2085 of 5030 Old 07-06-2014, 04:01 PM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
Rhed,
Thanks Dom.. I'll retake measurements when my new speakers arrive. Right now everything's disconnected as far as subs and speakers goes. I'm planning on moving my subs around the room for a better raw response with the new speakers.
rhed is offline
post #2086 of 5030 Old 07-06-2014, 09:19 PM
Quoted: 229 Post(s)
Liked: 962
Jbrown15,
Heck with this......I'm stacking! Can't let Jbrown15 score higher than me!
Doublewing........double stack.......makes sense.
post #2087 of 5030 Old 07-06-2014, 10:12 PM - Thread Starter
dominguez1's Avatar
Liked: 955
New member score format:
Separated DIY and Commercial HT systems. (You are DIY if you have any sub that cannot or could not be bought commercially.)
Name:	Member Scores 7-7-14.jpg
laugsbach likes this.
post #2088 of 5030 Old 07-06-2014, 10:52 PM
BassThatHz's Avatar
Quoted: 2314 Post(s)
Liked: 2064
dom, I've recalculated my score based on the Mal 21's you added in v14.4, here it is:
Can you update my 12.5hz, 16hz, and 20hz scores in the next spreadsheet update?
I'm looking at beefing up some of my subs... but the subs I'm updating roll off like a rock below 30hz so my ULF score won't really change any.
Name:	ULF Score.png
BassThatHz is offline
post #2089 of 5030 Old 07-07-2014, 09:34 AM
MKtheater's Avatar
Liked: 1249
So I will have a new score soon, I will update the progress. I wonder if this will equate to a better experience?
post #2090 of 5030 Old 07-07-2014, 09:59 AM
WhskyTangoFoxtrt's Avatar
Quoted: 78 Post(s)
Liked: 58
It will kick it up another three or four quads per channel. Make it more referencier.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
post #2091 of 5030 Old 07-07-2014, 10:45 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Strong thread is strong. Love the excessive detail in the beginning posts.
Mfusick is offline
post #2092 of 5030 Old 07-07-2014, 05:30 PM
ahmedreda's Avatar
Quoted: 327 Post(s)
Liked: 266
Josh Ricci tested the SVS SB-13 for audioholics. http://www.audioholics.com/subwoofer...r/measurements
Interesting it didn't get a passing result for 25Hz and below because of THD.
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is online now
post #2093 of 5030 Old 07-07-2014, 05:35 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
Wow, suddenly the PSA XS15 looks like its excellent value having very similar numbers and less then have the price!
jbrown15 is offline
post #2094 of 5030 Old 07-07-2014, 06:46 PM - Thread Starter
dominguez1's Avatar
Liked: 955
I'm guessing that it will, from a tactile feedback standpoint. Same SPL, but more tactile feedback.
You're on a riser now though, so make sure you do some critical listening on the riser so you can compare setups.
You audio memory is probably accustomed to the concrete floor setup you had for months...
post #2095 of 5030 Old 07-07-2014, 06:54 PM - Thread Starter
dominguez1's Avatar
Liked: 955
Yes it did:
Here is the estimate we had for it prior to Josh's testing:
Not bad! Within 1.5db!
Name:	SB13 Ultra Estimated.png
post #2096 of 5030 Old 07-07-2014, 07:00 PM
ahmedreda's Avatar
Quoted: 327 Post(s)
Liked: 266
Yes it did:
My bad.. I misinterpreted his results.. Your estimates were pretty darn close though..
My home theater
Display: JVC RS400
post #2097 of 5030 Old 07-07-2014, 07:13 PM
tvuong's Avatar
Liked: 1060
That was pretty darn good great job, Dom. Not that I didn't trust your estimate but now you have it backed up with Josh's result.
post #2098 of 5030 Old 07-07-2014, 07:20 PM - Thread Starter
dominguez1's Avatar
Liked: 955
Well, to be fair, I did miss the 10hz output, but still not bad.
post #2099 of 5030 Old 07-07-2014, 09:08 PM
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6444
the sb13 had a passing output down to 10hz. All the green means is amp limited vs orange thd limited.
basshead81 is offline
post #2100 of 5030 Old 07-30-2014, 08:18 AM
MKtheater's Avatar
Liked: 1249
OK, so I ported my IB to see what would happen. I have yet run a movie on it as it was too late last night but after the sims and then running in room responses my response from sealed to ported has not really changed except I have a taller and wider peak from 6-9hz. That's what happens when you tune very low. My score is the following:
5hz: 47
7hz: 23
10hz: 47
12.5 hz: 63
16hz: 63
I am building my enclosures for my surrounds tomorrow and I am either adding 4 f my drivers or two FTW-21's tuned to 7hz. My front wall is tuned to 7hz as well.
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
