Your Home Theater ULF Score - Page 73 - AVS Forum | Home Theater Discussions And Reviews
 545Likes
post #2161 of 4803 Old 08-11-2014, 09:31 PM
MKtheater's Avatar
Quoted: 1657 Post(s)
Liked: 1172
Sweeps after eq
I will now seal up the wall again and run the same sweeps and see which compresses sooner.
MKtheater is offline
post #2162 of 4803 Old 08-11-2014, 10:17 PM
MKtheater's Avatar
Liked: 1172
REW now has the nanoavr as an EQ option and it EQ's even better now, here is my center channel
post #2163 of 4803 Old 08-12-2014, 01:16 AM
popalock's Avatar
Quoted: 1236 Post(s)
Liked: 1727
Originally Posted by dominguez1 View Post
I also think that ported nearfield will take the tactile feedback up another notch as well!
Agreed...
It will be 4 inches away!
Now we are talking. Following ya know.
NFFTMFW!
popalock is offline
post #2164 of 4803 Old 08-12-2014, 05:25 AM - Thread Starter
dominguez1's Avatar
Quoted: 982 Post(s)
Liked: 752
Here was my raw sealed sweep
here is the ported
I don't get this as they look similar.
When you run sweeps on the ported setup, are you getting air flow through the port? If so, what direction? Into the IB area or into your room?
dominguez1 is offline
post #2165 of 4803 Old 08-12-2014, 05:27 AM - Thread Starter
dominguez1's Avatar
Quoted: 982 Post(s)
Liked: 752
Awesome response!!!
post #2166 of 4803 Old 08-12-2014, 05:30 AM - Thread Starter
dominguez1's Avatar
Quoted: 982 Post(s)
Liked: 752
Originally Posted by popalock View Post
NFFTMFW!
FY!!!
post #2167 of 4803 Old 08-12-2014, 07:13 AM
MKtheater's Avatar
Liked: 1172
I don't know, I will check later. Maybe my IB was never truly sealed and was a 7hz ported system with an inductance peak? Maybe it was leaking around the speakers? Now I want to seal up the wall so good just to see. I basically have two 12 inch round holes in my wall and the response did not change from no holes or 24 inch long ports, why so similar? Where are my design experts?
post #2168 of 4803 Old 08-12-2014, 07:15 AM
MKtheater's Avatar
Liked: 1172
BTW, the raw responses were done at 20 dB below reference so if it was flat it would have been at 95 dBs and the speakers at 85 dBs.
I let REW EQ my system, I picked nanoavr as the EQ and wanted to EQ 10-120hz at 105 dBs from the raw response and the sweeps graph is the response it came up with. I had to turn down the sub channel 10 dBs still as it was at 20 dBs below reference.
post #2169 of 4803 Old 08-12-2014, 09:36 AM
MKtheater's Avatar
Liked: 1172
Here are the sims of the ultimax 18 sealed and ported in the Chase VS 18.1 box tuned to 18hz.
post #2170 of 4803 Old 08-12-2014, 10:38 AM
derrickdj1's Avatar
Quoted: 909 Post(s)
Liked: 616
I was looking for info of the Dayton Ultimax in the Chase SS 18.2 and VS 18.1 box. What are the yellow and orange graphs. Is one of the sealed boxes the small 18.1 box They are hard to see due to the size. Thanks for the graph.
Last edited by derrickdj1; 08-12-2014 at 10:42 AM. Reason: Statement clarification
derrickdj1 is offline
post #2171 of 4803 Old 08-12-2014, 11:44 AM
MKtheater's Avatar
Liked: 1172
Basically the ultimax will look similar to the SI except the SI will have 2-3 dBs more output above 40hz. The ultimax in the ported box will have around 12 dBs more output at 16 and 20hz. The other sim was comparing to a sealed SI 18.
post #2172 of 4803 Old 08-12-2014, 12:29 PM
MKtheater's Avatar
Liked: 1172
Ok I ran a couple demos and even though the response is the same running it like this has more tactile feel during certain scenes. Well, much more than with the 24 inch long ports. Still testing though so nothing definitive.
post #2173 of 4803 Old 08-12-2014, 03:40 PM - Thread Starter
dominguez1's Avatar
Quoted: 982 Post(s)
Liked: 752
Thanks for the sims of the ultimax MK!
I'll update the estimated chart in the next round. Compared to the SI, it looks to be the same at 20hz, and then 1db up below that.
Derrick, I'll update your ULF Card and post back in the next day or so. Assuming you have the appropriate power to produce that output, it should be a pretty significant update from a ULF perspective.
post #2174 of 4803 Old 08-12-2014, 04:03 PM
derrickdj1's Avatar
Quoted: 909 Post(s)
Liked: 616
Thanks gentelmen. I wish it was a way of knowing the VS 1 ultimax mod with the 16 Hz tune box that I use. This should give me a little more output under 16 Hz. It was a fun project and I have plenty of power. Each diver is on a separate I Nuke amp channel. Two I Nuke 6000's and two I Nuke 3000's.
post #2175 of 4803 Old 08-12-2014, 04:14 PM
MKtheater's Avatar
Liked: 1172
Here it is compared to the sealed SI 18
post #2176 of 4803 Old 08-12-2014, 06:26 PM
derrickdj1's Avatar
Quoted: 909 Post(s)
Liked: 616
Looks like this should be an upgrade in the 10-20 Hz range from the graphs.
post #2177 of 4803 Old 08-12-2014, 06:54 PM
MKtheater's Avatar
Liked: 1172
Maybe 12 hz in room is possible, the sim is good to 14hz where the driver goes past x-max and way over under that.
post #2178 of 4803 Old 08-12-2014, 07:15 PM
derrickdj1's Avatar
Quoted: 909 Post(s)
Liked: 616
Is that the factory Xmax of 22? The Xmax on the Dayton subs have been on the conservative side. Either way it was great tonight watching demo clips. Definitely pushing more are in the room than before. I really appreciate your help getting this info.
post #2179 of 4803 Old 08-12-2014, 08:09 PM - Thread Starter
dominguez1's Avatar
Quoted: 982 Post(s)
Liked: 752
Data-bass puts the vs.1 at a 19hz tune. Did you do something to the box to tune it lower?
post #2180 of 4803 Old 08-12-2014, 10:56 PM
derrickdj1's Avatar
Quoted: 909 Post(s)
Liked: 616
When I got the VS 18.1 Craig had been working on the new Chane subs. One of the things he did was close off 1/3 of the slot vent, this effectively lower the tune to 16 Hz. I have the vent 1/3 plug and no HPF required. So, the VS 18.1 goes a little lower. In the next day or two I will do a FR of the MLP.
post #2181 of 4803 Old 08-13-2014, 06:37 AM
MKtheater's Avatar
Liked: 1172
Yes it is listed as a 22 mm x-max and the winisd file has the same. We can't change anything until proven more or less by Ricci. If it has more you are probably looking at 1-2 dBs more.
post #2182 of 4803 Old 08-13-2014, 09:19 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1994
I seem to recall a post by DaytonaAudioRory saying that it was rated at 22mm xmax but that it was really 25mm xmax. I can't see it having anymore then that if Rory says its 25mm.
jbrown15 is offline
post #2183 of 4803 Old 08-13-2014, 11:54 AM
MKtheater's Avatar
Liked: 1172
Well my drivers model about 3 dBs more than the SI at 30mm and made for IB. So a driver with 25mm will be about 1.5 dBs more.
My 4 SI 18's arrive today. I get back on Friday and will play around this weekend. The output from 4 ported 18's very close should be close to 8 ported 18's from 15 feet away.
post #2184 of 4803 Old 08-13-2014, 01:06 PM
jbrown15's Avatar
Liked: 1994
So how much of a difference would there be between the UM18-22 with 25mm xmax compared to the UXL-18 with 34mm xmax?
jbrown15 is offline
post #2185 of 4803 Old 08-13-2014, 01:25 PM
popalock's Avatar
Liked: 1727
I got this one guys.
The difference will be 9mm of xmax.
Let me know if you have any other questions.
popalock is offline
post #2186 of 4803 Old 08-13-2014, 01:49 PM
jbrown15's Avatar
Liked: 1994
Haha I totally walked into that one Pop!....lol
Of course I meant dB wise.
So how bad is the heat over in Qatar right now?
jbrown15 is offline
post #2187 of 4803 Old 08-13-2014, 03:18 PM
popalock's Avatar
Liked: 1727
Got back from a dinner around 10pm tonight and it was a balmy 106 degrees. Not sure what it is at the moment as it's 1:16am.
That said, I'm about to crash in my 66 degree bedroom.
popalock is offline
post #2188 of 4803 Old 08-13-2014, 03:32 PM - Thread Starter
dominguez1's Avatar
Quoted: 982 Post(s)
Liked: 752
Here is the estimate for the Dayton UM 18-22 and also derrickdj1's Chase VS with UM 18-22:
Here's derrickdj1's old ULF Card with the Chase drivers:
And his new ULF Card:
Nice upgrade! Massive at 16hz; 5.6 SI to 12.4!
Big question...can you tell a difference in ULF?
Name:	UM 18-22 and Chase VS Estimated.png
ID:	210665   Click image for larger version
Name:	derrickdj1 Chase ULF Score.png
ID:	210673   Click image for larger version
Name:	derrickdj1 UM ULF Score.png
post #2189 of 4803 Old 08-13-2014, 04:05 PM - Thread Starter
dominguez1's Avatar
Quoted: 982 Post(s)
Liked: 752
Nice! Tradeoffs of course, but it's nice to have a tuning option. That's one advantage to slot vents...you can just do a partial plug of a vent and wedge it in there, as opposed to a port. You guys with "Marty Subs" or slotted vents should give it a try and see how you like a lower tune...
^^^This. We'll keep it as mfg specs until tested otherwise.
post #2190 of 4803 Old 08-13-2014, 04:08 PM - Thread Starter
dominguez1's Avatar
Quoted: 982 Post(s)
Liked: 752
Looking forward to see if that ups your ULF experience even more!
Did you ever figure out if you have a sealed or ported IB?
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
