Your Home Theater ULF Score - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 522Likes
Old 09-04-2014, 08:26 AM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
I already know they have the chops for that 7hz Bass I love you note. The roll off will be based on box design as well. The smaller the box the more roll off but more power can bring that up unless the driver does not have enough motor to keep distortion down like my IB3-18's. I built the wall too small and to bring up the low end causes too much THD. A proper box will net you the same spl but less THD. This is why I am changing. I am tempted to buy Chops 4 24's but 16 18's are showing me a better low end with my wall. Wiring 4 drivers is much easier though!
MKtheater is online now
Old 09-04-2014, 09:46 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5280 Post(s)
Liked: 4165
Originally Posted by popalock View Post
Guess we know who to turn too now for help.
I've always had a few questions about the Matterhorn. Why the need for 40 individual amps vs. getting a few powerhouse amps drive multiple subs to save space and money? What kind of DSP work would go into the design to get it dialed in? I mean 40 drivers, each vertical row has a different distance from the horn mouth, so it seems like it would be a very tedious task to dial everything in properly. Maybe I'm just over thinking it and with a little time and patience anything can be done. It would be nice if @Ivan Beaver chimed in to provide just a glimpse of the secret sauce in the Matterhorn design.
I've seen some very great input from @Ricci about using multiple drivers in a tapped horn, but can't find the post...
Hey. I didn't mean to come off like a 'know-it-all' but I don't see what about it is so special that it could not be replicated with another horn sub design but upsized to ridiculousity. Take the Ohorn or Ghorn. Build forty of those and stack em together or even better line up half in front of one another and then build a horn extension between them to create a new larger mouth to couple them acoustically and extend their natural low corner. Bam. What else is there? Tack on the Danley name maybe for better?
popalock likes this.
Scott Simonian is online now
Old 09-04-2014, 03:40 PM
MKtheater's Avatar
Liked: 1116
Fatshaft,
what mic are you using?
Old 09-04-2014, 04:30 PM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
Fatshaft,
Calibrated Dayton UMM-6 from Cross-Spectrum
http://cross-spectrum.com/measurement/calibrated_umm6.html
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
Old 09-04-2014, 04:49 PM
MKtheater's Avatar
Liked: 1116
I have that one too!
Old 09-04-2014, 04:54 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5204
me three!
basshead81 is offline
Old 09-04-2014, 05:55 PM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
Originally Posted by basshead81 View Post
me three!
basshead81 likes this.
My Build Thread
Equipment Speakers:
Fatshaft is offline
Old 09-04-2014, 06:00 PM
MKtheater's Avatar
Liked: 1116
When I simulate my ports and wall it says I should have 138 dBs at 18hz yet it had no gain over sealed with less low end, why? When I first built them it should have been tuned to 10.2hz with 126 dBs at 10hz ground plane yet it was a dud, why? The sims show a huge advantage with ports for my room gaining 5-20hz with quadruple to double the output yet nothing. I wonder what was going on? The only thing that has worked so far are my sealed near field subs, huge gains in just feel. However, a sim shows tuning this to 10hz gives me 12 SI more at 10hz and even at 5hz so it seems like a no brainer, I don't trust it anymore. Maybe the IB drivers just don't have enough motor for ported or small sealed boxes and nothing will help it other than IB? Maybe the SI's with the bigger motor will?
Old 09-04-2014, 07:56 PM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1546
10hz is like 110ft long, perhaps the wall is completely acoustically-transparent at those frequencies.
Air leakage undermining the expected port pressure addition.
Maybe you've maxed out your mic.
BassThatHz is offline
Old 09-04-2014, 07:59 PM
Bass Enabler
Liked: 4165
"Maybe the IB drivers just don't have enough motor for ported or small sealed boxes and nothing will help it other than IB?"
Old 09-06-2014, 10:12 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
BTW,
I still can't open the new ULF calculator.
It must be something on your end...no one else seems to be having problems. Can you try a different program?
dominguez1 is online now
Old 09-06-2014, 10:19 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Maybe your setup was behaving like you were in the ported sub as opposed to outside of it. Who knows how your response is supposed to behave INSIDE a ported sub!!!
Old 09-06-2014, 11:26 AM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
Dayton sell a mic with a kit that has software for around $300 http://www.parts-express.com/dayton-...ystem--390-792 Can this mic be used with REW? I am thinking about getingt the kit but, there is not much help on this forum for the software.
derrickdj1 is online now
Old 09-07-2014, 03:36 PM
BassThatHz's Avatar
Liked: 1546
Try setting the security setting to low, and download all the SP updates for Office.
You could try Open Office if Microsoft is giving you issues.
Old 09-07-2014, 06:56 PM
MKtheater's Avatar
Liked: 1116
I fixed it. Still getting new setup up and running, stay tuned.
Old 09-08-2014, 06:20 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
jbrown15,
I can't post an attachment in a PM, so I'm just posting it here.
I checked out the sim...looks almost identical as your other subs. Less than 1db difference overall. I just added another sub like your other subs so you have a total of 5.
Here's what I get if you build that 5th sub and place it nearfield:
What amps are you running for these?
Name:	jbrown15 ulf score 5 subs.png
Old 09-08-2014, 08:02 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
I'll run a single inuke 3000 to power the 5th sub.
jbrown15 is offline
Old 09-08-2014, 08:09 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
What about the other subs?
Old 09-08-2014, 08:12 PM
jbrown15's Avatar
Liked: 1993
I was powering then with two iNuke 6000's but I sold one and so I still have one and a Peavey IPR2 7500.
jbrown15 is offline
Old 09-08-2014, 10:20 PM
MKtheater's Avatar
Liked: 1116
Ok, I just calibrated a new elite AVR to see how it does. It sounds good except the levels are so over cooked it is ridiculous. Every AVR I have ever tried calibrates reference about 10 dBs too hot. This is with the mains. I want to measure it's new MCACC EQ and then add my Nano AVR. The amps in this are good for my 4 ohm speakers. I tried to measure and one lap top does not recognize my UMIK, another does not have HDMI, and the one I usually use was dead and I can't find the power cord. I actually pulled out my old RS meter but I think it is broken as it never shows steady responses like it used to. Anyways, based on it I was extending down to 6hz for my two near field subs where it started to drop but I want to confirm this.
Old 09-08-2014, 10:21 PM
MKtheater's Avatar
Liked: 1116
Hey Luke,
How do you like that peavy? Did you ever try a Sanway to compare?
Old 09-09-2014, 08:56 PM
MKtheater's Avatar
Liked: 1116
This is why you don't trust auto EQ's, here is my center channel with subs(100 hz XO) with MCAAC.
Old 09-09-2014, 09:03 PM
MKtheater's Avatar
Liked: 1116
BTW, the levels are off by 25 dBs for true reference. So people should check their AVR's for how loud 0 dB's really is before letting it rip. My reference is -25 dBs! This is an Elite SC-81. Powerful amps in it though.
Old 09-09-2014, 09:46 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
I was just trying out this calculator and noticed the JTR OS was listed. Is this for the OS LF or OS LFU? I have the LFU which is tuned to 22hz, I think the LF was tuned to 25hz. Anyway here is what I came up with below. Obvioulsy ULF is a relative term...just eeked my way on to the list though.
Room Size 3500 Number of Subs 3 Member: lbrown105 Min Room Gain 6 Type Com 10hz 12.5hz 16hz 20hz SI Equivalent - - - 18.6 ULF Score NA NA NA 188 Groundplane SPL NA NA NA 135.6 GP Stars - - - 5.0 Stars (2 and up) (1.0) (1.0) (1.0) 5.0 Stars (1.5 and below) - - - - Category Stars 1.0 1.0 1.0 5.0 Stars 1.0 1.0 1.0 5.0 Reference Estimate Above Reference Subwoofage JTR OS LFU Power Tactile Feedback FX Total Cost $ 8,997 Cost per SI $ - $ - $ - $ 484 Cost per Star $ 8,997 $ 8,997 $ 8,997 $ 1,799
Last edited by lbrown105; 09-09-2014 at 10:19 PM. Reason: I cannot get the file to load. tried pdf, excel, word. no luck.
lbrown105 is offline
Old 09-09-2014, 11:01 PM
MKtheater's Avatar
Liked: 1116
Here is the response from my nearfield subs, sealed.
Scott Simonian likes this.
Old 09-10-2014, 06:49 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Nice! Is this with no eq?
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
Old 09-10-2014, 07:33 AM
MKtheater's Avatar
Liked: 1116
EQ'd 20-60hz.
Old 09-10-2014, 07:55 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Impressive mk! Where did you take the mic reading (how many feet or inches away)?
Old 09-10-2014, 07:58 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
This is pretty difficult to read over mobile...will get back to this when I'm home.
I believe this was the lower tuned version. Do you happen to have a sim for this? I could estimate the other ulf frequencies if so to give you a more rounded score.
Old 09-10-2014, 08:19 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
A bit offtopic, but I think MCACC only EQs 9 channels, each covering a whole octave, i.e. the standard ISO channels at 63, 125, 250, 500, 1k, 2k, 4k, 8k and 16k Hz. It won't fine-tune as Audyssey MultEQ XT32 does but the whole graph looks more or less level. It also looks like MCACC performs extensive time series analysis at each of the 9 bands though. There seems to have a dip above 1kHz in your graph -- is the X-Curve option engaged?
neutro is offline
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
