Your Home Theater ULF Score - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 537Likes
post #2521 of 4790 Old 10-03-2014, 08:54 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5392 Post(s)
Liked: 4328
Originally Posted by neutro View Post
Looks like all we can do now is attach files to posts, which show up as thumbnails at the end of the post. To attach a file you drag'n'drop them in the "DRAG FILES HERE TO ATTACH!" box under the text editor. There doesn't seem to be a way to upload files and make them appear in-line or even to resize images for some reason
Attach the file then select the url of that attached file and post it with (leave out quotes) ["img][/img"]. Simple but not as good as it used to be.
Scott Simonian is online now
post #2522 of 4790 Old 10-03-2014, 10:25 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Will have to try that. So you end up with attached files with thumbnails at the bottom, *and* full-size inline pics?
Anyway definitely not as good as it once was.
neutro is offline
post #2523 of 4790 Old 10-03-2014, 10:31 AM
Bass Enabler
Liked: 4328
Here is a thread made by my boy, LTD02 with pictures of the process. Do it once and it will seem extremely simple afterwards. Still not as simple as before but it's what works now and leaves a full sized picture in the post.
How to put an image in a post!
post #2524 of 4790 Old 10-03-2014, 10:59 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Awesome Scott, thanks for the tip.
Didn't know LTD02 was your boy!
I guess I should reserve usernames for my kids right now
neutro is offline
post #2525 of 4790 Old 10-03-2014, 11:29 AM
Bass Enabler
Liked: 4328
Hahaha!
There is a reason we are so like minded.
post #2526 of 4790 Old 10-03-2014, 01:27 PM
BassThatHz's Avatar
Quoted: 2071 Post(s)
Liked: 1637
LOL!
Scott Simonian likes this.
BassThatHz is offline
post #2527 of 4790 Old 10-03-2014, 02:46 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 441
Originally Posted by BassThatHz View Post
LOL!
More like
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #2528 of 4790 Old 10-03-2014, 02:58 PM
carp's Avatar
Quoted: 2597 Post(s)
Liked: 1860
Hey Dom,
Do you think my score would change with my JTR 215's added to my 8 SI's? The 215's are rated to 18hz, when I measured them I was getting output to 12 hz!!! Doesn't matter though because I use a HPF on my inuke at 20hz.
They are supposed to have the same output as a ported Captivator, so it's like I've added 2 ported Caps to my 8 SI's. I know my score won't change at 10hz and 15 hz but man subjectively I have significantly more headroom especially since I only play the subs from 30hz and down now.
carp is offline
post #2529 of 4790 Old 10-04-2014, 04:54 PM - Thread Starter
dominguez1's Avatar
Quoted: 966 Post(s)
Liked: 706
Originally Posted by Lecter83 View Post
http://www.audioholics.com/subwoofer...svs-sb-pb-2000
PB-2000 CEA 2010 Results (2 meter RMS)
20Hz 103.8 dB
25Hz 107.6 dB
31.5Hz 109.6 dB
40Hz 110.1 dB
50Hz 110.5 dB
63Hz 111.5 dB
SB-2000 CEA 2010 Results (2 meter RMS)
20Hz 92.1 dB
25Hz 97.1 dB
31.5Hz 102.8 dB
40Hz 108.3 dB
50Hz 108.9 dB
63Hz 109.2 dB
Nice! I didn't realize that it had been reviewed. I'm surprised Josh didn't review it...perhaps too busy at the time.
Originally Posted by basshead81 View Post
Yep very little difference between the PB12 and PB2000 in the 16-20hz range...maybe .5-.6db.
Also I think the XV15se numbers need a slight adjustment. Basically 2.4-2.5db less in the 16 & 20hz vs the XV30se. 99db 16hz & 107db 20hz.
Yup, will adjust the estimate to be .5-.6db difference. Didn't realize there wasn't much of a difference in the ULF range between the former PB12NSD. Good to know.
Regarding the XV15SE estimates, what I have down is directly from Tom V. See post below:
PSA XV15SE - Tom V.
dominguez1 is online now
post #2530 of 4790 Old 10-04-2014, 05:02 PM
lefthandluke's Avatar
Quoted: 137 Post(s)
Liked: 266
well...i had no idea
lefthandluke is offline
post #2531 of 4790 Old 10-05-2014, 06:07 AM - Thread Starter
dominguez1's Avatar
Quoted: 966 Post(s)
Liked: 706
Hey Dom,
So I was experimenting running my subs off a single Sanway 14K. I used to run the 8 IB3-18's of the 14K in bridged mode which I can not due anymore. So I hooked up the 4 drivers near field on one channel and the 8 front drivers on the other. The 4 drivers present a 4 ohm load and the front drivers a 2 ohm load. The funny thing is the 8 drivers in front represent a 6 dBs gain from the 4 in back but using the same gain levels on the amps(-10dbs, halfway), the levels were exactly the same. So my 4 subs in the back are the same sensitivity as my front 8. This tells me I lose about 6 dBs from distance. I have always thought I lost 12 dBs so this is a good thing. I will experiment more to figure out the port tune from the front.
Nice.
So are you still getting a separate amp for the nearfield or will you use the 14K? Let me know about the port tune...when you figure it out, post your sim of it, and I can update your ULF scores.
Originally Posted by carp View Post
Hey Dom,
Wait...these 215's have are supposed to be equal to a ported Cap each??? Wow...do you have a sim or any other info to read more about it?
If that's the case, I would definitely say yes, it would have an impact on your ULF score.
post #2532 of 4790 Old 10-05-2014, 06:10 AM
MKtheater's Avatar
Quoted: 1631 Post(s)
Liked: 1162
Dom,
My response shows a huge peak at 6-7hz from the front wall and not from the back subs so I figure it has to be from the tune.
MKtheater is online now
post #2533 of 4790 Old 10-05-2014, 06:43 AM - Thread Starter
dominguez1's Avatar
Quoted: 966 Post(s)
Liked: 706
Ok;
In my basement HT I have IB line array 4 x 15" AE15 drivers, plus 2 SI sealed subs, 18" and 15", inputting them into the sheet gave the below.
(I could not find a 15" SI, so "cheated"and said I had 2 18")
Ok;
I re-did mine choosing a similar 15" sealed cab, numbers came down slightly like expected
Hey mtb! I'm updating the calculator, and just realized that you posted the same ULF cards here...
For the 15in SI, I'm just adding another AE IB15. Let me know if that works. Puts you at 522 from 16hz down, and 587 at 20hz.
post #2534 of 4790 Old 10-05-2014, 08:21 AM
carp's Avatar
Liked: 1860
Originally Posted by dominguez1 View Post
Nice.
No, I don't have any other info. Here is a video I took that shows the tornado created similar to a ported Cap when pushed really hard:
Haha, you can see the bleach marks on the carpet where I attempted to clean during a GTG after spilling my drink. In my drunken state I chose poorly on the type of cleaner.
These things are 6 feet tall, 2 inches deep and 17 inches wide 210 pounds.
Jeff states that they are just like a ported Cap per speaker. However, both Archaea and I think that the output is more similar to a ported passive cap powered by a behringer ep 4000. We say this because that was the setup that both he and I had for a long time. Later he upgraded to a Crown 5000 to power the caps. I have heard that setup in my room and I don't thinkg the 215's quite hang with that - the ep4000 comparison seems more likely. Either way the output from a full range speaker is nuts and a lot of fun.
carp is offline
post #2535 of 4790 Old 10-07-2014, 07:13 AM
MKtheater's Avatar
Liked: 1162
Here are my front and back sub sims.
Name:	wall vs back.png
post #2536 of 4790 Old 10-08-2014, 04:06 PM
Archaea's Avatar
Quoted: 2948 Post(s)
Liked: 2555
anyone want to take a stab and determining how that Royal Device setup would score?
http://makezine.com/2008/07/15/world...est-subwoofer/
http://www.audioasylum.com/audio/spe...27/270975.html
Archaea is online now
post #2537 of 4790 Old 10-08-2014, 05:27 PM - Thread Starter
dominguez1's Avatar
Quoted: 966 Post(s)
Liked: 706
http://www.youtube.com/watch?v=SDPa0eGOwPI
Nice...some bada$$ speakers for sure!
I need to revise the estimated for the JTR subs because I think they are off. Once I do that, I'll estimate those 215's based on your impression of it with the EP4000.
carp likes this.
post #2538 of 4790 Old 10-08-2014, 05:33 PM - Thread Starter
dominguez1's Avatar
Quoted: 966 Post(s)
Liked: 706
So, for your front subs (IB), is that for all of them? For comparison purposes, it looks like your estimate at 12.5hz is around 114db (I subtracted 7db as that is how much the SI differs from its sim). That is Ricci's XXX Ported sub level of output...seems like it should be more than that, right?
post #2539 of 4790 Old 10-08-2014, 05:36 PM - Thread Starter
dominguez1's Avatar
Quoted: 966 Post(s)
Liked: 706
If you assume that 10hz was its tune, and its claimed 160db is groundplane and at tune...
One of those Royal Device subs would be equivalent of ~3600 18in SI drivers.
To recreate that in a sealed design using the 18in SIs and adequately powered, it would cost ~$1.4M!!! If you think about it like that, I doubt that took 1.4M to create....so what a bargain!
post #2540 of 4790 Old 10-08-2014, 05:48 PM
Bass Enabler
Liked: 4328
It's so not capable of that. At all.
post #2541 of 4790 Old 10-08-2014, 07:55 PM
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Agreed, by my calculations it should be able to do 146db @ 10hz.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #2542 of 4790 Old 10-08-2014, 07:58 PM
Bass Enabler
Liked: 4328
If that. Pretty optimistic figure. It could probably do something resembling that above 30hz.
post #2543 of 4790 Old 10-09-2014, 06:56 AM
MKtheater's Avatar
Liked: 1162
You are using the CEA burst numbers and the sims don't figure in distortion. The higher line is for the front wall and the lower spl line is for the 4 back. There is no way my front wall equals one xxx ported. My four subs in the back would at least equal the xxx ported around tune and much more everywhere else.
post #2544 of 4790 Old 10-09-2014, 07:07 AM
MKtheater's Avatar
Liked: 1162
Dom, all I did was port my old setup. My old setup could not be ported due to the IB designed motor. So I bought the equivalent output from SI(12) and ported the 8 and sealed the 4(near field). I have owned 4 LLT's with 13hz tune and this will blow them out of the water.
post #2545 of 4790 Old 10-09-2014, 11:55 AM
derrickdj1's Avatar
Quoted: 898 Post(s)
Liked: 608
MKtheater what size are the ported boxes?
derrickdj1 is online now
post #2546 of 4790 Old 10-09-2014, 12:53 PM
MKtheater's Avatar
Liked: 1162
It is one box, 230 cubes for the front wall. The back subs are 24 cubes each, or 48 cubes with 4 drivers.
post #2547 of 4790 Old 10-09-2014, 08:07 PM
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
The web page says the sub sensitivity is 120db @ 10hz @ 1w. So with the 400w he is using to power the sub should give you an SPL of 146db
My build thread
post #2548 of 4790 Old 10-09-2014, 10:15 PM
MKtheater's Avatar
Liked: 1162
The only way that is possible is if the horn is loaded at 10hz which it could be with the size of it.
post #2549 of 4790 Old 10-09-2014, 10:31 PM
Bass Enabler
Liked: 4328
"Says" and "is" are two different things.
You believe every posted spec you read online?
I'm not smart enough to explain it but nothing is capable of being that sensitive. Especially at 10hz. That is 100% fantasyland bull****.
notnyt likes this.
post #2550 of 4790 Old 10-09-2014, 11:30 PM
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Being that the sub is a horn and is using 16 x 18" drivers, I am leaning on the side that the sub is @120 db sensitivity.
So even if the drivers themselves had a sensitivity in the high 80db's, all those drivers combined ,plus the effects of the horn loading makes me think they are not pulling our legs. Or maybe I am just missing something with my line of thinking???
My build thread
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
