Your Home Theater ULF Score - Page 92 - AVS Forum
 140Likes
post #2731 of 2739 Old Today, 02:10 PM
jbrown15's Avatar
Quoted: 1146 Post(s)
Liked: 1172
So last night I took my new Reaction Audio CX-15's over to a local forum members place so that he could audition them, he has dual Mirage BPS-400 sealed dual opposed subs in his room on a suspended floor. Not keep in mind these subs basically don't really do anything below 20hz and actually roll off pretty fast as 30hz. But holy crap I wish I had a suspended floor!!!!....LOL
Now I understand what guys are talking about, I mean with my four monster ported subs you could get tactical feel from them but you would need to have them at some pretty insane levels. Then they would shake everything in the room. But I was amazed at how easily you could get tactical feeling and at such low levels. Makes me wish I could build my dream theatre room on a suspended floor!
jbrown15 is online now
post #2732 of 2739 Old Today, 02:26 PM
bear123's Avatar
Quoted: 271 Post(s)
Liked: 779
Can't you just build a platform to put your seating on? I assumed the bass would shake the platform much like it would a suspended floor. My house was built in 1928, and I have wood floors. Everything shakes and rumbles. I'll have to give that vibration app a whirl one of these days.
AVR:       Yamaha RXV-375
Display:  Panasonic  TH-50PC77U
LCR:       Hsu HB1.2  HC1.2
Sub:       (2) PSA XV15se
Blu Ray:  Sony BDP-S5100
Apple TV
Harmony 650
miniDSP
bear123 is offline
post #2733 of 2739 Old Today, 02:42 PM
derrickdj1's Avatar
Quoted: 118 Post(s)
Liked: 152
It still will not be the same with a platform. Last night I went up stairs and notice much more vibration/shake with the furniture due to the suspended wood flooring. If I could put my subs upstairs, I think I could tear up the the rooms, lol.
Klipsch RF 7 based HT 7.4, Pioneer SC 35, Acurus 200 Five, Dayton 18 Ultimxa Dual Sub Cab(2), Dayton 18 Ultimax Large Vented Sub Cab (2), on Berhinger I Nuke DPS amps, Samsung BDP F 7500, Asus/My Book Live HPC 4 TB
Yaquin VK 2100 amp, McIntosh XR 5 speakers, Samsung BDP F 7500
derrickdj1 is online now
post #2734 of 2739 Old Today, 02:43 PM
trmoore2's Avatar
Quoted: 14 Post(s)
Co-axial to RCA connection problem
Hey guys,
I have two coax cables running to my subwoofer from an AV Rack. I terminated the cable with RCA compression fittings. It seems I properly connecting the fittings (peeling back the shielding, etc.). Both cables either don't work or only work intermittently. It's not the sub, as I just replaced with a new sub. Any thoughts?! Thanks in advance.
trmoore2 is offline
post #2735 of 2739 Old Today, 02:46 PM
jbrown15's Avatar
Liked: 1172
Wouldn't be the same and no in my room that wouldn't work out to well, plus the ceiling height in my HT room is only 7'10" high.
post #2736 of 2739 Old Today, 03:09 PM
bear123's Avatar
Quoted: 271 Post(s)
Liked: 779
Hmm, wonder if 2x2's for a base with plywood would help and maintain most of your ceiling height? You would only lose 2-3". Just a thought.
AVR:       Yamaha RXV-375
Sub:       (2) PSA XV15se
Apple TV
Harmony 650
miniDSP
bear123 is offline
post #2737 of 2739 Old Today, 03:11 PM
Toe
Toe's Avatar
Quoted: 219 Post(s)
Liked: 536
This is why many of us with carpet over concrete build platforms built to flex and use transducers of some sort (I use BKs). It is a night/day difference in floor movement sensation vs just having seating on the carpet over concrete and might be THE best single upgrade I have ever done to my HT for audio or video.
My platform doesn't sit more than 3" off the ground with the kinetic rubber isolator feet. Even if you needed some 2x4s for more support (I did not even need to do this with my single couch), it wouldn't add much height and be well worth it!
I just need to figure out some sort of EQ that will allow me to reduce below ~15hz to keep my BKs from bottoming on those BIG ULF hits. I don't want to just turn down the overall level as I like my above 20hz right where it's at, so I just need to get some sort of simple (hopefully) EQ to reduce below 15 hz or so a bit.
JVC 3D: Been there, done that, bought a DLP
Toe is online now
post #2738 of 2739 Old Today, 06:26 PM
jbrown15's Avatar
Liked: 1172
I think part of it would have to do with the subs being coupled to the same floor your seats are on. I say that because my rear riser doesn't really feel any different then my front row. Plus that's not really a "suspended" floor, which is partly some of the effect.
post #2739 of 2739 Old Today, 08:18 PM
derrickdj1's Avatar
Quoted: 118 Post(s)
Liked: 152
I have wondered if the Isolator for the furniture feet wood make a difference. Transducers are the easy answer with the HT in the basement. You would have to buy 3or 4 subs to do the same thing.
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
