Your Home Theater ULF Score - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 522Likes
post #2791 of 4762 Old 01-17-2015, 12:08 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
For some reason on my Mac the calculator won't work
Can someone plug this in for me:
Room - 1600
2- psa xs30
2- Uxl 18's
And
4 - uxl 18's
Thank you!
Brian Fineberg is offline
post #2792 of 4762 Old 01-18-2015, 06:50 AM
ahmedreda's Avatar
Quoted: 301 Post(s)
Liked: 214
Here you go.
Room - 1600
2- psa xs30
2- Uxl 18's
And
4 - uxl 18's
Thank you!
ID:	485698   Click image for larger version
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is online now
post #2793 of 4762 Old 01-18-2015, 07:04 AM
Liked: 3514
Originally Posted by ahmedreda View Post
Here you go.
Thank you!
So Selling the psa's and going 4 ulx18's will give me the best results
Thanks again!
And this is for sealed ulx 18's?
post #2794 of 4762 Old 01-18-2015, 07:51 AM
ahmedreda's Avatar
Quoted: 301 Post(s)
Liked: 214
Yes, I used "DIY, UXL-18 Sealed"
Thank you!
Thanks again!
My home theater
Display: JVC RS400
post #2795 of 4762 Old 01-18-2015, 08:07 AM
Liked: 3514
Sweet!!
post #2796 of 4762 Old 01-18-2015, 08:36 AM
V.X.Donique's Avatar
Quoted: 52 Post(s)
Liked: 45
Thank you!
Thanks again!
Do it Bri, you won't regret it.
MOAR BASS
V.X.Donique
Introducing the Vier Systems Xero.1/Midbasiks Subwoofer builds....
Creator of the AVScience DIY Speakers and Subwoofers Forum
"Don't concentrate on the finger or you will miss all that heavenly glory." -Bruce Lee
V.X.Donique is offline
post #2797 of 4762 Old 01-18-2015, 08:43 AM
Liked: 3514
MOAR BASS
Oh I am . Gonna build two first see how I do
post #2798 of 4762 Old 01-18-2015, 08:55 AM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
Might want to also consider the SI-HST18. It has higher maximum excursion capability. So when the UXL-18 is at its absolute max output level and is starting to bottom out and make noises, the HST-18 will produce that output with excursion left. At least, that's my understanding as I have been researching what the best mid-priced 18 would be for a 4 ft^3 sealed enclosure. Now, the first graph on data-bass makes them look very similar, but when you read closely you will see that the UXL was starting to complain at that drive level, and the HST-18 had several more db's in the tank before running out of excursion. Look at the max long term output before compression and the difference starts to show up.
bear123 is offline
post #2799 of 4762 Old 01-18-2015, 09:05 AM
Quoted: 52 Post(s)
Liked: 45
Yeah, but unless Nick will be doing a "Group Buy" on the HST18 that the UXL18 is going for, I think that's the reason Brian's going the UXL route.
Personally I'd go with the Zv4/HST myself, but these group buys only come once in a blue moon
V.X.Donique
post #2800 of 4762 Old 01-18-2015, 09:18 AM
Liked: 3514
Exactly. It's only the group buy that enticed me
post #2801 of 4762 Old 01-18-2015, 10:03 AM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
It is called a higher x-mech. I am impressed with the quality of the even the SI-18HT.
Marantz 7702 Atmos
MKtheater is online now
post #2802 of 4762 Old 01-18-2015, 10:52 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Time to estimate a couple of more subs' ULF performance:
Triax T-18
Reaction Audio PS-18x
Similar to the Chase Subs, the T-18 run a variant of the Eminence 18. Perhaps a starting point would be 3 Chase 18.1 (or 1.5 18.2s)?
For the PS-18X, perhaps similar performance to the UXL?
Thoughts? Sounds pretty reasonable to me.
Name:	T-18 Estimate.png
ID:	486081   Click image for larger version
Name:	PS-18X Estimate.png
dominguez1 is online now
post #2803 of 4762 Old 01-18-2015, 11:11 AM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
I tried this calculator but it seems not to work on multiple subs. Unless I am doing something wrong.
Red99 is offline
post #2804 of 4762 Old 01-18-2015, 11:17 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
What are you trying to calculate? I can do it for you.
room size?
subs?
quantity?
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #2805 of 4762 Old 01-18-2015, 11:17 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
It does work for multiple subs. Just put the number of subs in the yellow cells to your corresponding sub, and it should calculate your score.
post #2806 of 4762 Old 01-18-2015, 11:42 AM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
I got it. I was putting in the number of subs at the top table and entering everything by hand. lol
Red99 is offline
post #2807 of 4762 Old 01-18-2015, 11:43 AM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
post #2808 of 4762 Old 01-18-2015, 11:58 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
That's an easy opinion to have if you've never used or heard the UXL's in person. The simply fact is 99% of the guys even buying the UXL's from the group buy won't even be pushing them hard enough to even get close to max output. And in a sealed box you won't be pushing them to full excursion with an iNuke amp so you're not going to hear any bottoming out or loud noises.
In my ported cabinets my house started to show more stress then the UXL's did when really hammering them. I think the simply fact of the matter is that most guys using UXL's will be amp limited rather then driver limited.
jbrown15 is offline
post #2809 of 4762 Old 01-18-2015, 12:00 PM
jbrown15's Avatar
Liked: 1993
Triax T-18
Wouldn't three Chase 18.1 have large cabinet volume which would increase the really low end numbers compared to a Triax-18? If the cabinet of the Triax-18 is smaller it would have a little less output in the 10hz & 12.5hz ranges.
jbrown15 is offline
post #2810 of 4762 Old 01-18-2015, 12:02 PM
jbrown15's Avatar
Liked: 1993
Thank you!
Thanks again!
Brian, that was exactly the same thing that I did this time last year!....lol
Total deja vu, if you have the space you should serious consider building ported cabinets like what I did.
To give you an idea of the output difference between four sealed UXL's and four ported ones like I built in your room, here's the ULF score you'd have
Sealed:
286 @10z, 267 @12.5hz, 250 @16hz, 267 @20hz .
Ported:
444 @10hz, 154 @12.5hz, 78 @16hz, 182 @20hz .
That's a really big difference in the 12.5hz to 20hz range.
jbrown15 is offline
post #2811 of 4762 Old 01-18-2015, 12:06 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Yes, but the T-18 offsets the small cabinet size with the high powered plate amp.
post #2812 of 4762 Old 01-18-2015, 12:06 PM
Liked: 3514
Haha nice
Well im starting small with only two to add to my xs30's. So I want to stay sealed. Then I will build two more if the first two are to my liking
post #2813 of 4762 Old 01-18-2015, 12:13 PM
jbrown15's Avatar
Liked: 1993
I thought the data-bass 18.1 numbers are for the passive unit using Josh's amp?
jbrown15 is offline
post #2814 of 4762 Old 01-18-2015, 12:36 PM
Quoted: 978 Post(s)
Liked: 506
Sealed:
Ported:
What is the port tune?
post #2815 of 4762 Old 01-18-2015, 12:38 PM
Liked: 3514
And what is the cabinet size?
post #2816 of 4762 Old 01-18-2015, 12:43 PM
3ll3d00d's Avatar
Quoted: 1566 Post(s)
Liked: 542
I don't follow your comment re max long term output. The long term data on data-bass says that the UXL has marginally more long term output <22Hz, marginally less til 35Hz and then ~3dB more through the mid bass. It looks to me more like they have similar output overall but the UXL needs less power to get there & the HST can take more abuse.
3ll3d00d is online now
post #2817 of 4762 Old 01-18-2015, 01:21 PM
jbrown15's Avatar
Liked: 1993
Port tune was 14-15hz, all info can be found in my old build thread.
LTD-M18 Sub Build
jbrown15 is offline
post #2818 of 4762 Old 01-18-2015, 01:34 PM
Liked: 3514
LTD-M18 Sub Build
Cool
How do you tune a port? Those are waaaaay to big for my place
post #2819 of 4762 Old 01-18-2015, 01:41 PM
Quoted: 978 Post(s)
Liked: 506
Cool
You don't tune the port. Port tune is what the sub is supposed to play down to before roll off begins. Port tune is made up of driver parameters, box size, port size, and amplification. Simulations can help you decide on your dimensions and amplification.
post #2820 of 4762 Old 01-18-2015, 02:30 PM - Thread Starter
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 614
Hmmm, good point. I'll look at db to see how many volts it was given...I'm guessing it wasn't that much relatively speaking, meaning the speaker power amp would have enough juice to compensate for the small box.
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
